možda su ispravili propust pri punjenju baterije (ono kada skinete sa punjača a ona odmah padne za par procenata)
To nije propust koliko znam i pisao sam o tome na prosloj strani.
Baterry life mi je odlican na 6.0, kao i na svim njegovim romovima do sad izuzev 5.6 gde baterija nije htela da se napuni na 100%, kad sam skidao fon sa punjaca padala je odma na 98%. Uradio sam rekalibraciju baterije i obrisao battery stats. Nisam ni imao prilike da vidim koliko je to uspesno bilo jer sam ubrzo posle toga flashovao 6.0 i evo danas kad sam napunio telefon na 100% ostajao je na tom procentu, tako da je problem resen u svakom slucaju.
Koliko sam citao, posle nekoliko promenjenih romova pobrljavi battery stats koji mora da se obrise i da se baterija ponovo kalibrise upravo ovako:
So, you are having trouble with your battery seemingly draining too quickly, especially after having flashed many ROMs/Kernels/etc...
It is possible that the problem (or part of the problem) is not necessarily the phone using too much power. If this is the case for you, you should see some results from doing the following:
1. Connect the phone to the charger with the phone powered on, and allow the phone to charge until it shows 100%
2. Disconnect the phone from the charger, and power it off.
3. Reconnect the phone to the charger with the phone powered off, and allow the phone to charge until the battery indicator shows 100% (you can use vol-up/vol-down to make the indicator come back up when the screen goes to sleep).
4. Disconnect the phone from the charger and power it on.
5. Once the phone is powered completely on, power it off again and reconnect it to the charger until the battery indicator shows 100%.
6. Disconnect the phone, power it on, and use it.
You should only need to use this sequence one time.
Hope this helps.
Bas sam pratio punjenje pre neki dan i notifikaciju da je baterija puna, ali zapravo istog trenutka padne na 98% kad se skine sa punjaca. Ako je to slucaj onda treba da se uradi ovo gore i battery stats clear. Kao sto rekoh, danas kad sam skinuo fon sa punjaca posle prethodno uradjenog pomenutog guida, ostao je na 100%, znaci to nije propust, mora samo baterija da se rekalibrise.
