Nabukodonosor
Pa bilo je pitanje na ovoj strani. Zadnju opciju stavi.
@blackbear
Pazi, imam instaliran i W7, i u njemu mi se desava da mi npr. posle 10-15 minuta samo se iskljuci monitor i zvuk i sve, i samo treperi lampica na monitoru. Ni hard reset ne radi, samo iskljucivanje iz zida. Prvo sam pomislio da je memorija, ali sam je testirao i dobra je, onda sam pomislio da se procesor greje pa sam kupio novi kuler, oborio temperaturu ali nije pomoglo. Posle sam pomislio da je nesto do graficke, ali tu nisam nasao resenje. Sto je najgore, nema nikakvog pravila kada ce da se desi to. Desavalo mi se cak i u toku instalacije Windowsa 7. Najvise mi lici na pregrevanje NECEGA. U XP-u mi se to ne desava.
100% ok, ali evo sada u idle-u je 38C, a nisam startovao igru ima jedno 3-4 sata.
ne znam samo kako su to izveli na VLC-u ali ovaj zadnji mi skuca komp maximalno, kad pustim nešto on kao bufferuje minut-dva. totalni raspad bolje da nisu ništa dirali, od najboljeg postao najgori plejer
When installing AMD's current northbridge drivers, the "success" confirmation message, installation log entries, and info in the Device Manager might lead you to believe that everything was installed just fine. Too bad the Catalyst setup says otherwise.
ATI has also released a 10.7 Preview driver which is newer than the official 10.7 driver and provides support for OpenGL ES 2.0.
Starcraft II: Support for Anti-Aliasing through the ATI Catalyst Control Center when using a Windows® 7, Windows Vista® or Windows XP based system with an:
ATI Radeon™ HD 5xxx series graphics card or ATI Radeon Mobility equivalent series of products
ATI Radeon HD 4xxx series graphics card or ATI Radeon Mobility equivalent series of products
ATI Radeon HD 3xxx series graphics card or ATI Radeon Mobility equivalent series of products
ATI Radeon HD 2xxx series graphics card or ATI Radeon Mobility equivalent series of products
Improved performance for Quad ATI CrossFireX™ for Eyefinity™ supported configurations
Koliko ja znam nVidia daje podrsku i za prastare kartice ?
Pozz svim forumasima , elem imam jedno pitanje . Skoro sam uzeo novu graficku MSI 4650 HD (ati radeon naravno je cip ) i lagano sam krenuo da cackam Catalyst program i naleteo sam na stavku overclock , i odkljucao sam je posto je naravno bila zakljucana . Posto sam je overclock ovao , i digao joj radni takt sa 600 Mhz na 700 Mhz i radni takt memorije sa 400 Mhz na 500 Mhz , sve je radilo ok nekih 5 min i odjedom grafika je pobljavila . Prvo su izasle neke plave tackice na ekranu a zatim je graficka pobljavila nacisto i izbacivala mi je stalno crn ekran . Sada to sam nekako popravio , ali me zanima zasto je grafika pobljavila kada pise da je dozvoljeno da se overclock cup i memory na grafickoj do 85 % ?
Some of you will no doubt be aware that Vista, and now Windows 7 do not Support the ATI Radeon 9200SE. Here is a full solution for those of you with the Blue Screen of Death issue on Shutdown & Restart.
1) Download the Windows 2000 Driver for the Card from the ATI Website. Use option 2 (Driver Only).
2) Once the download has completed, simply right click it, click properties and run it in Compatibility mode for Windows XP Service Pack 2, also tick Run as Administrator.
3) After applying the settings, run the download. Let it extract, and then allow the Installation to complete, however decline the option to restart immediately.
4) Now, go to the System32 Folder and cut the ati2dvag.dll to your desktop.
5) Log out, and log back in. By this point, your graphics will look terrible and you'll be cursing me but have faith!
6) Take the ati2dvag.dll and paste it back into the System32 folder.
7) Restart your PC.
You've done it! No more Blue Screen of Death.
