Da, ja sam iskreno prezadovoljan ovom klimom.
Cak i da imam wifi modul ne bi ga nesto koristio, ja je uvece stavim na 22c posto svakako mi ne odgovara da se kuvam dok spavam.
Danas sam na poslu video neku 18icu Midea forest, tu su negde po ceni.
When choosing between the
Midea Forest 18 and the
Fujitsu ASYG14KMCC, you are comparing a
budget-friendly entry-level unit with brute-force capacity against a
premium, highly efficient Japanese-engineered unit designed for sustained performance and serious heating. [
1,
2]
The decision depends entirely on whether your primary goal is high-volume summer cooling or efficient, reliable winter heating.
Quick Comparison Overview
| Feature | Midea Forest 18 (18,000 BTU) | Fujitsu ASYG14KMCC (14,000 BTU) |
| Cooling Capacity | 5.28 kW | 4.20 kW |
| Heating Capacity | 5.57 kW | 5.40 kW |
| SEER (Cooling Efficiency) | 7.4 | 6.9 |
| SCOP (Heating Efficiency) | 4.0 | 4.1 |
| Airflow Volume (Max) | 840 m³/h | 770 m³/h |
| Built-in Wi-Fi | Yes (usually included/free) | No (Optional module required) |
| Build & Hardware Class | Budget / Entry-level Inverter | Mid-Premium Japanese / Electronic Expansion Valve (EEV) |
Dakle krmaca moze da se kolje i sa nekim 18btu modelima.
