Ne znam da li nekog od vas još mori problem sa satom koji se stalno menja. Meni je ovo rešilo problem
Dear Stuart
This is not a fault with the device or its software, your device updates its time automatically from the Internet and from your mobile provider.
Occasionally there is a difference in the time from the Internet and the time from your provider which can cause the time to appear to be changing when it should be the same.
Normally this will resolve itself within a few days, however, this is very inconvenient so we recommend to disable any automatic time updates on your device.
This will not effect your sync with other things like Exchange and similar
From the Home screen tap:
Start - Settings - Data services - Time synchronization - Untick all here.
AND
Start - Settings - Menu - All settings - Personal/Private - Phone - GSM & UMTS Services - Time synchronization - Get settings - Untick all here.
Sincerely,
Adrian
HTC
