ATI's 5 series refresh on Track for the Second Half of 2010
blackbear
Link
“We are ramping the ATI Radeon HD 5000 series now and look forward to refreshing the entire lineup in the second half of next year” Dirk Meyer
..of next year? koje next year? :)
Evo ti odgovora:
Considering the fact that the call was dedicated to AMD’s financial results in the Q4 of fiscal 2009, the AMD executive referred to the second half of fiscal 2010 as to the “next year”, which is basically the second half of calendar 2010
Po ovome nista od nade da ce Ati imati refresh 5000 serije u trenutku kada nVidia izbaci GF100, kako su se neki nadali.
Pretpostavljam da se pod refresh misli na veci clock i eventualno neki manji upgrade. Jer za sledeci Ati-jev big thing gotovo sigurno se ceka na neki napredniji proizvodni proces, bio to TSMC-ov 28nm koji se ocekuje da staruje krajem godine ili mozda kod GlobalFoundries-a.
Evo jos jedan clanak/izjava koji ide u prilog ovoj pretpostavci:
http://www.xbitlabs.com/news/video/...n_Performance_Leadership_Throughout_2010.html
“I suspect that through 2010 it is possible there will be moments where we don't have the fastest graphics card, but I expect that for the majority of 2010 we’ll have the fastest card you can buy. I have good reason for believing that, but I can't talk about unannounced products or any of the stuff we're doing to secure that,” said Richard Huddy, AMD’s worldwide developer relations manager, in an interview with Bit-tech.net web-site.
Bice mozda nesto iz ove generacije u 28nm, kao test poligon za narednu.
To je veoma verovatno poznajuci politiku Ati-ja poslednjih godina, mada ostaje pitanje da li ce ici na TSMC ili ne.
Tipujem na 32nm GPU za tačno godinu dana.
HD5800 series refresh najverovatnije izlazi dva meseca nakon launch-a Fermija, početkom leta.
32nm je TSMC na kraju otkazao i preskocio, i idu direktno na 28nm, sto je kao prvi proces najavljeno i iz GlobalFoundries-a.
Inace, ovo otkazivanje 32nm procesa je verovatno dodatni problem za NVidiju, mozda su racunali da ce u par meseci po predstavljanju Fermija imati i refresh u naprednom proizvodnom procesu, sto im je sa ovolikim cipom preko potrebno. Ovako je 28nm najmanje godinu dana daleko kada su upotrebljive kolicine u pitanju.
Mislim da cemo u Q4 najkasnije videti 28nm verziju Radeona 5670.
Govorim o Global Foundries-u.
Prezentacija od pre dva meseca - link.
Strana 6. ;)
Da nije u pitanju proizvodnja CPU-ova u 32nm ;) Mislim da ce sledeca generacija GPU-ova biti 28nm.
Piše i CPU i GPU :). Logika kaže da je sledeći step za CPU sa 45nm na 32nm a za GPU sa 40nm na 28nm ali već uveliko eksperimentišu na Fusion-u koji će definitivno biti rađen u 32nm. I dalje mislim da će probati GPU u 32nm.
Da, uopste nije sporno da ce CPU biti u 32nm, a nakon toga na 22nm.
Sto se GPU-a tice, nije naravno nemoguce da probaju 32nm, ali ne vidim preveliku poentu toga. TSMC ce definitivno ici na 28nm, a taj medjukorak bi im onda samo bio gubljenje vremena - ionako bi 28nm bio mesec-dva daleko, a to je daleko dugorocnije resenje.
Mozda Nedjo moze malo svetla da unese, ako ga ne sprecava korporativna politika ;)
pa meni tvoj rezon zaista zvuci logicno.
i obratite paznju da Dirk nigde nije upotrebio New ili Next generation, vec da je covek lepo citav projekat nazvao refresh! Tako da je naslov treda malo pogresan i mozda zbunjujuci.
Pre par sati su se pojavile i prve navodne specifikacije AMD-ovog odgovora na Fermi.
Q3 listing HD6750, 40nm process, the chip area of more than Cypress, less than 400 mm2, still 1600SP/256bit bit wide, divided into two 800SP modules, each of which has an enhanced off Tessellation Unit and a Rasterizer, two modules parallel-oriented graphics. Triangles rate doubled, Tessellation 3-4 times performance improvement. L2 Cache redesigned to significantly improve the performance of GPGPU. Core frequency of 900Mhz-1GHz, TDP of 225 watts or so. Target performance is 10% -20%, GTX480, expectations and GF100 B1 version of its flagship chip, the performance was flat. North Island family, the first product in the maturity process of verifying the new structure.
Q4-Q1 next year, listing HD6670/6650, single 800SP modules / 128bit bit width, Water 28nm process.
Q1-Q2 next year, listing HD6870, 28nm process, four 800SP module, 512bit-bit wide return to core area of 400-450 mm between the target performance of dual-core card Fermi suppression. In fact, R600 is the ultimate form
MCM? Koliko shvatam, u pitanju su dva poboljsana Junipera, samo iz ovog prevoda bas nije jasno kako ce medjusobno biti povezana.
Ne mogu reci da nema logike, jer je te manje cipove daleko lakse proizvesti u realno losem TSMC 40nm procesu.
Ocekujem DX11.1 u specifikacijama da se pojavi kad-tad:)
E jedva cekam...uh ko ce taj dan docekati:d
Ko je čekao Fermija, čekanje mu neće teško pasti :)
Inače, ako su spekulacije tačne, voleo bih da vidim povratak sideport-a kao interconnect-a između modula. Nažalost, zbog smanjenja čipa i potrošnje, sideport je izostao u 5000 seriji.
AMD nastavlja svoj razvoj u pravcu sve veće modularnosti.
Dobro sada, ne preterujmo ;)
Sto se samog nagadjanja tice, vec se odavno spekulisalo da ce se ici ovim tokom, nesto slicno kao kod procesora. "Kinezi" su se bas napogadjali u poslednje vreme, pa ko zna da li su i sa ovim na tragu istine :)
Mozda je ovo i idealan trenutak za ovakav eksperiment, jer imaju dovoljnu prednost na trzistu i dosta prostora da se slobodnije ponasaju, jer je GF100 ispao takav kakav jeste.
Taj Sideport, koliko se secam, nikada nije "aktiviran" kroz drajvere.
Postojala je mogućnost da se oktljuča, čini mi se Asus-ovim hack BIOS-om, ali na žalost nije bio doteran u driverima. Davao je bolje performanse na HD4870x2 ali ju je činio i nestabilnom. Da je sideport-a na HD5970 mislim da bi performanse iste bile još veće.
R600 = 2900 serija sa 512 bita
kao ultimatum se misli da ce izgleda 6xxx serija biti u 512 bita ;)
to je i bio problem prevelike potrosnje i zagrevanja tih serija tada, zar ne? izgleda da su sada uspeli da ga rese. . .ispravite me ako gresim, ako ne ovo sa novijom tehnologijom i proizvodnjom bi trebala biti ubitacna kombinacija :D
Pa ako je verovati ovome, formalno ce biti 512 bita, ali ce verovatno biti podeljeno na 4x128, jer ce se cipovi proizvoditi i slagati kao blokovi... mejnstrim = 1 cip, Performance = 2 cipa, high end = 4 cipa. U tom konceptu je glavna stvar interna logistika, tj komunikacija izmedju ovih cipova. Prednost je mnogo niza cena razvoja tehnologije, a mana... ako omanes u dizajnu, ugasio si za celu generaciju.
Opet, ne hvatajte se previse za ovo, glasina je u pitanju, i dok ne dobijemo potvrdu od nekog iole pouzdanog izvora, kao takvu je treba i tretirati ;)
Sasvim razuman pristup, kao lego kockice, totalno resava problem proizvodnje, samo treba videti(ako bude uopste ovako) kako ce se snaci sa optimizacijom svega ovoga, ja im drzim palceve!
Sideport je na seriji 5800 izbačen ali će u ovom refrešu izgleda da se vrati na velika vrata . Koliko sam shvatio on omogućava da pojedinačna jezgra imaju direktnu komunikaciju međusobno , a žrtvovan je da bi se smanjila površina gpu-a upravo iz razloga što se nikad nije koristio na seriji 4800 . Mislim takođe da ukoliko ati bude radio grafiku po principu slagalice ovako nešto postaje imperativ u smislu optimizacije rada jer npr. neće uvek biti potrebna sva četiri gpu-a .
O MCMu i modularnosti se priča još od rv670. Čudi me, zbog toga, da nije opet spomenut shareni framebuffer :).
Od sideporta su odustali zato što se koristio PLX bridge PCI-E ver. 2.0 koji navodno ima dovoljno bandwitha za komunikaciju među čipovima.
Inače, dosta toga ima smisla: 800sp blokovi, odvojeni rasterizer (što je ATI tvrdio i za rv870), odvojeni teselator ...
Čak i 40nm proces ove godine ima smisla. Znači, nova arhitektura prvo na 40nm, mali derivat na 28nm i onda standardna performance klasa u 28nm Q1/Q2 2011. Malo izvrnuta logika, ali ima smisla. Na taj način bi preskočili testiranje novog procesa na rv8xx derivatima i krenuli direktno na novu arhitekturu. Još više ima smisla kad se uzme da je 40nm proces tek sada sazreo, a pitanje kada će biti spreman 28nm.
No vratimo se u realnost, "refresh" će biti nešto tipa 5890 :).
Jeeeej jos 6 meseci spekulacija o necemu :happy:
Pre će biti 5770x2 , sa sideportom .
