Bravo, vidim da si me dosledno zamenio.....
Nije da zameram, ali sam na drugom forumu nasao info da je to nezvanican FW...
Ajde reko opet da te preduhitrim, nemoj da mi zameris...
:type:
http://www.o2media.es/firmware/firmware_NTR83L/NTR83_Firmware_Ver.1.74.zip
Verzija 1.74
Dodan Hrvatski jezik u OSD MENU
dajte i za 81 i gde moze da se vide unapredjenja novog firmware-a?
MKV merge i sastavis to za 5min.
NOVI FW ...0.75
Improved items. Version 75
Corrects the problems with TV screen or playback of video contents when setting HDMI option as AUTO in the video output (fonud in some TV)
Corrects the problem with the scheduled recordings by EPG
Corrects the problem that recordings will not be finished in the desired tiem to whtih you set the Duration option
Corrests the error of recording file name when you record some services or programs (example: ABC Weekly, Middle Man)
This character is created on teh first letter of program title
Corrects the problem that you cannot copy, move, deleto or rename the recording file on PC
Time Shift Storage should be created on the HDD to first use Time Shift feature when the player is conneted to external AV (Not applied to DTV)
The operation of player is limited during its process (around two minutes)
When this storage is created in the drive one, this process is not needed any more (as long as you will not replace HDD)
The message box appears on the screen concerning this matter
verzija za ntr81
http://hm-download.pl/firmware/Novatron/NTR81_Ver75.zip
verzija za ntr 82, 82
http://hm-download.pl/firmware/Novatron/NTR82_NTR83_Ver75.zip
odavno je ona, potrazi po netu mozda novije ima...
Da takođe problem sa YouTube servisom... pretraživanje radi perfektno, ali samo prikazivanje video zapisa nikako ne radi. CNN recimo radi.
Takođe mi se dešavalo da se uređaj zablokira na nekim Internet Radio stanicama
Ponekad štuca i mreža, (share sa drugim računarima) ali to verovatno nije do njega nego do Windows 7 OS na mašini.
Naravno svaki predlog je dobrodošao? Kada će novi firmware!
Da li je neko probao da pusta online streaming preko iamma i da li je to uopste moguce ?
samo na komp instaliraj Cisco network magic i neces imati apsolutno nikakvih problema
