In 2016, nothing changes,
except that the glass on the front and back panel becomes 2.5D ( it is a fashion, and only now do all of these slides with rounding). But the very body materials are exactly the same.
The second point - is the protection of water. Just like in the Galaxy S5, it returns to the phones Samsung, and all flagships.
Standard protection - IP68, phones can drown, and they do will not do. There impregnating components on the board with a special solution, water repellent (it used in phones like Motorola), but also the design does not allow water to get inside, to the speakers and microphone special membrane.
The body slightly increased in size, it is a consequence of both larger battery S7, and another frame structure, it is made of durable to withstand the machine serious fall. I have the latest generation Galaxy does not have any complaints about the resistance to the falls. Immediately fully counted and arrangement of the components of the phone to provide even greater survival and safety glasses that cover the screen and the back surface. Miracles do not happen, and you can break any device, but users ruler Galaxy / Note know that they have a very reliable machines that are difficult to break.
Therefore, the new Galaxy will be granted an extended warranty on the VIP-screens, they will be replaced free of charge or for a nominal fee if you break the fault of their own them in the first year after purchase. Depending on the country program may differ in detail, in some countries it may be absent
On subjective impressions. As an S7 most objective person in the world (not yours truly), then the apparatus S6 feels like unfinished workpiece. And I add to this there is simply nothing.
Now the memory card back into all flagships, you can use them almost any volume. If you find a card to 2 TB, you can, in theory, to put their (still in the line "support" for the 2 TB flaunts an acronym TBD). I have a card yet, so believe in the word that they will work. Map 200 GB is recognized and works.
RAM by type has not changed, it's chips built on 20nm technology, the first time we saw them a year ago. The peak data rate - 3.2 GB / c, which can be considered a top speed of mobile devices in the next year, or even a half. RAM up to 4 GB.
Memory manager, which appeared in the previous generation and caused complaints of many users that it is unloaded from memory applications stayed here. But added mode of operation in which the last application kept in RAM, unload them only when necessary. That is, we got kind of mixed mode: until the memory is required, the application it hanging, but as soon as it is needed, they go into the buffer.
But because of the speed of the processor, the time to download applications from the cache was reduced at least by half, it seems that they hang in the memory. Visually, and feels it is a big increase in speed in this aspect.
The vast majority of countries will receive the flagship of Samsung Exynos version rather than Qualcomm 820. Operators who want to, for whatever reasons, to get a version of Qualcomm, do it consciously and for their own reasons. Of the minuses Qualcomm version has been less about 10 percent of the time in different modes at the same performance that looks like a huge difference. Also, the integration of smaller chipset from Qualcomm BRITECELL camera from Samsung may affect the speed of the autofocus (but you do, most likely will not notice). Advantageously, the flagship version will be the one that uses the Exynos 8890 inside.
I would like to underline that the new processor is very fast. In all senses it is one of the best processors on the market, while it has good energy efficiency, reduced energy consumption, which, combined with other technical solutions make these models very interesting.
The screen has a couple of chips, both hardware and software, which has not yet been leaks, most guesses. Leave them to the presentation.
In S7 EDGE screen size 5.5 inches for curved facets added new applications and operating modes. Tell us more about them from Barcelona. The bottom line - the best screens on the market become even a little better. What has become customary.
In S7, the first module is used proprietary BRITECELL (at Sony received a license for its release, it has already said that it is an interesting story). Physically, the matrix has a resolution of 24 megapixels, but the output image is formed as half that of neighboring points combine to enhance the sharpness of the image. Something similar happened on Symbian from Nokia, where the company presents its photo oriented flagship model.
In this technology, there is another aspect, there is usually a green color filter, it reduces the sensitivity matrix. In this filter BRITECELL refused, which, coupled with the f / 1.7 leads to increased sensitivity of the camera, look at the picture of presentation.
perhaps the most important - is the increased clarity and brightness of the picture (although, I confess, I do not know much better, the current flagship shoot very well). Here increased ability to shoot in the evening and in the dark. There are new scenes and plots, the camera settings. This will need to be discussed separately and in detail, to turn the camera in practice. While I will say this cautiously, as the differences between shooting EDGE Plus and S7 are clear and well marked.
The Samsung managed to improve the camera, although it seems that this is not possible.
The phone has two built-in wireless standard of chargers, you can use any. There is support for fast wireless charging. There is also a fast charging wire - a hundred minutes you charge the unit by 100 per cent (in the S7 EDGE little longer, about 120 minutes). To obtain a half charge, it takes less than an hour.Many of the flagships of other companies can only dream of such a fast-charging technology that saves even when a night you forget to charge your device, in the morning it will be enough minutes.
The most important improvement in the current champions, and all 2016 models from Samsung, this increased operating time. Here gigantic work done, and it should be noted. On average, they will work in 1.5-2 times longer than previous devices of the same segment. The reason - the increase in the battery capacity, but also the optimization of software and hardware.
A few words about the connector microUSB, which is a progressive part of mankind has decided to send to the scrap and waits USB Type C. Personally, I'm worn out pull a second cable, constantly remember, so I have some phone numbers are charged only at home, where such cables are. The value of Type C is greatly overrated, a connector need a small audience that feels technology enthusiasts. Therefore, the mass products it is not used. The gradual transition to a start in the autumn of 2016, and that this is an issue not fully resolved.
As before, this phone has a TouchWiz, but he extensively revised the style of Android, and now the whole system is perceived as a very mild air and all together looks natural.
The speed of the UI is excellent, it flies, no brakes just yet. Again, it all depends on personal perception, someone sees the brakes on what other people think instantly.
The software a lot of chips, they will have to tell apart. Some services were first introduced with these devices, existing applications significantly reworked. This unit must be taken in hand in order to understand what and how it differs.
A brief summary and thoughts about the new flagship
Ungrateful thing - to evaluate new devices on the pictures or photographs. In the case of S7 / S7 EDGE is doubly ungrateful.It seems to be the same materials, the same design, but they need to take in hand to realize the difference. And she was not in favor of the previous generation. These devices need to feel alive and see how they work, how responsive menu, it removes the camera, and it is desirable to do so in the twilight, to understand the differences.
We are accustomed to the fact that each new generation of the flagships from Samsung gives new technologies and sets the bar for performance, and what can be built into cell phones.Today it is the most functional solutions of all, but in the past year waiver of memory cards has upset many. Now this deficiency is corrected, and everything returned to normal. But even added a reinforced shock resistance, protection IP68 from drowning. Plus increased battery and optimize the system so that the work grew by 1.5-2 times. It's all together suggests that the model was not very successful, and sverhudachnym.
The new camera module BRITECELL looks promising, it needs to turn and look, but overall this is a breakthrough in the direction where no one was waiting for major improvements.Now I did not expect that the difference will be visible in life.This is a serious bid for it to maintain its advantage in this area, other vehicles are approaching Samsung's photofraction, but to catch up and can not.
From an engineering standpoint, these devices - small masterpieces, they stuffed the latest technologies and made them work. Do not be amiss to point out that other companies, in the first place, Apple, comes to applying these technologies only years later, they have no opportunity to do something like that. They are too far behind in development, and this is evident in almost every piece of iron. I have a very positive perception of the new flagship, and that Russia is well dispersed in the previous generation, says a lot about the changing orientations of people in crisis. The same S6 due to affordable price has become the flagship of the most popular, followed by the iPhone 5s 16GB. Selection of a three-year model for me remains a mystery, but the people see this as some kind of sense. But everything is changing, slowly and surely ordinary people realize that a fast charge in real life look like high-quality screen and why Android gives you the freedom to use. I have no doubt that the seventh generation Galaxy will be very successful, there are all prerequisites device turned interesting.
http://mobile-review.com/articles/2016/galaxy-s7-wait.shtml
Ovaj batica ruski eldar maltene napravio review [emoji23] [emoji15]
Kakav zverski telefon u najavi.. Pravi naslednik s2
