Uf,bas si otisao u najnizi segment ,sad sam gledao cene bar srednje klase guma ali bar 2k po gumi bi morao dodati195/60/15
Šteta za Hankook, ove zimske su baš fine gume. Šteta što nemam veći budžet, uzeo bih i letnje Hankook.
https://www.tyrereviews.com/Tyre-Tests/2026-ADAC-Summer-Tyre-Test.htmDa se vratimo na gume?
Ja sam bio na ivici da uzmem Laufenn S FIT EQ+ LK01 ili Lasa Greenways (koje imam već na jednom paru točkova, mada bi ih menjao sledeće godine). Posle već 5 godina, nije se tako loše pokazala, obzirom na puteve.
U petak odem do Kema, reče mi onaj lik na šalteru, uzmi Lasa Revola, bolja guma od svih, Greenways se uplastiči, stari model, nema ih maltene na satnju, trtmrt. Kod njih na sajtu reklama Lasa greenways "Novo, preporučujemo, kemova garancija.
Prepipao sam malo laufen, deluje kruće i jače, laički govoreći, dok lasa revola baš deluje gnjecavo, čak sam u drugoj radnji malo pogledao Riken summer 3, iskreno, dosta liči na revolu, mekana guma.
Primarno mi je da guma može da trpi ove naše divne ulice i rupčage.
The Turkish-made Lassa Revola is rated “not recommendable.” The summary states that it barely reaches a satisfactory score in safety: dry-road performance is poor, with the tyre losing grip as temperature rises, offering only minimal steering feedback and making it hard to control the vehicle; it tends to oversteer in emergency manoeuvres. Wet performance is somewhat better, with average braking and above-average handling, though aquaplaning resistance is only average. The environmental rating is only “befriedigend” due to average mileage and abrasion; efficiency is good thanks to low weight and fuel consumption. Strengths include very short dry braking, good wet performance, low weight and low fuel consumption, but the tyre is very weak on dry roads, has aquaplaning weaknesses and only satisfactory mileage and abrasion.
Imas na rate ,kartica ili cekoviVeruj mi, i sa ovim se natežem. Bar još nisam spao na Ling Long. 😀
Danas kod vulkanizera zadnja desna skinuo da mi pogleda,a ono kao da malo jaje tj jest neravna sreca sa novim lezajem nisam ni presao ni 200kmNemoj zaboraviti, lose gume tj neravnomerno potrosene vrlo lako vibracijama koje proizvode mogu razbiti lezajeve.
Neko je spomenuo gore, prevuci prstima preko sare tj lamelica i ako osetis kao stepenice, te gume su za bacanje... a pogotovo tolika razlika u Dot-u!? Tolike godine uticu na smesu gume i to po meni nije bas pametno i bezbedno za voznju no ljudi svasta danas voze... :/
Mozda poneo zeni za cvece.Pa vi kupujte stare polovne gume. Pre koju godinu izbacim ispred kontejnera 4 letnje Bridgestonke 3mm šara 205/55 R16 koje su bile na autu kad sam ga kupio, dot star 8 godina. Nije prošlo 5 minuta, zaustavi se namunjeni Audi A3, stade i tovari u gepek, kao da su suvo zlato...
Da li neko zna koja je prva ugradnja za kineske automobile koji se prodaju kod nas?
Sudeći po nekoliko poruka na Jaecoo i Omoda grupi, na J7 Kumho ljetne.
Значи бацаће се у реке и остављати поред пута. То се решава мало другачује, посебно у држави која има озбиљан проблем са смећем на све стране.Meni sada vulkanizer naplatio 100din po staroj gumi ako hoću da mu ih ostavim. Kaže mora da plati odvoženje na reciklažu.
У Норвешкој се приликом куповине нових гума плаћа еко-такса од 25 круна (2-2,5 евра) по гуми од које се финансира скупљање и рециклажа половних гума. За гуме, као и остали отпад су задужене локалне комуналне службе.![]()
Nelogične odluke oko subvencija: Zbog bacanja starih guma kreće poskupljenje novih?
Problem koji je napravila odluka Ministarstva zaštite životne sredine pogodio je reciklere, ali se prelio na servisere, pre svega vulkanizere, koji će po svemu sudeći biti prinuđeni da, ako su savesni, povećaju cene i svojih usluga i novih pneumatika. Ili to ili će uslovljavati vozače da moraju...satplus.rs
O AS se uglavnom piše u temi o zimskim gumama.Nisam nesto pratio, ne znam da li se ovde vise spominju all season ili u zimskoj temi, ali planiram da uzmem nove all season gume za Opel Corsu D. 195/55/16.
Vec 5.5 godina kako sam je uzeo vozim na zimskim kupljenim gumama non stop, pa bih sad to zamenio. Ne prelazim vise od 6-8K godisnje.
Sledece godine planiram nov auto, a ovaj ce da ostane supruzi, pa pored jos nekih ulaganja, planiram i gume, jer idemo sa bebom na more, pa zelim da osiguram auto koliko toliko.
Moje pitanje je koje da uzmem, secam se da sam gledao jednom Hankook u Kemoimpexu, ali tog modela vise nema. Uzeo bih tamo jer vidim da moze na 12 rate preko Intese. Ali ako ima drugi prodavac da nudi iste uslove, nije problem. Koji model je sada medju najboljima?
Системи већ постоје и функционишу, само треба да се преузму. Нажалост, само треба (и овде)…
Izlazimo iz teme, ali reciklaža i odlaganje otpada su već sada ozbiljan biznis u kom se zaradjuju ozbiljne pare.Reciklaža i povratna logistika bi mogle da postanu ozbiljan deo privredne aktivnosti kod nas, ali niko za to nema sluha. Uz to bi zaposlila ljude da margina društva i svi bi imali koristi...
Između ove tri koje si naveo definitno hankook, i to ventus prime 4Stigle felne a s njima i gume od kojih je jedna zakačena bočno, mada mi vulkanizer reče da mogu da teram tako, neki đavo mi ne da mira, pa sam mislio da ipak zamenim one koje će ići na istu osovinu.
Pitanje je šta uzeti?
Hankook Ventus Prime
Firestone roadhawk 2( ne znam da li su ENLITEN)
Kleber Dynaxer
