SMOS 1.3 se radi, ima li neko neku sugestiju pre nego što se završi?
Ima li negde sta je novo u 1.3?
Da li je moguce podesiti da grafike kopaju npr. Ltc a procesor neki cpu coin?
Jasno. Pada mi na pamet sledece ukoliko je naravno izvodljivo:
Eksportujes onaj backup fajl sa podesavanjima rutera i vratis nazad kad ruter padne. Trebalo bi da cuva i mac tabele a obicno traje 1 minut koliko treba da se restartuje nakon ucitavanja backup konfiguracije.... Shvatas na sta mislim?
Moze li neko kratko upustvo kako to uraditi, za pocetnike koji nemaju iskustva sa linux - om?
Nisam uspeo nista korisno o ovome da nadjem a mislim da nije lose da se i procesor iskoristi kad vec moze..
Ok. Hvala na odgovoru..
git clone [url]https://github.com/pooler/cpuminer[/url]
cd cpuminer
./autogen.sh
./configure CFLAGS="-O3"
make
Ima li neko nešto da doda? Još sutra primam sugestije. Večeras ostaje da se vidi stabilnost.
Pogledajte prilog 133771
Pogledajte prilog 133772
Evo dve slike dole.
- Catalyst
1. Laste version installed - Catalyst 13.12
- Web Status
1. Added SMOS Logo
2. Security protect added (default password:donate)
-2.1 Access just via password - To turn off status password, just delete password from file passowrd.txt
-2.1.1 File is placed on home folder. /home/password.txt
-2.2 Access via IP - You can add IP in list.txt, and someone can access to see your status without password. When you login, he cant access anymore.
-2.2.1 File is placed on home folder. /home/list.txt
3. Restart rig from status (green) - sleeps for 10 second, then restart rig
4. Shutdown rig from status (red) - sleeps for 10 secound, then shutdown rig
5. Added logout in web status. - When you logout, nobady cant access to your web status.
6. Some color changed, and images.
- Mgpumon
1. Fixed port to 8080 when you try to join on some of your rigs.
- Gpumon
1. Changed text under speed on gpumon Mhs to Khs, it wasnt correct.
- Kernel flag
1. It was on tips from december, but now its by default. Problem with freez, boot sloved. And you can boot more than 5 cards (if your moatherboard support it)
- Cgminer-3.7.2-kalroth and sgminer 4.0.0
Cgminer kalroth, and sgminer isnt installed by default.
You need to install it manuel.
Cgminer 3.7.2 is default version. This two version is for r9.
1. Cgminer-3.7.2-kalroth - Its placed in /root/mining/cgminer-3.7.2-kalroth, and you just need to run scritp to change your cgminer with this.
-1.1 to change it just type /root/smos/mining/cgminer-3.7.2-kalroth/kal.sh
2. Sgminer - Its placed in /root/mining/sgminer, and you just need to run scritp to change your cgminer with this.
-2.1 to change it just type /root/smos/mining/sgminer/sgminer.sh
- Network
1. Network manager installed
2. Network manager gnome installed
3. In folder /root/smos/network/ we added drivers for next cards. Now you dont need to transfer it on your RIG. Just to install it.
e1000e
e2200
e2205
e220X
AR8161 Gigabit Ethernet
AR8162 Fast Ethernet
QCA8171 Gigabit Ethernet
QCA8172 Fast Ethernet
AR8131 Gigabit Ethernet
AR8132 Fast Ethernet
AR8152 v2.0 Fast Ethernet
AR8152 v1.1 Fast Ethernet
AR8151 v1.0 Gigabit Ethernet
AR8151 v2.0 Gigabit Ethernet
Look list of compat drivers - http://www.smos-linux.org/list
Kod:git clone [url]https://github.com/pooler/cpuminer[/url] cd cpuminer ./autogen.sh ./configure CFLAGS="-O3" make
sta dalje uraditi? kako se pokerce iz smosa?
