abgx360 v1.0.2 released!
Changes affecting all platforms:
- Added support for 4th Wave PFI/Video
- Added support for SS v2
- Added the new check for DMI corruption which the database has been using since 2009/06/14
- Added ability to at least try to verify the game data when no Xex/SS ini is available and we're not going to AutoFix
- Added support for Avatar Awards
- Added option to select your preferred language to use when displaying strings from the Xex title resource
- Added drag & drop support for the GUI Input panel
- Added option to embed images in the HTML source code as data URIs for better portability (when using HTML output)
- Added JavaScript to HTML output that allows you to check off achievements and see the achieved text (especially useful when the how-to text is vague)
- Added a Donate button to the GUI so you can help me pay the bills and continue working on improvements
- Removed "Look for verified files in the local folder only" option from the GUI. I can't tell you how many people have checked this box without reading it because they saw it in a tutorial or someone else told them to do it, and then they can't figure out why abgx360 says you need to enable online functions. Please stop writing/following tutorials! Just read the Quickstart topics, the tutorial is right there.
- Checking for updates to GameNameLookup.csv is now optional (the csv was eating 50% of our bandwidth and you probably don't need it anyway since the game name can be retrieved directly from the Xex)
- Fixed a bug where folders would be considered files when parsing the ISO filesystem on some recent games
- Fixed a bug where default.pe (a temporary file used when decompressing a compressed default.xex) wasn't being deleted automatically
- Fixed a bug where unicode code point 160 (no-break space) would be displayed in a CLI window as " ?" instead of " "
- Small changes to the way some messages are displayed (harder to miss)
