AMD Radeon Rx serija
Sto nisu stavili neki gaming test, grejanje bi bilo manje. Vise me interesuje to realno stanje, nego ovo silovanje sa 3Dmarkom i sl programima.
Al ok, sve u svemu hladjenje je bolje, radi tise, cena je i dalje dosta povoljnija od Titan/780Ti koje redovno sustize. A sada... cekanje za R9 290 sa boljim hladnjacima. :)
Ima test na pcper, Asus dc,performanse na nivou 780ti tisa od referentne 20 stepeni hladnija ne obara klokove i navodno samo 20 dolara skuplja. Jedina mana što je neće biti nigde veoma dugo :)
ne znam sto je samo trebalo ovako dugo Asusu da izabci ovu kartu hladjenje mi se cini isto kao na GTX780Ti previse su otezali sa izbacanjem ove karte, ali izgleda odlicno odradjeno ako se gleda referentna R9 290X, ovo je onda savrsenstvo, sprasi titana u svakom smislu, Performanse/cjena/hladjenje.
The Sapphire R9 290 Tri-X OC Edition
http://www.kitguru.net/components/g...ire-r9-290-tri-x-oc-review-1600p-ultra-hd-4k/
Sapphire have overclocked their R9 290 Tri-X from reference speeds of 947mhz to 1GHZ and the GDDR5 memory has also received a speed boost, from 1,250mhz to 1,300mhz. This should translate into a healthy performance boost when compared against the AMD board.
The adoption of massive 10mm heatpipes has really worked wonders for cooling performance. When gaming, the reference R9 290 holds at 95c, and this overclocked Sapphire Tri-X version at only 68c. Yes, that is an improvement of a staggering 27c under load. The Sapphire R9 290 Tri-X OC doesn’t thermally throttle either which can help under certain situations.
Well, MSI je "pustio u prodaju" svoje custom 290 i 290X modele [Twin Frozr hladjenje].
http://www.techpowerup.com/196074/msi-r9-290-gaming-4g-and-r9-290x-gaming-4g-now-available.html
Kao i XFX [sa boljim hladjenjem po indenticnoj ceni kao i reference modeli :)]
http://www.techpowerup.com/196072/xfx-rolls-out-radeon-r9-290-series-double-dissipation-cards.html
Ali sansa je velika da je ce rudari sve to da pokupuju, ili da zbog pritiska kod svih ostalih modela, da cena ode gore svuda za jos dugo vremena. AMD moze samo da predlozi MSRP, a prodavci nemaju nikakvu obavezu da to ispostuju.
Ne zna niko mozda nece nikad ni izaci.
na wikipedia stoje neki kao podaci o tome, al ko zna, sve zavisi koliko losh yield amd ima i koliko ce skarta biti da se osakati i promeni ime :)
A na temu 290 ide mi voda na usta od modela kojih dolaze karte je bolesna samo po sebi :)
Postovani, zanima me da li neko ima MSI R9 280X Gaming 3G graficku kartu, kakva su iskustva sa njom, koliko kh-a daje, koliko napajanje je dovoljno za 2 ovakve karte? I da li je bolja opcija ova kartica ili Asus r9280x dc2t? hvala unapred :)
Malopre sam video da ima 280X Toxic, samo je 40evra skuplji nego napolju al sta je to za nas mi smo bogati :crash:
42k :p, znaci buduci 290 toxic ima da bude minimum 52k...
E bas sam to hteo da napisem, nereferentne 290 ima budu nenormalno skupe. Ma ja ne planiram ovde da kupujem vise, samo nesto malo ako moram..
Krenuce Madjari nadam se i graficke da donose.
Dva slajda sa behind the closed doors CES prezentacije za Kaveri APU:
Jel stiglo ista od custom cooler modela od 290/290x kod nas?
290 je bese bio najavljen kod nas za 40k, evo vidim danas da Atom prodaje stock 290 za 52k. T_T
Nije bilo tesko za pretpostaviti da zbog rudara od tih "najavljenih" cena nece biti nista.
Zato sam ja bez razmisljanja uzeo referentnu 290x pre mesec i kusur, i to sam jedva nasao i nju.
Odlicna karta - katastrofalan launch. Posebno za gamere. Na kraju balade ostajem na staroj kartici dok se stvari malo ne iskristalisu.
Mislio sam da neće ni izbaciti 280 :d
Mora nekako škart da se iskoristi, samo izgleda da ga nema preterano puno čim je ovoliko vremena trebalo.
Vjerovatno je sazreo 28nm proces, a i trebalo je rasprodati HD7950, ova karta R9 280 trebala bi biti bukvalno Hd7950 sa drugim nazivom, ali za 249$ opet je dobro, ako potraje ovakvo stanje sa dzukelama ili sa LTC moze se otplatiti za 2 mjeseca.
Ovo rudari odavno cekaju vjerovatno zbog velike potraznje tesko ce biti dostupna na domacem trzistu iako bude bice vrtoglave cjene kao i za R9 280X
Lepo. Samo što ovde neće biti tako lepo, koštaće kao 280X napolju a i neće je ni biti tako da *** :D. Može AMD da izbaci šta hoće ovde je ko sa benzinom `93-e..
