ikoalosaurus
Zanimljiva zverka 🙂
To je do 3d marka, moras da stavis patch.
Samo da je još malo utišam u 2d.
Čini mi se da je malo glasnija od stare grafe a i 2 fana ima.
Ako ti kartica ima Product No. neka od ova dva:
70-C1CQ90-A06
70-C1CQA0-A06
pokusaj da stavis nov BIOS (imas ga ovde ). Na raznim forumima ljudi potrdjuju da im je u 2D kartica tisa. Uostalom, i asus ga je opisao kao "New VBIOS for reducing the FAN nois" :d
Uzeo sam i ja tu karticu, samo P.N. mi pocinje sa 90, tako da je tiha kao nindza ,)
Sobzirom na kojim taktovima radi u 2d dobro je.
GPU core: 405Mhz
Memorija: 162Mhz
Shaders: 810Mhz
Temeratura: 31-33 C
Fan: 16-18% 1110-1140 rpm
VDDC: 0,9500V
Gainward GTX560Ti Golden Sample --> Thermaltake Xaser III V1000A ¦ Thermaltake Toughpower 750W [W0116]
Gigabyte GTX560Ti@1000MHz --> CoolerMaster 690 + Corsair HX750
Gigabyte GTX560ti OC @ 980MHz --> Chieftec CFT-750-14CS
nVidia GeForce GTX 560 Ti --> CoolerMaster 690 - TT Toughpower 750W
MSI GTX 560Ti --> NZXT Phantom + SeaSonic 850W
MSI GTX 560 TI Hawk --> Cooler Master Haf X + Chieftec Nitro 850w
MSI N560GTX-Ti Twin Frozr II OC --> Cooler Master CM 690 II Adv.,SEASONIC SS-620GM
MSI GTX 560 Ti Twin Frozr II OC --> CM 690 II Advanced/Corsair VX450/Scythe S-Flex
MSI GTX 560 Ti Twin Frozr II OC --> CM HAF 932 i Seasonic 750W
Gainward GTX560 ti 1gb --> Nzxt Hades,LC Power Metatron Prophecy LC8750
ASUS GTX 560TI DCII --> CM ELITE 430, CHIEFTEC CFT-750-14CS
ASUS ENGTX560 Ti DCII TOP/2DI/1GD5 --> COOLER MASTER 690 II ADVANCED,CHIEFTEC CFT 650W
GIGABYTE GTX 560 TI 1GB DDR5 --> Cooler Master Centurion 532 Black,Chieftec 600W-14cs
ASUS GTX560Ti DCuII @ 1005/1102 --> NZXT tempest + LC6650GP3
Gainward GeForce® GTX 560 Ti 1024MB Golden Sample --> CM RC 690
Gainward 560 Ti, GS, 1gb --> A Big One!
MSI 560GTX-Ti Twin Frozr II/OC --> Chieftec BX-B-B-B-03
MSI N560GTX Ti Twin Frozer II --> CHIEFTEC CTB 650W
GTX 560-Ti MSI HAWK --> CM 690 Advanced II-CM GX 650W
MSI N560GTX Ti Twin Frozr II --> Lenovo D20 case + Bel 1060w PSU
Gainward GTX 560 Ti 1024MB Golden Sample --> Cooler Master HAF 932,Chieftec CFT-650-14C CS 650W
Gigabyte gtx 560 OC --> LIAN LI
Asus GTX560Ti DCII TOP --> CM 690+Corsair TX850
ASUS GTX 560 Ti DirectCU II TOP --> Cooler Master 690 II Advanced i Chieftec CFT-750-14CS
ASUS GTX 560 Ti DCII TOP --> Antec Nine Hundred / Chieftech CFT-650-14CS 650W
Ako za PC bude neophodno napajanje preko 600W samo da bi po def. koristio neki x8> CPU
onda pisi propalo, koliko to struje ima da vuce.
Dzaba i napajanje i sve ako placas elektrodistribuciji po bar jedan 2TB hdd(nov naravno 😀 ) mesecno.
