Nehalem
P ploce ce biti za 1366 socket i i7. Ne znam koji je RM leakovan, niti sam ga video.
Konacno jedan pravi ekslkuzivnii info od tebe ;) (ako je neko negde vec video ovo za "P" i LAG1366, neka me ispravi)
jel to znaci da ce ploce sa "P" chipsetom biti DualChannel, obzirom da je sustina "problema" oko 6/8 slojnih ploca zapravo u ocuvanju integriteta signala ka/od memorije?
To je logicni zakljucak zasto ce im trebati 6-8 slojeva stampe. To ne mora da se procita na netu da bi znao. ;)
Intel Core i7 Extreme Edition i7-965(3.2GHz,8MB L2, LGA1366, Product Code BX80601965 & QPI 6.4GT/sec) Estimated Price in EU : ~1000€
Intel Core i7-940(2.93GHz,8MB L2, LGA1366, Product Code BX80601940 & QPI 4.8GT/sec) Estimated Price in EU : ~510€
Intel Core i7-920 (2.66GHz,8MB L2, LGA1366, Product Code BX80601940 & QPI 4.8GT/sec) Estimated Price in EU : ~260€
While some companies are already out there promising Core i7-based gear, we haven't yet heard many official specifics about the actual processors that'll be at the heart of them (at least not since their earlier Nehelem days). That's now changed in a pretty big way, however, with some supposedly authentic leaked materials revealing the complete spec list and some pricing details. Apparently, you can expect Core i7 920, 940 and 965 models to roll out in November, with 'em clocking in at 2.66GHz, 2.93GHz, and 3.2GHz, respectively. Each, as expected, are quad-core, 45nm processors, and each boast the same 8MB of shared L3 cache, 256kb of L2 cache per core, and TDP rating of 130W. No word on individual unit pricing just yet, but it looks like the Core i7 920 will run $284 in quantities of 1,000, with Core i7 940 upping things considerably to $562, and the "extreme" Core i7 965 demanding a hefty $999.
http://www.engadget.com/2008/09/17/purported-intel-core-i7-details-leak-out-920-940-and-965-model/
sto oznake neodoljivo podsecaju na Penium D procesore...
Po poslednjim informacijama NF200 jos uvek nije EOL i u upotrebi je.
Kao sto se vidi MSI ima 3 modela na X58 cipsetu, i
svi modeli imaju SLI+CF.
    195.9 KB · Pregleda: 1,096
evo ga Nehalem wafer...
    79.2 KB · Pregleda: 100
    67 KB · Pregleda: 99
Koga zanima vafer kada je procesor vec spreman :)
    195.6 KB · Pregleda: 106
    417.9 KB · Pregleda: 86
    129 KB · Pregleda: 117
    243.7 KB · Pregleda: 131
Joj, kako me samo oduševljava ona četvrta slika. :S: Način montaže coolera ostaje isti. Da li je moguće da ne žele da promene i olakšaju način montaže coolera? :wall:
Ne vidim sta fali sadasnjem montiranju ? :trust:
@delimir
ajd sta si se stisao :D:D reci nesto barem spi da vidimo rar bilo kakvu glupost u da spi je glupost :D:D:D
nego mogli bi da probamo pod vodom sta kaze :-devil-:
Funkcionalno ništa, odlično drži cooler na mestu. Ali što se jednostavnosti tiče dosta, ako si nekada montirao cooler na neki od novijih AMD procesora onda znaš o čemu pričam.
Inače, skoro me je Intelov "pristup" debelo namučio i iznervirao. Kada sam čistio računar, skinuo sam da očistim i CM TX2. Kasnije sam pokušao da ga vratim, ali posle frustrirajućih 10 minuta neuspešnih pokušaja na kraju sam vratio Intelov stock cooler, jer su na njemu pinovi već "razrađeni", a i malo bolje izliveni pa ga je bilo daleko lakše namestiti.
ja sam se hyperTX-om mucio samo prvi put i nikad vise, svaki sledeci put sam ga montirao za 20sec
DDR3 2000 possible with Core i7 Nehalems
We've learned that if you combine the top Asus X58 motherboard, put some overclocking effort into it and use some of the upcoming DDR3 triple channel memory, you should end up with up to DDR3 2000 speeds.
Companies such as Corsair are currently investigating Nehalem's top memory speed and it looks like they should be able to launch DDR3 1866MHz in triple channel kits. Some modules will run at DDR3 2000 but we believe that Corsair will initially launch DDR3 1866 and go for higher speeds later.
As Intel officially certified DDR3 1066 only, this will be pure overclocking, but at least it will give you some decent memory speed. Triple channel fast DDR3 memory from Corsair and other memory partners will launch with Nehalem, so you can expect it in November time.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9596&Itemid=36
Uglavnom, na proizvodjacima ploca je da odluce koje ce memorijske "standarde" implementirati, a Intel zvanicno deklarise DDR3-1066 support.
Industrija maticnih ploca je pocela da posluje kao automobilska industrija -- ima gomila modela kod kojih se razlikuje kozmetika, a motor je jedan te isti vec godinama.
To sam i ja kucao ovde od pre jedno 3 godine.Nista novo a boljitak se ogledao u overclocking potencijalu.Zato @Dark preskace Nehalem u 2008 i 2009 i ostaje na dq6 i q9450 .
A videcete tek koliko ce izmena pretrpeti ploce za Nehalem.Izlazice kao stripovi revizije chipseta:D Posebno mislim na novost integrisanog mem.kontrolera.Ovde ce biti eksperimentisanja i izvlacenja "masimuma" od strane prozivodjaca ploca.
Ako neko zeli da kupi dobru konfiguraciju treba da saceka kraj jedne linije Socketa i chip seta.Potom , kupi poslednju plocu na kojoj su ispravljeni svi bug-ovi i uziva.Kao npr. q9450 i neka od Asus ili Gb ploca.Novotarije su uvek pune bagova i preskupe su.Moje predvidjanje je da ce ploce vredeti za kupovinu ,kad je Nehalem u pitanju,tek krajem 2009 godine.No videcemo.
Evo da dodam u ovaj thread posto se onaj o Sandy Bridge negde zaturio -- AVX ekstenzije koje donosi Sandy Bridge nece sadrzavati FMA instrukciju vec ce to biti posebna funkcionalnost koju ce doneti sledeca generacija procesora. Ja sam se bas iznervirao kad sam to cuo, a verujem da ce i mnogi drugi developeri (kovacm ce sad da se smeje).
Opa!!!
Intel je zesce zabrljao sa integrisanim memorijskim kontrolerom!!!
WE GOT WORD that Intel is adivising mobo-makers and memory vendors alike about their new X58+Core i7 combo and to abide to a strict 1.65V limit on memory voltages, beyond which there is the risk of burning out the CPU.
Read more...
uuu, i am so scared :)
Mislim, na gomili ploca pise: "Overclock may permanently damage your CPU" ili na svakom box procesoru pise: "This product is intended to be professionally installed", pa ga instalira kako ko stigne. Proizvodjac se mora ograditi i utrapiti tebi rizik, ako nesto izgori, a setovao si ga iznad limita.
Znaci, videli su nalepnicu (posto nema varijante da uklavire sta pise u threadu, jer je sve na kineskom) i skleptali vest, a ti preneo kao da je Intel zabrljao sa memorijskim kontrolerom...
Na nalepnici se spominje 1.65, ASUS im je, kao, potrvdio da je limit 1.7, a Muskin da redizajniraju module kako bi ih ponudili u tri-channel packovima (verovatno nove kutijice u koje mogu da stanu odgovarajuci setovi modula i stikeri na njima).
Naravno, i overklokom mozes da spalis procesor to nije nista novo, a uskoro cemo videti kako to sve radi :)
Pa i ne mora da znaci :).Ako se do kraja godine pojave low volt DDR3 memorije sa razumnom cenom,ovo i nece biti veliki problem.Ovaj limit od 1.65V bi mogao da bude i problem koji proces proizvodnje(high k/mg) ima sa naponima preko te vrednosti.
Zbog ovoga je intel i podrzao samo 800/1066 standard,jer moduli deklarisani na te frekv. rade sa nizim naponima.Uskoro cemo i saznati koliki je ovo problem kad neki extremni likovi pocnu da se s'igraju sa nezdravim podesavanjima u biosu i pocnu da moduju ploce :)
@delimir:
Sasvim ocekivan off-topic od tebe. :trust:
Nije sustina u ogradjivanju proizvodjaca!
Rec je o tome da u prodaji ima "legitimnih" DDR3 modula koji zahtevaju i do 2.1V da bi radili na deklarisanim frekvencijama.
Te module ne kupuju samo overclockeri vec i "entuzijasti" i korisnici koji zele maksimalne performanse, a koji ne zele da rizikuju overklokovanje sporijih modula.
Sa kontrolerom u chipsetu (X38/X48) do sada je mogao bilo koji DDR3 napon da ide, ovde je limit 1.65V sto drasticno ogranicava memorijske taktove.
Po mom misljenju realan rizik postoji -- ko god sada koristi d0m1n4t0r module na 2.1V na X48 ploci, zadrzace memoriju, kupice X58 i Nehalem i tras -- ode mu CPU.
Zasto? Zato sto je Intel zabrljao. Eksterni memorijski kontroler je bio tolerantan na visok Vddr, integrisani nije i tacka.
Secam se svojevremeno dok sam imao AMD Athlon 64 (Socket 939) da je postajao fazon da posle odredjene granice za vDIMM mora da se digne CPU napon da bi memoriji mogao da se da visi napon. Ocigledno se radi o istom problemu sa integrisanim memorijskim kontrolerom. Doduse tada su naponi bili bas extremni, pogotovo za Winbonde BH-5 i BH-6...
zbog cega bih se smejao? ...(moram da proverim... ;))
hm, zato sto Power6 to ima od juna ove godine? pa i nije neko kasnjenje intela...
osim sto Haswell po wikipediji (koji ce biti "first Intel CPU to implement FMA") treba da se pojavi 2012!?! :D
kako si znao da cu da se smejem? :)
EDIT: evo gledam da je FMA deo originalnog AltiVec-a iz 1999.
Bas sam pre dva,tri dana video ovu vest i razocarao se malo.mada opet videcemo u skorije vreme tacno kako ce to sve biti.
