Rucno sam odradio po ovom uputstvu , ali na napravljenim kljucevima Port0,1,2,3,4,5 nemam AN i GTF DWORD kao kod@ P307
da li treba jos nesto odraditi sem ovoga u uputstvu?
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\iaStor\Parameters\
1. Go to Start-> Run..
2. Type in RegEdit and hit the Enter Key..
3. Go to the following Key location to insert or configure the registry keys for LPM:
4a. Right click "Parameters" select "New" then name it "Port0".
4b. Left click "Port0" to open and in the pane with Name/Type/Data, Right click select "New" then "DWORD" and name the new value "LPM".
4c. Repeat 4a/4b "LPMDSTATE" and "DIPM".
5. When you want to ad the other Ports also to registry, then repeat the steps from 4a to 4c and name it Port1, Port2, Port3, Port4 and Port5.
