ATI Catalyst/AMD Crimson - diskusija, pitanja, linkovi
RDNA1/2:
Kod:
https://drivers.amd.com/drivers/whql-amd-software-adrenalin-edition-26.3.1-win11-a.exe
RDNA3/4:
Kod:
https://drivers.amd.com/drivers/whql-amd-software-adrenalin-edition-26.3.1-win11-b.exe
Kombinovani: (RDNA1/2/3/4)
Kod:
https://drivers.amd.com/drivers/whql-amd-software-adrenalin-edition-26.3.1-win11-c.exe
Zeza me zvuk oduvek kad skrolujem u Chrome, prekine tu i tamo ali sad od zadnjeg update-a baš počelo da smara mnogo više nego ranije.
Ovo sam uključio u drajveru i prestalo je:
Ne znam koji profil i da li je bio uključen neki ali prestalo je, za sad.
26.3.1 zadnji za RX6650XT.
Sto ne reinstaliras chrome? Iovako imaš nalog, a sa njim će povući sve. Nema veze ti profili, najviše je to kad se igra i onda uništava igre umesto kad se lepo u igri podesi.
26.5.1 kresovao ceo sistem (black screen) prilikom alt-tab iz YT videa nazad u igru (BF1). Vracam se na provereni 26.2.2
^ da li je to generalno dobar drajver ili samo za 7800 XT ?
Premalo informacija...
Ako nisi probao debagovati (čista instalacija nakon DDU), informacija nije korisna tj. pouzdana; može biti konflikt sa starim drajverom ili čak sa nečim trećim.
Odradjena deinstalacija starih drajvera, DDU u safe mode, instalacija novih.
Odradio autoupdate drivera videću kako se ponašaju u narednom periodu, kartica je 9070xt
AMD has officially confirmed that its AI-powered FSR 4.1 upscaling technology is coming to older Radeon graphics cards, bringing superior upscaling to older architectures, according to reports from PCWorld and The Verge as of May 14, 2026.
  • RDNA 3 (RX 7000 Series): FSR 4.1 will roll out to RX 7000-series GPUs in July 2026, offering support for over 300 games, notes The Verge.
  • RDNA 2 (RX 6000 Series & Steam Deck): Support for older RDNA 2 cards is scheduled for early 2027, PCWorld reported.
Key Details on FSR 4.1 Expansion
  • Performance Optimization: While FSR 4.1 was designed for newer RX 9000-series cards, AMD’s Jack Huynh stated they "carefully tuned, optimized, and validated the model" to run on older hardware, explains The Verge.
  • AI-Powered Upscaling: The technology offers improved performance, sharper visuals, and smoother gaming, and it was previously considered exclusive to the latest, top-tier hardware, according to Engadget.
  • Wider Support: This update ensures users of older cards, including the widely used Steam Deck (RDNA 2), will not be left behind, as highlighted by The Verge and Tech Sportskeeda.
"RDNA 2 cards is scheduled for early 2027" - može li to malo ranije rodjaci, pa cak i ja cu menjati do tad grafu 🙂
Isti slucaj sa 26.5.2, pride vidim da atieclxx (AMD External Events Client Module) ima konstantan ~2MB/s I/O write/read
E nisam, posle update drajvera i dalje i to krenuo toliko da prekida da mi i miš u nekom trenutku počeo da zeza (trza u pokretu). Probao sve živo, čistio sa DDU drajvere stavio čiste, kao malo bolje ali sam primetio kada ga dugo držim u sleep bez restarta tada se najviše pogorša. Nakon restarta je bolje ili prekine skroz pa opet posle jednog dva sleep-a ponovo zeza. Danas odradio update za chipset (B550) i za grafičku 12.5.26.
Ako ne prestane vraćam se ja na Win10 i to ću LTSC da stavim i da batalim ovo smeće od 11.
Inače sam na 24H2 od marta prošle godine, sve update do tad, nakon toga isključen update. Zezao i na predhodnom 22 nekom.
Da li si probao ovo?
Nisam ali to nije za to koliko vidim, koristim zvuk sa ploče i USB zvučnika koji imaju svoju zvučnu karticu i na oba je isto tako da nije do zvučne i drajvera.
@djalf Mislim da sam ja ranije imala, ako ne i isti problem, bas je pretrazivac stekao strasno. Iskljucila sam neku opciju, ne znam kako se zove, na foru refresh rate, sync, variable scale nesto. Nasla sam tad na netu i od tad nemam problema. Mislim da je u glavnim grafickim podesavanjima to.
Verovatno Hardware acceleration u browseru, Ako je USB onda to nema veze sa grafičkom.
Da, Hardware acceleration pomaže što se tiče Chrome-a ali ostalo i dalje zeza.
Hvala, probaću i to.
directx je skup raznih standardizovanih apija, i ne znaci samo graficku.
tu ti latencymon predlaze da iskljucis CPU throttling u ctrl panelu, mada ako se radi o masini iz potpisa stvarno ne vidim poentu za cimanjem.
ako se oslanjas na usb kontroler za zvuk, imaces veliku letenciju, ali to nije ono sto tebe zeza, nego nacin na koji masina tumaci te tvoje jeftine sluske.
iskljuci zvucne izvore koje ne koristis - ako imas integrusu, disabluj u biosu, ali je prvo uninstaliraj.
te integruse su znale da prave konflikt sa kojom god zvucnom imas. nije do nje same nego do windowsa.
druga stvar, overi podesavanja za usb cuvanja energije i da ih ne iskljucuje ako se ne koriste.
amd je generalno uzasan sa ovim stvarima i razlog je zasto sam se vratio na intel platformu nakon 3 ryzen upgrade-a.
(izludjivalo me je sto je sam od sebe budio win iz sleep-a nasumicno, i prateci logove krivac je uvek bio usb host controller odnosno jedan od uredjaja a svima sam iskljucio da to rade u dev manageru).
Znam, DirectX kontroliše i zvuk, input itd... ovo ostalo što si predložio sam sve probao sem integrisane zvučne, nju koristim, ima dobar zvuk i bez nje komp mi ništa ne vredi.
Juče odradio Win10 LTSC, sve update, zadnji BIOS, zadnji drajveri, otkačio sve sa USB-a i ostavio samo USB miš (ostaje da probam preko PS2 pošto ga imam), drugu USB Wifi karticu, bez nje, isto. Mogu da gledam Stremio satima i nema problema ali čim otvaram i skrolujem tabove u Chrome ili Edge krene da prekida zvuk, ne stalno, zato je i problem jer trebam da čačnem nešto od podešavanja pa da čekam da se desi, izuzetno me nervira i na kraj ću da promenim celu mašinu zbog ovoga jer ovo je neverovatno šta se dešava. Isključio Resize BAR, isto, spustio RAM sa 3200 na 2100, isto. Isključio LAN mrežnu u BIOS-u, isto.
Ostaje da je neko podešavanje u BIOSu (PBO, to nisam ništa dirao sa default?), da grafika ili CPU imaju neki problem hardverski.
Kad budem imao vremena da probam i ASIO FOR ALL za zvučnu i drugu grafičku, procesor nemam za probu pa je to zadnje. Ovo što si pomenuo USB zvučnu to su USB zvučnici koji imaju svoju zvučnu kartu i isto se ponaša na njima i bez njih, dakle nije ni do toga.
Zeza i van browsera.
Rešio, stavio stari drajver iz 2022 - 22.5.1 i za sad više ne zeza. Znam da kad sam sklopio komp 2023 i da tad nije zezalo toliko, možda ponekad ali u zadnje vreme kako je noviji drajver ono sve gore - dakle AMD očigledno ne ume da napiše drajvere.
Tacno su na nekoj verziji dodali tu neku opciju koju sam ti spominjala, pa te to zezalo.
