onua
http://tasker.wikidot.com/profile-index
Pošto je interesovanje za Tasker veliko, evo je i tema :banana:
Evo mog polu teškog setupa za nap time (all credits for users in xda). U pitanju je Nap Time setup koji radi sledeće:
1. da uključi silent na telefonu
2. da pokrene alarm aplikaciju
3. da za primljene poruke i propuštene pozive pošalje auto sms "OVO JE AUTOMATSKA PORUKA. Trenutno spavam, javiću se kad ustanem. Pozdrav" onome ko me je tražio
4. kada isključim profil, da vrati sound na normal
Evo kako ide (u potpunosti kopirano sa xda sa mojim izmenama):
Ovako sam dobio 2 widgeta Start Nap Mode i Stop Nap Mode kolje uključujem i isključujem po potrebi.
Testirano i radi :wave:
ps. Ovih dana ću pokušati da editujem (opet sa userima sa xda) setup koji će raditi sledeće:
1. kada me jedna osoba pozove JEDNOM da pošalje auto sms i ostavi silent uključen
2. kada me jedna osoba pozove VIŠE puta da isključi silent i zvoni redovno
Lock your applications
Silent Incoming calls by turning your phone
Keep Screen On
Change wallpaper Automatically
Disable lock screen in Home
Jessy Pinkman!
Auto rotate screen for certain apps
Enable WiFi when at Home
Automatically switch profiles in certain areas
Use it as a Location Based Reminder Tool
		Kod:
	New Task: Start Nap Mode
[A1]: Variable - Variable value, %NapMode to On
Save this Task and add an icon to it (so that we can create the widget)
New Task: Stop Nap Mode
[A1]: Variable - Variable value, %NapMode to Off
New Profile: Nap Mode
Context: State - Variable Value, %NapMode matches On
[A1] Audio - Silent Mode, On
[A2] App - Load App, now select your alarm app
New Profile: Nap SMS
Context: Event - Phone - Received Text (leave the fields blank to reply to all)
[A1] Variable - Variable Set, %NapSMS to %SMSRF
[A2] Phone - Send SMS, Number; %NapSMS, Message; "I'm sleeping, leave me alone" (or whatever), Tick the Store in Messaging App if you want
New Profile: Nap Call
Context: Event - Phone - Missed Call (leave the fields blank)
[A1] Variable - Variable Set, %NapSMS to %CNUM
Now create 2 widgets on your homescreen using the Tasker Task widget and have one link to the 'Start Nap Mode task' and the second link to the 'Stop Nap Mode' task
You can now manually start and stop it by these buttons, it will also be disabled as soon as you have a missed call.
Keep Screen On
Jessy Pinkman!
