Zašto se PotPlayer ne nalazi na velikim download sajtovima (Softpedia, Download.com, SnapFiles i slični)?
Ogroman broj programa na tim sajtovima je u beta, a ponekad čak i u alpha fazi.Verovatno zato što je još uvek u beta fazi.
GOM Media Player Features
Codec Finder
GOM Player includes many codecs (XviD, DivX, FLV1, AC3, OGG, MP4, H263 and more) so you won't need to install separate codecs for most videos. For those videos that require a separate codec, GOM Player will find one and direct you to a place where you can download an open source version of the codec. That way, you won't get stuck with unnecessary codecs on your system.
Play Broken AVI Files (Patented)
AVI files can't be played if the index is broken, or if the file isn't completely downloaded. This is because the index is located at the end of the file. GOM Player's patented technology enables users to view files with broken indexes or that are still being downloaded.
Powerful Subtitle Support
GOM Player supports SMI, SRT, RT, SUB(with IDX) files for subtitle. You can specify margin, location, size, resolution, font and others. You can also enable shadow, view ASF files with subtitle, karaoke subtitle mode. You can even synchronize subtitle and video if there's any mismatch.
Convenient Playlist
If you run a video file and there is already a file with a similar name in the directory, it will be automatically added to your playlist. GOM Player has a similar playlist format as M3U, PLS, ASX and you can also include and edit different media formats on that playlist as well. It's easy to create and edit your own multimedia playlist with GOM Player.
Support Different Media Types
Along with different media format such as AVI, MPG, MPEG and DAT, GOM Player also supports streaming Windows media format (WMV, ASF, ASX). You can also watch DVD-quality videos with 5.1 channel audio output.
Screen Capture
Screen capture allows you to take a screenshot of your video directly from GOM Player. Using the Burst Capture feature, you can take continuous screenshots up to 999 shots.
Advanced Features
There are an endless number of advanced features. Customize brightness, contrast and saturation. Sharpen and add noise to your video. Try the audio equalizer. Repeat a section of your video with our A-B Repeat feature. Fast forward/rewind a few seconds using left/right keys. And much more for you to discover!
	Pogledaj 3-4 posta iznad![]()
Linkove moras cele kopirasne rade
a ovo : pa ni ta tvoja nece valjati kad izadje jos novija verzijaTo sam ko primer stavio odakle ima da se skidaju a ne da skine bas tu
... necu cim izadje nova verzija da postavljam novi link
Da nije hardcoded titl?
Kod mene nece tako da ucita prevod.Mozda ne radim kako treba.Jedino hoce kad ga iz foldera prevucem.ALT + L
Jel radi DXVA ( preko graficke)?
