Ima li on lock screen widget?
treba mi neki plejer (osim poweramp-a) koji ima to, moze da pregleda po folderima muziku, i da je sortira po datumu dodavanja (poweramp mi baguje kod ovog poslednjeg, zato bih ga menjao)...
Ima player pro
Da spektrum je super, samo jos da je player.. :D evo bas sad probam ovaj Miui jeste to to, ali treba mi bas neki koji ima zive boje i sve, ovaj Miui mi vise dodje kao za sa'rane i opela... :D
Za Amazon App
Evo nasta sam naisao (nisam probao):
How to use Amazon App Store for non-U.S. Android users:
1. Register for an e-mail address or use a throw-away account. DO NOT USE your current email address tied to Amazon because entering fake information is grounds to have your account suspended.
2. Register for a new account on Amazon using the disposable email address. Again, DO NOT use your regular Amazon account or email address.
3. Enter information as if you were based in the U.S. Go to "www.fakenamegenerator.com" for help in this regard. Enter the name, address, phone number, and credit card number (Amex, Mastercard, Visa ).
4. Download the Amazon App Store apk to your phone.
5. Browse the Amazon App Store from your phone! You will not be able to access paid apps, but you can at least get the free apps that are exclusive to Amazon.I’ve double-checked with a staff member based in Europe and it worked, so good luck.
Treba mi neka najosnovnija vremenska prognoza,znaci bez previse nekih nebitnih gluposti,a da lepo radi. Samo da napomenem da nisam stalno online,ali jesam cesto,tako da mi treba da vidim temperaturu u datom trenutku,ne mora ni da se automatki updateuje,mogu i ja rucno kada mi zatreba :)
Ja sam odustao od svih vremenskih prognoza, pratim preko twittera
@Marko Ja koristim Go weather, ima ona dosta i podesavanja i skinova, ali je dobra kao widget, na jednom od skinova imas refresh dugme tako da bi ti koristilo za ono sto ti hoces.. ima i Live wallpaper, ali on bateriju ubije ocas posla..
E meni isto treba neka weather app koja u widgetu pokazuje 3-4-5 dana unapred vremensku prognozu?
@djilkosh Ne znam za sam widget, ali imas accu weather on ti pokazuje trenutnu, a kad jednom pritisnes njega dobijas prognozu za 5 dana unapred..
^Da da to znam. Mislio sam da ima neki free da se preporuci :)
Mislim da sam pitao ali se ne secam.. Potrebna mi je aplikacija koja ce skenirati Wi-Fi mrezu, pronaci sve racunare na mrezi po imenu,i zapamtiti, tako da kada se promeni ip adresa da moze da pristupi deljenim resursima bez konstantnog skeniranja. Takodje sama aplikacija treba da registruje telefon na mrezu po imenu, kako bih mogao da odem na racunaru u Computer\Network i tu da vidim ime telefona i da pristupam deljenim direktorijumima, kao i da mapiram to ime na disk.. Dakle, ima li tako nesto..
EDIT:
Nasao sam: https://market.android.com/details?id=com.funkyfresh.samba&feature=search_result
Ima li jos neka aplikacija tog tipa?
Instalirao sam beweather,to je to sto sam trazio,hvala na preporuci :)
I meni je non stop aktivna u pozadini. Kako misliš non stop drži budnim? Slobodno je deinstaliraj, pa koristi web verziju.
EDIT:
Ili neki rom sa podrškom za cifs.
Pa vise mi odgovara aplikacija...ako sam ROM ima tu podrsku kako bi se koristila.. Verovatno, isto, preko nekog programa.
Ja ne znam koji je ovo djavo,ali sad mi beautiful widgets brljave..tj tacnije weather widget,kad mi otvori forecast ekran lepo pise Nis,ali kad "kliknem" na prognozu za naredne dane,on mi u browseru otvori prognozu za mesto "Kamenica" koje je pored Nisa,a ja tamo zadnji put bio ko zna kad?!?Takodje,da li ovaj weather widget razlikuje dan i noc?Jer on mi bilo nocu,bilo danju drzi istu ikonicu na homescreenu za maglu,u vidu zamagljenog sunca..
^Pa kad je stalno magla :D
BeWeather odlican!
Sent from my Samsung Galaxy S 2 powered by ICS Domination
Jel ima Kragujevac u BeWeather-u? :)
Meni Beweather strasno baguje telefon. Nekoliko puta sam morao bateriju da vadim o_O
Auuu da to je mocna aplikacija, ako neko zna kako se zove neka kaze da trazimo...
To je HTC-ov sense widget za vreme, nema to nigde na marketu, barem ja nisam video, a obrnuo sam dosta weather aplikacija.
