To i ja mislim. Još samo da bude 260E
EDIT: Ja sam bolestanKoji će mi djavo nova grafa?!
...kao sto sam i napisao po evropi... i najjeftinije se pise zajedno
Jel prati neko i dalje onaj nemacki forum?Ima jos zanimljivih stvari![]()
...ne bih se slozio. Ako bude 6950=5870(a za sad ovi rezovi tako nagovestavaju), onda ce se verovatno pojaviti po ceni od 5870... kako u evropi tako i kod nas...Nemoj pisati cifre za evropu jer nama to apsolutno nista ne znaci.
kolko je meni poznato 5850=6870<5870 ohohho![]()
IMHO, 5850 se bolje klokuje od 6870 pa kontam da su tu negde, cak mislim da je 5850 za nijansu jaca kad se obe oc...
ok. mozda gresim... nije to ni bino , nego 6870 se pojavila po ceni 5850... zasto sad ne bi bilo isto tako ako bude 6950=5870?
Nebi reko da je ovo tacno:d onda bi bila ko GTX580:d
Ispravka, onda bi bila za nijansu sporija od GTX580, baš kao što je neko od forumaša rekao pre desetak stranica![]()
What'll be interesting to see is what games the reviewers use to compare. If they use games that are heavily 5870 favored, Cayman might not look great - however, if they show games where the 5870 struggled and 480/580 excelled, its possible Cayman looks amazing. Of course, this will show who's biased to who...
TL;dr - 3dMark and other benches are optimized for VLIW-5 and VLIW-4 isn't optimized yet, and so 3dMark isnt representative of Cayman performance yet. Where Cayman will shine and probably pull ahead is in DX11 games where DirectCompute and Tessellation is necessary. Ultimately, the suite/games tested will determine whether the 6970 looks like a big improvement. What's most important though is comparing it to the 480/580/570 and seeing if it is a more consistent performer relative to those cards than the 5870.
In an interview with Eurogamer, 4A Games’ CTO Oles Shishkovtsov described their new proprietary game engine.
"I really enjoy three things: compute shaders, tessellation shaders and draw/create contexts separation," Shishkovtsov says. "The major thing that can up the performance is the compute shaders. Today, games spend the majority of the frame doing the various kinds of post-processing. The easy route to extract some performance is to rewrite that post-processing via compute. "Even the simple blurs can be almost twice as fast. For example we've rewritten our depth-of-field code, to greatly enhance quality while still maintaining playable frame-rate. [In Metro 2033] all the 'organic' things like humans are tessellated and monsters use real displacement mapping, to greatly enhance visuals."
Nema me 24h i napisete 6 strana... i to u nedelju
Interesantno je da niko i dalje ne zna cenu, iako je ostalo skoro sve poznatoInace, Ace-ov post pogadja sustinu
Promenjena je arhitektura, sve optimizacije ne vaze, posebno za sintetiku... setite se samo prvih rezultata 8800GTX
Sto se tice die size, odnosa sa GF110 i slicno, tacnog broja SP... bez problema su mogli da naprave Cayman nesto vecim (ali i dalje mnogo manjim od GF110), samim tim brzim, i ubedljivo najjacim GPU-om današnjice. Procenili su da im to nije potrebnoVidecemo vec zasto su to odlucili, i da li im je odluka na mestu.
