GeForce GTX 280
starac
GeForce GTX 280 got 7k+ in 3DMark Vantage Extreme Test - http://www.pczilla.net/en/post/11.html
We learn from pcinlife forum that GeForce GTX 280 graphics card can get 7k+ scores in 3DMark Vantage Extreme test, double the score of 9800GX2 in 3DMark Vantage Extreme test. But now we still don’t know the specification of the test hardware and software configurations.
We learn that GeForce GTX 280 graphics card is equipped with 512-bit 1GB DDR3 video memory; it has 240 stream processors with 250W power consumption. GeForce GTX 280 graphics card uses dual slot cooling fan,
We also heard there’s no problem for GeForce GTX 280 graphics card to run 1920x1200 with AA and AF in Crysis.
Nadam se da je ovo tacno? Nece Kriza vise trzati :)
Iskreno, sumnjam u ovo. Preveliki su dobici.
Power consumption bolje da ne komentarišem.
Da nije malo mnogo? :) Brze nego 3-way SLI sa tri Ultre! U svakom slucaju bilo bi lepo.
Mnogo je, ali nije neostvarljivo. Vidjeli ste sta radi 9600GT jezgro. A i treba opravdati toliki power consumption.
Isti izvor navodi kako je R700 sporiji od GTX280!
R700 lost battle to GTX 280?
We learn from pcinlife forum that ATI next generation flagship R700 lost battle to GTX 280 in closed doors tests.
Taiwan graphics cards manufacture obviously got both 4870x2 and GTX 280 graphics card samples for these comparisons. But as we told you before, we still don't know the specification of the test hardware and software configurations.
We hope ATI Catalyst Develop Team could do miracle to save Radeon HD 4870x2 in next gorgeous chips battle between AMD and NVIDIA.
Zasto je to cudno? Pa i 8800gtx je bio dosta brzi od 7950gx2 kad se pojavio. I svi su se kao prijatno iznenadili. Mene to ne iznenadjuje, posto nvidia nije izbacila novi proizvod 19-20 meseci. Ne verujem da su sedeli skrstenih ruku i cekali da im konkurencija preuzme tron.
GTX 280 fotke.
http://www.tgdaily.com/content/view/37554/135/
Ono sto je Nedjo spomenuo za povrsinu jezgra je izgleda tacno - 576mm2 !!!!
Samo mi nije jasno kako su dosli do 0,9-1,1 milijarde tranzistora. Sa tolikom povrsinom u 65nm morao bi imati preko 1,3 milijarde.
neko je negde bio pomenuo cifru od 1.2 ili bese 1.3... moguce je da bi to bila finalna cifra da je NVIO integrisan, ali bi GPU bio preko abnormalnih 600 mm^2
Da,ali nevezano da li je NVIO integrisan u GPU ili ne,ako je povrsina jezgra 576mm2,onda je ono za 77% vece od G92 jezgra koje je isto izradjeno u 65nm,sto znaci da bi moralo da ima za isto toliko procenata vise tranzistora,dakle preko 1,3 milijarde.
Evo mozda i potvrde za broj tranzistora:
http://www.hardware-infos.com/news.php?news=2078
Pise 80 TMU jedinica,znaci ovde
http://www.benchmark.co.yu/forum/showpost.php?p=1427687&postcount=13
bih trebao da iskorigujem broj TMU jednica po jednom bloku od 24 SP jedinica - naime izgleda da nVidia nije dodavala vise TMU jedinica po bloku shadera vec je samo dodala dva bloka vise pa je broj TMU-a porasao sa 64 na 80. Sto je sasvim realno, jer je jasno da broj TMU jedinica nije predstavljao bottleneck kod G80/G92.
EDIT:takodje se spominje ~1100 FLOPS,sto znaci da bi frekvencije GPU-a mogle da iznose 650/1625Mhz.Bice ovo pravi monstrum.
GT200 has 1.4 billion transistors inside, sell for $600+
We learned from PCINLIFE Forum, NVIDIA next-generation flagship product, GT200 has 1.4 billion transistors inside. The floating-point computing power of GT200 reaches to 900 + GFLOPS.
Based on the GT200 structure, the retail price of GeForce GTX 280 graphics card will be 600 + dollars.
Cena ce takodje biti sitnica :)
Ali tako nesto se i ocekivalo,ovo ne samo da ce biti monstrum od graficke kartice vec i vise od toga: PhysX ready,CUDA technology...
Šest stotina... Jaoj... Koliko je beše koštao 8800GTX kada se pojavio?
Uhh.. ovo je bas zwer!
Polako ali sigurno NVidia povecava razmak u performansama...
7000 markova u Vantege-u na extreme settings.Inace 3-way SLI sa ULTRAma daje oko 6000.Naravno ovo je samo rumour :)
Pa realno kad pogledamo, znate kolika je bila razlika izmedju 8800gtx-a i ostalih "u klasi" kartica ;) Ista prica i sa GTX 2xx serijom ;) Veliki GPU i NVIO cip izdvojen ;) Savrseni naslednik 8800GTX-a ;)
sve je to lepo, ali ce otpadati usi od cene. mada sa 2. strane, takva karta ne moze da se pokloni...
Pa da, od tih 600e samo ventilator kosta 400e jerbo ne sme da otkaze :d
Slaba ti graficka, Audio, mogo bi malo da se obnovis sa nekom tazijom :)
Pa jasno je da ce ovu karticu retko ko kupiti kod nas,mada kapiram da ce se u svetu dobro prodavati uprkos ceni jer dosta ljudi ceka najjacu karticu.
Ali opet,veoma je vazno da je barem nVidia ostala da gura napred sa performansama u high-end segmentu jer za godinu dana ce izaci smanjena i pojednostavljena verzija ovakvog GPU-a za nekih 200 evra :)
znaci da treba da mrcvarimo 8800GT jos godinu dana :( :D
I na kraju ih prodamo za cca `50 jura :D
