Starcraft 2
  • Začetnik teme Začetnik teme Doktor
Version 7.0 Preview:
* Reactive AI. AI will understand different strategies and how to counter them.
* Attack code overhaul. AI will understand which units are good for what and will use them accordingly. For example, if he masses marines and marauders as well as a few reapers, he'll use the reapers to attack your workers while attacking you at the front with MMs.
* Unit logic overhaul. Individual units are now less stupid. SCVs repair damaged buildings and stanks (in the heat of battle 😉 ). Queen uses creep tumors, terran buildings lift off when taking damage from ground units. The list goes on.
* Customizable difficulty. You will now be able to modify the difficulty easily. This won't only be APM changes and mineral bonuses. Setting the AI to easy mode will mean he'll be slower to counter, he might forget to counter, he won't reach saturation as fast, he won't mass as many units. All of these options will be open to the end user.
* Many, many more additions and modifications.
Ako sve ovo odrade bice dobro.
Da li neko zna kada u SC2 Dark Templar ubije radilicu iz udarca, dobija li protivnik onaj mini-map signal i obaveshnjte da je napadnut? U kecu je bilo tako.
Svi koji imaju betu neka provere mail, meni je isto juče stigao još jedan key pa je prosledjen dalje. :smoke:
A šta mislite da radimo svakog dana? 🙁
Čekaj, čekaj... Oni koji VEĆ imaju? A oni koji nemaju ni jedan jedini? 🙁
Baj d vej, pročačkaše mi Battle.net nalog. i R satifactory!
Cek ,cek ovi koji vec igraju betu tj. kojima je SC2 Beta aktivirana na Battle.net accountu su dobili jos jedna beta key .... wtf? sta ono ladno kao dajte friendu ili za rezervu
Evo ovako to izgleda iz first persona 😛
StarCraft® II: Wings of Liberty™ Beta Test – Invite a Friend
Congratulations! This is an additional invitation to the beta test for Blizzard Entertainment’s StarCraft® II: Wings of Liberty™ for you to share with a friend! You are receiving this email because you are currently participating in the StarCraft II beta test, and we want to encourage you to test out some of the social features of the revamped Battle.net® online-gaming service by inviting one of your friends to play with you. This email contains your additional beta key for you to send to a friend, along with instructions to help your friend get started.
c/p prvog dela maila koji je stigao 18 marta. Pozz 🙂)
stvarno su supci, izvinite na izrazu ali tako je :smackbum:.. mislim ima nas koji nismo dobili invite dok oni koji vec imaju privilegiju da igraju online imaju i privilegiju da zovu koga oce na to ebeno testiranje! mislim stvarno nije u redu, neka "namire" nas koji cekamo na prokletu igru vise od 10 god! dodje mi da :wall:
pa ne moraju da znaju,ali red je da se da onima koji cekaju a ne onima koji su vec dobili.. 🙂 iskulirao sam ja nego me malo nerviraju takve stvari...
Pazi nije to lose ... ima dosta ljudi koji su dobili key a neki njihov prijatelj nije pa ... sada stupa na snagu a zasto sluze prijatelji 🙂
Cela penta deljenja ovih ključeva je da se dodate međusobno na friend liste i da komunicirate. Rade na testiranju odredjenih delova bnet-a i to je razlog slanja ovih ključeva ljudima koji imaju već SC2 beta.
Uhh, strpićemo se već.
Nego, nakon uklanjanja " NDA-a ", Heroes of Newerth ključevi su postali dostupni praktično svakom iole zainteresovanom igraču. Potajno se nadam sličnom razvoju situacije... Mada, znajući Blizzard, ne treba očekivati preveliku velikodušnost.
Ali KAKO oni mogu da znaju ko je od vas hard-core ol' school igrac koji nestrpljivo ceka godinama i neko ko je nub u svakom pogledu? Svako moze da slaze da je old-skuler, zato i ne treba da se daje po tom principu.
Desavalo se i na drugom forumu da je lik koji nije ni jednom u zivotu upalio prvi starcraft, a dobio u kljuc vec u drugom krugu.
Pa i nije poenta da igru testiraju samo HC igrači.
Pa ne moraju i ne trebaju da obracaju paznju na to ko je "old skul".. ali to davanje 2 kljuca nekome a nekome nista, smatram da nije uredu. Sad cete reci pa dobro taj kljuc ce nekome ipak otici nece ostati ne iskoriscen ali opet smatram da nije uredi :wave:
Pa to je isti sistem kao pozivnice za vreme Gmail beta perioda. Ne vidim šta je tu toliko čudno.
aj da ne ne skrecemo sa teme puno..ja sam rekao moj neki stav nisam imao nameru da se raspravljam.. 🙂
nije cudno uradili su to da bi isforsirali sto vise testiranje 2vs2, a to ces uvek pre da igras sa prijateljem kojem si dao key 😉
O *** al' ste naporni bre.
Otvorite temu za trolovanje blizzarda pa tamo pljujte, dzizs...
Kao da mi ne znamo kako oni funkcionishu.
Probah... Zerg na Protossa, Blistering Sands. Zergling rush, as usual. 🙂
Čudi me da se nije potrudio da Zealotima blokira uphill entrance, dovoljno je uzak. Loše pozicioniranje jedinica, uopšte.
Edit...
Protoss na Protossa, takođe Blistering Sands. Ovog puta je blokirao uphill entrance, međutim... Zbog lošeg AI-u, lako ih je izvući.
Pa, ako ništa, ova verzija AI-a deluje žilavija.
Bolji je nego 6.1.1 osetno. Pravi raznovrsnije jedinice, vodi detektore sa sobom (barem zerg koliko sam ja primetio), pametnije napada ali i dalje postoji problem, normal/medium kako god, uglavnom najjacha verzija koja ne cheatuje se lako pobedi a cheating komp je neizbalansiran jer nenormalno je da neko ima toliko para. Mozhe da se pobedi ali je glupo. Ako nishta vezhbash mikro.
Jel neko negde citao,cuo,video,itd da ce biti reci o nekom Multi-ju ... meni je AI prelak...a i smara,predvidljiv je.Ipak ne moze se AI ,porediti sa cistim uzivanjem klanja drugog igraca...
Evo ljudi samo da javim, odigrah danas 5 partija, 3 sam dobio a prve 2 izgubio jer sam mislio da ce komp praviti sve linearno kao i ostali AI ali uopshte nije tako. Pravi sve jedinice, nezavisno od rase, techuje, upgraduje sve jedinice, vodi detektore sa sobom, igra raznovrsno, najzanimljiviji i po meni najbolji AI do sada, neki kinez ga kodirao, svaka preporuka. Vredi probati. :wave:
Aaa ,ako je brat kinez radio,onda zaista moram ad probam 😀
hvala na preporuci
