Imam problem nece da radi dx10 javi nema dll, jel mora sp1 za vistu ili to zeza gtx260 dx9 radi
Added the option to set the mouse sensitivity.
Added the option to set the dead-zone for a gamepad or joystick.
Added a Ping column in the multiplayer servers list.
Fixed: Saitek X52 Pro crash
Improved the default control mapping for Saitek P990.
Improved the default control mapping for the Thrustmaster Dual Trigger gamepad.
Multiplayer: full servers no longer displayed in the server list.
Fixed: users would not gain a new level in some circumstances when they should have.
Fixed: the game sometimes could not be minimized.
Fixed: the game entered in Windowed Mode if a pop-up from am messaging program appeared.
Fixed: a player could receive two invitations to the same multiplayer match.
Fixed: no error message to players trying to join a full server via an invite.
Fixed: players could not accept invites to multiplayer matches while in certain menus.
Fixed: freeze in the Friend Invite menu after inviting a user with a nickname more than 13 characters long.
Fixed: multiplayer invites did not disappear after being accepted.
Fixed: incorrect name for the host in coop games.
Fixed: the player was unable to join any online multiplayer match after cancelling a Quick Match and then changing between Ranked and Player Match.
Fixed: after the host left a multiplayer match, sometimes the users involved in this match would become unable to find each other's matches.
Fixed the hint for Rotate Camera.
Fixed: buttons overlapping in the Coop menu on LAN.
Fixed: double selection in the profile selection screen.
Fixed: crash when the player applied a profile created on a partition other than the primary one, on Windows Vista.
Fixed: crash when using an Xbox 360 controller and quickly pressing A after entering the options menu.
Fixed: starting the game with CAPS LOCK on caused an input issue.
Fixed several Spanish localization issues.
Fixed: not all French characters were recognized.
Fixed: stuttering and visual artifacts on Nvidia cards when using Vista, the DX10 executable and certain settings.
Fixed: the game window did not maximize correctly when using Vista and the DX10 executable.
Fixed: mission 15 (Operation Thunderbolt) could become impossible to complete when loading from the last checkpoint.
Fixed: crash to desktop if the user tried to join a Ranked Match in certain conditions
Fixed: often, selecting Quick Match lead to creating a new server, even though servers with good latency and available slots existed.
Fixed: if the user hosted a Ranked Match and then quit it and tried to join another Ranked Match, he would end up in an unending loading screen.
Fixed: if the user joined a Player Match using the Quick Match option, then quit and tried to join a Ranked Match also by using the Quick Match option, he would end up in an unending “please wait” screen.
Fixed: the screen went black at game start-up on certain configurations.
Fixed: the game crashed often on laptops using certain ATI video cards.
Fixed: if the user pressed the “Host Session” button too quickly after selecting Custom Match, he would end up in an unending “please wait” screen.
Fixed: players sometimes were unable to accept game invites.
Fixed: the game crashed on Windows 7 Beta when the player tried to create a profile.
Performance has been optimized for Pixel Shader 3.0 videocards running DirectX 9.
jel zna neko kako da pređem (mislim da je to)21 nivo to je ono kad treba neke električne stubove da pogodite da bi nestao onaj zaštitni crveni štit ima tri štita i podvučem se pod štit i uništim električne stubove i na kraju radar e sad sve ja to odradim i kad ih sve pogodim ostane mi samo gola mapa nigde nijedna meta
jel to ima bag igrica ili neki fazon treba da se odradi?
ima tu i neka baza na sredini mape ali što god radio oko nje nevredi,probao i da sletim i rokao po njoj ali ništa se ne dešava
unapred zahvalan na odgovoru.
Ma ja igram iz zadovoljstva, misije odavno završene, odrađujem chalenge-e, vežbam gađanje sa raznim oruđima, šteta što nema više mapa.
Tek kad mi ovo sve dosadi, onda cheat![]()
E pa ovo stvarno nije u redu.... sad moram da kupujem džojstik!!!![]()
ehhh što nije ovo izašlo u januaru da se ko čovek zabodem kući i izližem hard od igranja...ovako prosto greota napolju lepo vreme a unutra prosta milina uz ovo čudo cccc
Ima bugova ali da se podneti![]()
Kako preci onu misiju kad treba zastititi predsednika!!! milion aviona i svaki put dodjem do pola i sjebu ga!
Da li imaju još neki serveri za on line a da nije garena?
Ne moj previse da se odaljavas od aviona predsednika i stalno pritiskaj dugme (1) da tvoji wingmeni takdje napadaju neprijateljske avione a ne da ti brane ledja.Za rakete uzmi avion sa RGM,Multi AA i AAspect raketama,tako ih sa RGM zdrndas dok su daleko,sa Multi kad su an pola puta a sa AAspect kad su oko tebe i predsednickog aviona u blizini.
mozes da igras preko hamacija,ili da kupis igru ,ali vidim da se ovi s originalima bune da im ne rade original serveri pa i oni sljakaju preko garene/hamacija
Ps-ja sma malo kreno da radim na menjanju skinova aviona,za pocetak je to stavljanje nasih oznaka,oznaka hawxa ,pa da vidim neki klan da oformim pa na rep da stavim neku znacku,trenutno sam u radu na 2 skina ,jedan za mig 29 drugi za su47,ako nekog interesuje nek poseti moji xf ili evo linkova
http://screenshot.xfire.com/screenshot/natural/fdf1f5082767ecc7783684103777ad268130f494.png
http://screenshot.xfire.com/screenshot/natural/fe13dbfe8201119646560d1fdc183808c138a29c.png
Kamuflaze mi s esvidjaju na 29ci tako da mislim d anju necu dirati ubuduce
SJAJNO!!! računaj mene u eskadrili....i dajte IP za hamachi!Ufff jedva čekam da dođem iznad 20 lvl da napakujem malo boljih raketica
...sad sam mali
pa me ace-ovi namirišu sa većih daljina
Top nije loš ali teško je naciljati sa njim mada malo vežbe i ...
Radi se polako na unapredjenu postojecih skinova ,za 29ku sam zavrsio ima an XF profilu,naravno svaka kritika i predlog je dobro dosao,kad budem imao jos vremena videcu da uradim vecinu aviona,a i da navatam neku dobru kamuflazu pa da je stavim mesto postojecih skinova
A za eskadrilu sam mislio da uzmem ime vitezovi u njihovu cast mada ima i drugih dobrih eskadrila pa mozda na predlog kolege markonija ime klana bude SAF
Evo ti SU35 skin,neko je vec napravio takav(doduse sa par strafta u odnosu an tvoju sliku):Meni je ova shema naj...Ta Slovacka isuvise vuce na NATO trend i njihov digital.Mada fino izgleda svakako.
Pogledajte prilog 48660Pogledajte prilog 48661
Ne znam kako su to uspeli...fajlovi unutar .pak datoteka (dds-ovi) su zasticeni lozinkom.Zanimljivo![]()
