Google tablet - Nexus 7
Meni je se malopre zamrzao i nije reagovao na dodir,gašenje i paljenje rešilo problem tako da će i kod mene pasti vraćanje na fabrička podešavanja.
Ja sam stavio drugi karnel preporodio se.
Trenutno franco, slabo igram igre pa ne mogu da ti kazem tacno za bateriju.
Druze jesi li vratio na fabricka podesavanja,bas me interesuje kako se ponasa ako jesi:sceptic:
šta se gubi sa factory resetom tj. šta ostaje ?
ja se nešto kolebam...čini mi se da se usporio, recimo 20 posto.
Speed Up Your Aging Nexus 7 2012′s Storage with F2FS
It’s no secret that despite being a great device overall, the Google Nexus 7 (2012) offers less than ideal flash memory performance. While the issue has been mitigated to a certain extent through the use of TRIM, file system performance is still often the device’s Achilles heel. Because of this, it stands to reason that any steps taken to improve storage performance on the device will greatly improve the overall user experience.
XDA Senior Member legolas93 decided to take on the task of improving the Nexus 7′s storage performance through the use of F2FS, which is a different file system created to be more optimized to the characteristics of NAND memory in flash devices. But before we go any further, it’s important to note that when changing your file system, you will lose all of your data. So please make sure that you make a full backup, and then transfer that backup to your computer while you perform the required steps.
To get started, you must first download the F2FS-enabled kernel and a modified TWRP capable of reformatting the tablet with F2FS. Then you flash the kernel through your current custom recovery and the modified version of TWRP through fastboot. Next you access the modified TWRP and format to the new file system. And finally, you can restore your backup after copying it back onto your tablet form your PC.
More detailed instructions and all of the downloads can be found in the original thread. And if you’re a SlimKat user, you may want to try this version modified to be fully compatible with F2FS.
preuzeto sa xda portala
moze li netko tko se bolje razumije pojasnit o cemu je stvar?
Stvar je u novom fajl-sistemu koji je bolje prilagođen NAND memoriji. Svede se sve na instalaciju kernela koji ga podržava i TWRP-a koji će da formatira memoriju u taj FS.
Jesi na toliko informacija mislio?
Znali neko gde bih mogao da zamenim ekran nexus-u. U ovlašćenom servisu su mi rekli da je 19000 a ja tablet platio 17000 😡 Bilo kakva vrsta informacije bi mi značila
Stvarno nisu normalni. Mozes N7 2013 maltene za te pare uzeti.
Nema veze šta možeš novo uzeti za te pare... ako ti je za utehu, ekrani mobilnih telefona koštaju tek nešto manje, pa onda ta cena koju su ti rekli ima smisla.
Bolje pitanje je koju bi cenu ti očekivao kao realnu?
Sve je tačno što Džoni kaže, ali je tačno i da to gore nije original.
A evo recimo moj slučaj sa sličnim opisom i sličnim kvalitetom digitajzera za iPad - nikad nije radio touch kao na originalu. Imao sam osećaj kao da kasni za mojim pokretom. Vrlo iritantno.
Takođe, računaj i troškove naše drage države na ovo gore. Kada vide ekran lupiće PDV kao da je roba od 100e, vrlo verovatno da neće tražiti fakturu. Naravno, i u tom slučaju je to i dalje jeftinije nego što ti traže u servisu, ali podvlačim da ono gore nije original. Možda ti bude super, možda baciš pare.
A u servisu stavljaju original? 🙂 Kako da ne. Iste gluposti koje se vrte po ebay-u stavljaju. Znam, prošao sam ''tu školu''.
Što se carine/pdv-a tiče, mogu da zapadnu isti, a i ne moraju. U vr' glave ispadne 50-ak eura. Mogu u carini da lupe da je ekran i 200e, samo se ne primi paket koji poštar donese, ode se do carine i reši se problem.
Pa vidi, ako je zvanični onda zaista verujem da jeste original.
U svakom drugom moguće da će ići linijom manjeg otpora i staviti šta im donese veću zaradu.
Dao bih maksimum 9000. Pogledaću to na ebay-u ako ne nadjem neki servis kod nas.
Ja sam nexusa prodao pre dva meseca 100e bio kao nov,garancije imao još 18 meseci..
Pokusao sam da pustim film preko usb i Nexus Media Importer-a i nece😡Ranije radilo kao podmazano,da nisu nekim updateom onemogucili,kako je kod vas?:sceptic:
Znaci ipak su onemogucili?Zahvaljujem
Не знам јел раније радило пошто ме није занимало пребацивање само медија, поготово само у једним смеру. Одувек користим stickmount на Н7.
jel probavao tko nastimati nexus-a u auto? Kao navigaciju, glazbu, itd itd..
Gledam ovaj na youtubeu kako je postavio nexus, koristi izgleda nekakve magnete..?
[YOUTUBE]ww-9-N3yXEU[/YOUTUBE]
U mene isto ovakav auto kao na videu, zna li netko gdje bi mogao naci nekakve drzace ili slicno kao na videu?
To nije to
A kad pomeris na gore za visinu bezela jel se onda uklapa? Mislim porucio si samo ekran bez toucha?
Da izgleda da je to to samo bez touch-a ako neko nadje po nekoj normalnoj ceni touch neka mi javi ovde ili na pp. Hvala unapred.
Jel' zna iko ima li ovome spasa ?
Pre par dana mi je pao, i slomilo se staklo. Touch radi u oblasti ispod pukotine. Ekran radi normalno. Jel ima iko iskustva sa popravkom, gde se moze nabaviti original zamenski displej?
