1.09 HIGHLIGHTS - MAIN NEW IMPROVEMENTS AND FIXES
* significantly smoother gameplay on Northern part of Sahrani (up to 100% increase in frame rate depending on scene, video settings and graphics card)
* combat AI improvements
* voice over net and multiplayer related fixes and improvements
* new anti cheating methods in multiplayer (including optional
www.BattlEye.com depending on server settings: if enabled, be server and be client dlls will be used and automatically updated to your computer)
* fixed compatibility problems caused by various copy protections used
* fog is rendered correctly on DX10 generation cards
* new scripting functions (string manipulation, multiplayer synchronization)
KNOWN ISSUES
* occasional BSOD in multiplayer using VOIP with some SoundBlaster cards (this problem was present also in all previous version of ArmA including 1.08 but due to limited use of VOIP it wasn't real issue). Known work around is to disable hardware acceleration in ArmA audio options.
* BE server protection doesn't work
* Patch can't be installed if you have beta folder with version 1.07 present:you need to remove beta folder in case you have 1.07 beta folder present in order to install this patch.......
