PotPlayer (naslednik KMPlayer-a)
Koja je poslednja verzija ovog cuda? I odakle je najlakse da se skida najnovija verzija...
Zašto se PotPlayer ne nalazi na velikim download sajtovima (Softpedia, Download.com, SnapFiles i slični)?
ko zna... autor je tvorac KMPlayera, koji je prodao, pa sada razvija PotPlayer 😀
Da neidem duboko u off ali Gom Player ima zabinljivu devizu:
- Play Any Video File, Any Time!
Treba samo napomenuti da je frbesplatan i da je kompatibilan sa Windows 7
http://www.gomlab.com/eng/GMP_download.html
Kod:
GOM Media Player Features
Codec Finder
GOM Player includes many codecs (XviD, DivX, FLV1, AC3, OGG, MP4, H263 and more) so you won't need to install separate codecs for most videos. For those videos that require a separate codec, GOM Player will find one and direct you to a place where you can download an open source version of the codec. That way, you won't get stuck with unnecessary codecs on your system.
Play Broken AVI Files (Patented)
AVI files can't be played if the index is broken, or if the file isn't completely downloaded. This is because the index is located at the end of the file. GOM Player's patented technology enables users to view files with broken indexes or that are still being downloaded.
Powerful Subtitle Support
GOM Player supports SMI, SRT, RT, SUB(with IDX) files for subtitle. You can specify margin, location, size, resolution, font and others. You can also enable shadow, view ASF files with subtitle, karaoke subtitle mode. You can even synchronize subtitle and video if there's any mismatch.
Convenient Playlist
If you run a video file and there is already a file with a similar name in the directory, it will be automatically added to your playlist. GOM Player has a similar playlist format as M3U, PLS, ASX and you can also include and edit different media formats on that playlist as well. It's easy to create and edit your own multimedia playlist with GOM Player.
Support Different Media Types
Along with different media format such as AVI, MPG, MPEG and DAT, GOM Player also supports streaming Windows media format (WMV, ASF, ASX). You can also watch DVD-quality videos with 5.1 channel audio output.
Screen Capture
Screen capture allows you to take a screenshot of your video directly from GOM Player. Using the Burst Capture feature, you can take continuous screenshots up to 999 shots.
Advanced Features
There are an endless number of advanced features. Customize brightness, contrast and saturation. Sharpen and add noise to your video. Try the audio equalizer. Repeat a section of your video with our A-B Repeat feature. Fast forward/rewind a few seconds using left/right keys. And much more for you to discover!
Pogledaj 3-4 posta iznad 😉
Znam tamo si stavio link za dvb sajt ali je to samo za verziju 1.5.24134,
a kao sto rekoh na linku koji sam dao su update-i za verzije vise ... naprimer trenutno je aktivna verzija 1.5.25231.
Pogledaj razliku tvog i mog linka
tvoj link http://www.dvbsupport.net/download/i...ct=view&id=230
i moj http://www.dvbsupport.net/download/i...ct=view&id=239
mala razlika 😉
na sat-universe ima poslednjih update-a ali zahteva da se korisnik registruje kako bi download-ovao update.
Linkove moras cele kopiras 😉 ne rade
a ovo : pa ni ta tvoja nece valjati kad izadje jos novija verzija 😉 To sam ko primer stavio odakle ima da se skidaju a ne da skine bas tu 😉 ... necu cim izadje nova verzija da postavljam novi link 😉
Ok moja greska za linkove nisam video ... ***...navikao covek na copy/paste...
ceo link http://www.dvbsupport.net/download/index.php?act=view&id=239
... ni netreba da postavljas nove linkove... na ovom linku postavljaju uvek poslednju verziju. Uvek je bas na toj stranici update-ovana (poslednja verzija)....
mada nije ni bitno .... mozda smo mi samo freakovi koji vole uvek najnovije stvari pa nam tako i ovaj potplayer super jer se vrlo cesto update-uje 😀
Kako skloniti prevod koji je u filmu, i staviti-učitati srpski? Probao sam ono klasično: open/subtitles/ selektujem *srt* prevod, ali neće, ostaje ovaj sa atačmenta.
    102.1 KB · Pregleda: 117
I mene interesuje kako se ucitava prevod preko potplayer-a?Pustim film normalno ali ne mogu da ga ucitam kad udjem u opcije.Jedino da ga prevucem iz foldera gde je film ali me to nervira pa ako moze neka pomoc.
ALT + L
pardon, ALT + O je da izaberes prevod, dok je ALT + L sluzi za biranje izmedju vise prevoda...
najlakse ti je da ti prevod i film imaju isto ime, pa ce se automatski pustiti...
Hvala.Sad radi.
Pozdrav.
Uzgred...
U takvim slučajevima, nije loše dodati pozadinu titlu, da bi se još lakše čitalo.
Hvala na sugestiji za pozadinu, ali i dalje ne mogu da učitam u PotPlayer-u *srt* titl preko hardcoded titl-a? Dok kao što sam već rekao u KMPlayer učitava preko njega bez problema.
Jel radi DXVA ( preko graficke)?
Stisneš TAB. Važno je zato što ti je onda rasterećen CPU.
    140.8 KB · Pregleda: 165
Ne koristi DXVA(videti u atačmentu), verovatno zbog male rezolucije filma?, a procesor je opterećen 10%. Verovatno bi opterećenje procesora(E6600) bilo veće da je rezolucija kao kod tebe. Da li se DXVA uključuje "ručno" ili automatski po potrebi?, kad je opterećenje procesora veliko.
    278.6 KB · Pregleda: 108
Ako je ukljucen i namesten decoder preko koga moze dxva pali se uvek..
No to sto ti pustats je verovatno xvid/divx tu i nemoze dxva a i nema potrebe..
Ima u podesavanjima, mislim za rezoluciju vecu od 800x600 (mozda moze i da se promeni), da pusta preko DXVA. E sad, ne znam koji dekoder treba odabrati, mislim da ne moze sa MadVR-om.
