Msi N260gtx-t2d896-oc
Komentar ti je skroz na mestu, respekt :)
Eto nama X58-ce uskoro i problem resen :) za 1k Evra :d
:wave:
Ne znam da li si ti primetio koliko je lakse nabaviti dobru CF plocu od dobre SLI ploce. Nije ti palo na pamet da ljudi teraju CF zbog ploce koju vec imaju a ne da bi dokazali to o cemu ti pricas.
Dobra SLI ploca ne postoji, tako da to nije problem.
Da se vratimo na temu, a to je 260GTX ;)
Uporedjivo sam malo rezultate sa Paradigmom (4870X2) i posto je covek testirao Crysis i u 1680x1050 sa ukljucenih 8xAA, sto meni koji ga do sad nisam ni ukljucivao nije padalo na pamet, resih da provrtim test pa da vidim gde sam. Iznenadjenje sledi....
19.8.2008 20:36:16 - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1680x1050, AA=8x, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 54.46s, Average FPS: 36.73
Min FPS: 20.64 at frame 152, Max FPS: 47.30 at frame 990
Average Tri/Sec: -34520024, Tri/Frame: -939905
Recorded/Played Tris ratio: -0.98
!TimeDemo Run 1 Finished.
Play Time: 50.90s, Average FPS: 39.30
Min FPS: 20.64 at frame 152, Max FPS: 49.42 at frame 1009
Average Tri/Sec: -36445972, Tri/Frame: -927485
Recorded/Played Tris ratio: -0.99
!TimeDemo Run 2 Finished.
Play Time: 50.89s, Average FPS: 39.30
Average Tri/Sec: -36428256, Tri/Frame: -926956
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1680x1050 AA=8x, 32 bit test, Quality: High ~~ Overall Average FPS: 3930
Prosecan framerate je nizi u odnosu na 1680x1050 4xAA mizernih 2fps?!??!
Ajde provrti Assault Harbor sa high to very high modom u 8XAA (podesi filter u testu) + 8XAF, tu HD4870x2 ima 34 avg fps ;) u rezoluciji 1680x1050 :) Overklokovani GTX280 33 avg fps, a O/C single HD4870 28 avg fps
Mala opaska: Ti nisi pokrenuo test iz batch fajla vec iz Crysis benchmark tool-a i nije uporedivo, cisto da znas da je razlika u rezultatima izzmedju ta dva testa ogromna!
:wave:
:wave:
Hmm vec vidim kako zovem jos jedan GTX260 u pomoc :D Salu na stranu, evo izvrteo sam Assault Harbor HIGH, 1680x1050 8xAA opet iz Crysis benchmark tool-a. Sa onim very high modom mislim da bi mi framerate otisao u minus :p Ajde molim te okaci mi taj cfg za very high pa cu i to da pustim pa da okacim ovde. Za sada samo ono sto sam gore boldovao
19.8.2008 21:12:57 - XP
Beginning Run #1 on Map-harbor, Demo-Assault_Harbor
Demo Loops=4, Time Of Day= 5
TimeDemo Play Started , (Total Frames: 4100, Recorded Time: 132.23s)
Play Time: 125.29s, Average FPS: 32.72
Min FPS: 22.31 at frame 2895, Max FPS: 47.50 at frame 3244
Average Tri/Sec: 8570424, Tri/Frame: 261901
Recorded/Played Tris ratio: 0.05
Play Time: 117.61s, Average FPS: 34.86
Average Tri/Sec: 7924596, Tri/Frame: 227321
Recorded/Played Tris ratio: 0.06
Play Time: 118.82s, Average FPS: 34.51
Min FPS: 18.60 at frame 2979, Max FPS: 49.94 at frame 986
Average Tri/Sec: 7938989, Tri/Frame: 230067
!TimeDemo Run 3 Finished.
Play Time: 118.27s, Average FPS: 34.66
Average Tri/Sec: 7991110, Tri/Frame: 230523
TimeDemo Play Ended, (4 Runs Performed)
Completed All Tests
Run #1- DX9 1680x1050 AA=8x, 32 bit test, Quality: High ~~ Overall Average FPS: 34.676666666666666666666666667
Zaboravih, patch 1.21 :d Mada si mogao iz batch fajla da pustis, cisto usporedbe radi :)
Evo ti probaj i extreme quality, kada vec imas snage, neka bude igra sa uzivanjem :)
:wave:
1680x1050 8xAA 8xAF (forsirano iz drajvera) high to very high cfg Assault Harbour
Run #1- DX9 1680x1050 AA=8x, 32 bit test, Quality: High ~~ Overall Average FPS: 22.596666666666666666666666667
1680x1050 8xAA high to very high cfg Assault Harbour
Run #1- DX9 1680x1050 AA=8x, 32 bit test, Quality: High ~~ Overall Average FPS: 25.003333333333333333333333333
1680x1050 extreme quality benchmark gpu
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 30.735
Evo ti rezultati koje imam sa HD4870 na defaultu :)
Gledajuci sa leva na desno:
zuto-NOAA NOAF
crveno- 8XAA, iz drajvera forsirano 8XAF
plavo-16XAA, iz drajvera forsirano 16XAF
zeleno-16QXAA, iz drajvera forsirano 16XAF
rezolucija 1680 x 1050, patch 1.21, quad core @3400MHz, ista mapa kao kod tebe, quality takodje na high :)
:wave:
!!! I sta sad? Pa nemoj sad da ispadne gtx260 bolja od ljubljenog 4870.Ne ide to tako.Ima da vrtimo testove dok se ne poonesvescujemo ...
Zasto hate, samo sam napravio digresiju na njegovu uspredbu i ne dobije se iskrivljen utisak :)
Na zalost nemamo svi sanse da probamo sav HW.
Gde sam ja napao ili rekao da nV GT200 ne valja?
Ponavljam samo sam zamolio da testovi budu u istim uslovima odradjeni :)
:wave:
zuto-NOAA NOAF
:wave:
hmm cekaj jel high ili high to very high? ono gore je sto sam postovao je very high i extreme :trust:
Ovo dole je 1680x1050 high Assault Harbour
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 45.57
pozz
:wave:
Vidim ja da je tebi malo kartica na onom testu koji spremas, fali ti jedna 260GTX pa si bacio oko na ovu :p
Pogubismo se u high, very high to mega giga ultra high podesavanjima i opet nismo uboli ista da izvrtimo testove i uporedimo rezultate :D
:wave:
Taman posla da bude hate.Shvatam sve ovo kao zezanje.Ne daj Boze da mi je
primarna stvar u zivotu hw.Ispalo mi je simpa, svi zevamo u u testove a vecinu nas
nema kuce za sta da ujede (cast uvazenim pojedincima).Da sam na zapadu, radeci
ovo sto radim ne bih gledao testove nego bi bilo bacanja para na gluposti.
Nek' smo svi mi i zivi i zdravi, nemojte da preozbiljno shvatamo sve ovo.Najbitnije je da se druzimo.:wave:
pozz
High to very high!
Extreme nemam ubelezeno na zalost, isti sam ti dao jer lepo izgleda :)
Uzeo si super kartu, uzivaj u njoj :)
:wave:
@Player ne bi bilo lose da ako mozes dodjes sa Dominatorom do mene, na zalost nemam GTX260 :( a karta zaista privlaci paznju :)
:wave:
Tako bwe cika Vlajjo cheers :)
:wave:
Reko da stavim i ja rezultate.
Upitanju je Asus GTX260 TOP 650/1400/1150,kloknuta na 750/1500/1300
3DMark 06
  • ScreenShot001.rar
    375 KB · Pregleda: 76
Pre GTX260 sam imao cuvenu 4850:p i rekao sam da sam zadovoljan.Sada sam jos zadovoljniji:D
3DMark Vantage mi je uvek pucao pri 750/1500/1300 mislim da je zbog kloka sejdera,a Asusov SmartDoctor mi uvek povecava sam klok sejdera kada povecam za core,pa je test zavrsen sa 726/1452/1300
Hvala Vinko
:wave:
  • ScreenShot002.rar
    740.3 KB · Pregleda: 51
Ljudi, neka mi neko za 5 minuta na private posalje gde moze da se uzme MSI 260GTX. Hitno mi je!!!
A Riva Tuner neradi na 200GTX seriji ??
Riva radi ali samo mogu da menjam brzinu ventilatora:d.Kada promenim klokove,uvek vraca na pocetne vrednosti:wall:
Nisam ni znao za njihov programcic.Evo upravo ga skidam pa ce vidimo;)
tnx
:wave:
Ja ne znam sta se to desava,nikako ne mogu da podesavam odvojeno klok za core od sejdera.Naime preko eVGA Precision ako namestim klok za core 750,za sejdere nikako nece da spusti ispod 1500:S:.A ako prvo namestim sejdere na 1450 klok za core nece preko 725:mad: Slicno mi se i desavalo na Asusovom SmartDoctor-u
:wave:
odnos kloka jezgra i sejdera kod GTX2x0 serija kartica mora biti manji ili jednak od 2
Ne postoji mogucnost da se zaobidje nikako jer je u pitanju sama arhitektura jezgra!
@Boombastic
Ako hoces 750Mhz za core moraces i 1500Mhz min za sejdere...
A u tom zecu cuci zbun:D
Vidim da necu moci da drzim 750 za core:wall:
:wave:
Jel' probao neko da podigne napon GPU-a preko Bios sa 1.12->1.18V ?
Ima li smisla ?
SuFox
