Dwyane Wade
- Laptop
- Lifebook
Za ispod 30 dolara sa kuponima ima Steelflier SF745 . Za taj novac neverovatan sat. Od opreme bruka 🙂 Za ovaj se i isplati da se platri pošti "šta već"
Specifications
- High-concerned chemical
None
Display Type
Arabic Numeral Markers- Case Thickness
13.35mm
Band Width
15 to 19 mm- Band Material Type
Leather
Movement origin
Jp(origin)- Battery Included
Yes
Case Shape
Round- Dial Window Material Type
Sapphire Crystal
Boxes & Cases Material
Plastic- Model Number
SF745
Dial Diameter
35 to 39 mm- Feature
Screw crown,Luminous,DIVER,Water-Resistance,swim,Luminous Hands
Water Resistance Depth
20Bar- Clasp Type
Buckle
Band Length
23cm- Case Material
Stainless steel
Movement
Quartz- Style
SPORT
Brand Name
STEELFLIER- Origin
Mainland China
Item Type
Quartz Wristwatches- Pointer size
9.25*13.00*13.00mm (hour hand * minute hand * second hand head length)
Dial size
29.33*29.00*28.00*0.40mm (wire hole * surface diameter * open surface * thickness)- Watch mirror size
30.00*3.80mm (diameter * thickness)
Crown size
10.00mm (diameter)- Crown type
Screw-in screw-lock crown
Bottom cover type
Screw in solid bottom cover- Luminous features
Swiss super luminous
Weight
77g (with khaki nylon strap)65g (with leather strap)- Battery model
SR920SW
Movement features
3 needles, sweep second- Movement model
VH31
je l moze link? ima ih u preko 15 prodavnica, svugde popust 3 posto..
