Windows 11
  • Začetnik teme Začetnik teme Deleted member 46590
Apdejtuje se tokom instalacije.
Pa naravno, ali može odmah da se napravi butabilan fleš sa MCT v9711.
Windows 11 KB5127648 ISO now available for USB install via official Microsoft tool
Most of you probably already are very familiar with what it is and how it helps, but for those who may not, it is essentially Microsoft's official bootable ISO media creation utility. It downloads Windows 11/10, and currently, the company's Windows Update servers are delivering the latest available KB5127648 (build 26300.9711 on 26H2).
Sređuju polako, context menu konačno. 🙂
Moraće da se sačeka 26300.9807 (KB5127936) ili da se koristi ViveTool kako bi se ukljucila ta opcija.
Feature Bundle ID:
vivetool /enable /id:61161283
New Context Menu:
vivetool /enable /id:60813048
New AutoPlay Dialog:
vivetool /enable /id:62141177
New Low Latency Profile for Files:
vivetool /enable /id:62816659
New Folder Options with Dark Mode:
vivetool /enable /id:59203365
New Temporary Files Settings Page:
vivetool /enable /id:61456288
New Start Menu Phone Hover:
vivetool /enable /id:60682493
New Tilde Support:
vivetool /enable /id:61815311
0:00 Intro
0:32 How to Get this Update
1:14 New Context Menu
4:02 New AutoPlay Dialog with Dark Mode
4:36 New File Explorer Search
4:54 New File Explorer Address Bar
5:07 New File Explorer Folder Options with Dark Mode
5:28 New Low Latency Profile for Files
6:00 New Gaming Task View in XBOX Mode
6:22 New Privacy & Security Settings Page
6:45 New Device Info Card in Settings Home Page
6:55 New Modern Temporary Files Page in Settings
7:05 New Start Menu Phone Hover
7:36 New Taskbar Window Previews Animations
7:52 New Taskbar Improvement
8:02 New Magnifier Contrast Theme
8:23 New Magnifier Per-Monitor Zoom
8:34 New Magnifier Viewport Locking
8:41 New Live Captions Screen Reader Audio Option
8:52 New Narrator Math Reading Support
9:02 New Family Safety Improvement
9:12 New Windows Recovery Environment Improvement
9:27 New Cloud Rebuild Feature
10:28 New Microsoft Edge Accelerated App Launches
11:01 New Default Debloat Method Multi-Session Support
11:32 New Adaptive Hibernate Improvement
11:49 Memory Integrity Enabled by Default
12:11 New Windows IPv6 Networking Support
12:32 New Data Protection API
12:38 New Windows Spotlight Improvement
12:46 New Unicode 17
12:53 Remote Desktop Fixes
13:22 BitLocker Fix
13:33 Smart App Control Fix
13:54 How to Enable All New Features
15:52 Outro
Gde ga vide. 🙂
Ipak je ovo Insider Preview build...
Koliko vidim ovaj W11 smece nema sanse da dodje na nivo stabilnosti i fluidnosti W10 LTSC jos 5 godina da krpe..:.
Voleo bih da je tako, evo probao W11 LTSC(obicne necu ni da probam puni bloatwara) em sto je sporiji a da ne pocinjem sa problemima sto sam imao. Plus sto je UI uzasan opet to je stvar ukusa ali realno po meni veliki korak je w11 u odnosu na w10.
Windows uglavnom koristim za gaming a MacOS za ostalo, a kada pređeš sa fluidnog W10 na W11, tačno vidiš koliko sistem štuca. Razlika je u odzivu samog sistem-a npr samo za koriscenje explorera nista vise, na svakoj masini na kojoj sam instalirao W11 novi StartMeni i FileExplorer imaju onaj sitni stuttering koji ni na jednoj verziji W10 nisam imao.
Dobro, ja bih se isto slozio da je respond losiji nego na W10 ali daleko da je lom W11. Koristim oba pa vidim u realnom radu razliku. Finese su u pitanju, ali verujem da ce to da ispeglaju vremenom. Opet ogromni redizajn celog interfejsa rade, core elemente... Potrebno je vreme da se sve to napravi pa ispolira
Nešto ti tu ne štima.
U pravu si totalno, ništa ne štima od kad su počeli da se lože na AI i ostalo smeće koje pakuju u sam OS. Umesto da srede sistem i izbace gotov proizvod, oni izbacuju poluproizvod sa forsiranjem reklama i drugim glupostima. Svako može da koristi šta želi naravno, ali za sada je stanje takvo da je, nažalost po nas korisnike, W11 običan poluproizvod sa krpljenjem u letu.
Saglasan da je desetka fluidnija ali daleko od toga da je 11 krš, apsolutno nikakvih problema nemam. Ono što je meni malo čudno, da u vremenu kad je NVMe disk standard, igrama treba po 10-15 sekundi da se startuju, prvi put, drugi put bude već bolje, znam da ima veze sa keširanjem, DRM provjerama, itd... but still... 🙂
Što se tiče gejminga i tih par FPS-a gore-dole, iskreno nisam primetio neku razliku. Međutim, sama fluidnost sistema je druga priča. Tu je i onaj novi, nazovi Start meni, za koji mi treba gomila dodatnih programa samo da bih ga doveo u neko pristojno stanje. A tek desni klik... neverovatno je da i to mora da se tvikuje kako bi radio najosnovniju stvar kao i do sada.
StartAllBack i središ ujedno i Start meni i desni klik, sve se sredi u dva klika.
Probao sam i to, ali na LTSC verziji taj alat sredi samo Start meni, dok sam za vraćanje starog desnog klika ipak morao ručno da čačkam po Registry-ju. Hvala na predlogu ali jednostavno mi nesto ne lezi W11 dok ga ne ispegalju kako treba ili izbace skroz XAML, VBS i ostale bezbednosne nazovi funkcije. Naravno, ljudi koji koriste novije arhitekture sa P i E jezgrima možda i vide neki benefit od W11, ali ko god ima procesor sa klasičnim, monolitnim jezgrima, po mom mišljenju ne dobija apsolutno ništa osim bloatware-a i večitih apdejta. Ali dobro, svako ima pravo na izbor, pa i da bude beta tester za Microsoft. 😆
Razumem da ti se ne dopada W11, ali u ovom trenutku je i više nego dobar. Sa poslednjim ažuriranjem File explorer je kao metak. Koristim ga od kako je izašao i sa svakim ažuriranjem je sve bolji i bolji.
Moguce i da je to toga posto je W11 LTSC 24H2 verzija, probacu opet u nekom momentu pa cemo videti da li su ga sredili.
Neće ga nikada "srediti" da bude svima potaman na defaultu ali je dovoljno elastičan da može da se sredi po ličnom ukusu. Registry, koji mnogi uzimaju kao manu, ima mali milion promenjljivih opcija.
Zanimljivo je sto 26H2 sa poslednjim ovim update-om je za skoro citavih 1.8GB laksi iso fajl. U odnosu na lansiranu verziju u septembru.
Claude optimizivao
Jel moze vec postojeci windows da se apdejtuje na tu verziju?
Meni je jos uvek 24H2 (26100.9711)
obzirom na cenu licence za windows ovaj operativni sistemje brutalno dobar.
U tom slučaju linux i mac trče krugove oko windowsa.
A cena proizvoda odavno nije izražena u novcu jer si dao mnogo više nego što misliš. To važi i za google i meta i ostale lopove koji svoje proizvode nude "besplatno" uz malu napomenu da su ti uzeli i dušu. Mada to nije tema ovde, izvinjavam se.
