imam plocu 770ta-ud3 rev 1.0 i phenom II 550BE(koji se provereno otkljucava), koja opcija treba da se enabluje da bi sva 4 jezgra proradila?
Skini uputstvo u PDF formatu za tu plocu:
MB Intelligent Tweaker(M.I.T.)
Advanced Clock Calibration
EC Firmware Selection
Allows you to select the EC firmware version when Advanced Clock Calibration is enabled. After the selection, select Save & Exit Setup in the BIOS Main Menu and then press <Y>. A message which says "BIOS Is Updating EC Firmware!!! Don't Turn Off Or Reset System" will appear. Wait for a few seconds and the system will automatically restart for the settings to take effect.
Normal Uses the standard AMD EC firmware version. (Default)
Hybrid Uses the specific AMD EC firmware version. Advanced Clock Calibration
Allows you to determine whether to enable Advanced Clock Calibration when using an AMD Black Edition CPU.
Disabled Disables this function. (Default)
Auto Lets the BIOS to configure the settings to defaults.
All Cores Configures Advanced Clock Calibration for all CPU cores.
Per Core Individually configures Advanced Clock Calibration for each CPU core. Value (All Cores)
This option is configurable only when Advanced Clock Calibration is set to All Cores.
Options are: -12%~+12%. Value (Core 0), Value (Core 1), Value (Core 2), Value (Core 3)
Options are: -12%~+12%. CPU core Control
Allows you to determine whether to manually enable/disable CPU Core 2 and Core 3. Manual allows the two items below to be configurable. Options are: Auto (default), Manual.
Auto Lets the BIOS to enable all CPU cores (number of cores available depends on the CPU being used).
Manual Allows you to individually enable/disable CPU Core 2 and Core 3.
(Note) This item is present only if you install a CPU that supports this feature.
BIOS Setup - 40 -
CPU core 2 (Note)
Enables or disables CPU Core 2. (Default: Enabled) CPU core 3 (Note)
Enables or disables CPU Core 3. (Default: Enabled)
