AliExpress (FAQ u prvom postu)
Dzabe crtam, naplatili su ti samo to ne znas izgleda.
Dizem ruke od rasprave, da ne popijem kaznu bespotrebno, neka je sa srecom svima GPC Nis.
Treba davati 1 zvezdicu za product description, u komentarima pisati da njihov partner Posta Srbije naplacuje dodatnih $2.5 na svaku posiljku iako je postarina free ili placena aliexpress-u.
Partneri sigurno nisu, džabe daješ jednu zvezdicu jer samo štetiš prodavcima.
Danas komsiji u Pa postar doneo dva paketa, memorijske kartice, u vrednosti 0.90€, naplatio dostavu 300din i rekao da ce od sada da naplacuju dostavu paketa od 300din pa navise. I da, ovo nije vat, carina i ostala s****, nego dostava.
Takodje imam jedan od 16.02. pisao sam danas ovim ECSC
Isto sam pisao evo sta su mi odgovorili:
European Chinese Supply Chain Zrt., 2026. március 02. hétfő, 14:10​
Dear ************!
Thank you for your inquiry. You have reported this parcel number: LA**********HU
We would like to inform you that we have initiated an investigation of your report to the relevant department.
Based on our preliminary information, a new system has been introduced at the Serbian customs authority, which has resulted in a significant extension of the time required for the customs clearance of parcels; the status displayed in the tracking system has been recorded as a related logistical indication.Please kindly monitor the Serbian Post’s tracking website on a regular basis using the following link. https://www.posta.rs/eng/alati/pracenje-posiljke.aspx
As soon as we have the necessary information, we will contact you immediately. We are doing everything we can to provide you with a meaningful response as quickly as possible, but the investigation may take longer, so we kindly ask for your patience in advance.
Thank you for your understanding!
Best Regards
ECSC Customer Service Department
I meni danas postar naplatio 300 din , paket LAxxHU vrednost 0.80 $ Toliko i kinez napisao
I jeste novo. Ni preko niske carine nisu ništa naplaćivali za neregistrovane pošiljke. Drugo, sada su, izgleda napravili dogovor sa Alijem da stavljaju prave cene na pošiljke, pa tako naplaćuju i pravi PDV. Ja sam pitao prodavca da stavi manju cenu na paket i AI mi je izbrisao poruku zbog kršenja lokalnih zakona. Verovatno više neće biti gift/returned goods.
Ja sam mu pisao istu,dijagnostika kostala oko 30,on stavio 10 evra i kaze da je odradio svoje,ali ne zna kako ce AE reagovati i moza iskrave
Ja sam odbio nekih 14 do sad, 4 sam preuzeo nesto sto mi je bas bitno bilo, na sve je islo 280-360 din po komadu, nema smisla za stvari od 20-40 centi placane davati 300+ din, inace kod kineza sve sto sam odbio sam obelezio kao da je stiglo i to je to.
Kako si znao šta je šta kad ovi naši promene broj pošiljke?
Stigne sms od pošte u fazonu "za vas je prispela pošiljka PJxxxxRS koju možete očekivati u toku dana. Iznos za uplatu je xxx din." nema načina da se poveže sa informacijama koje daje aliexpres pa da znam da li da preuzmem ili da vrate, jer većina stvari koje uzimam su preko coinsa i izađe većina ispod dolara, ne isplati se dodatno plaćati dažbine.
Stigne poruka na Viber sa pravim brojem pošiljke i iznosom za uplatu. Bar je meni tako bilo.
Meni je prvo stigla SMS poruka sa tim PJxxxxRS brojem, onda me zvao kurir da proba isporuku (ja bio na poslu pa je vratio u poštu) i onda mi je stigla poruka na viber slične sadržine "Pošiljku PJxxxxRS možete preuzeti od tad i tad u Pošti...." isto kao i za bilo koji post expres paket u domaćem saobraćaju...
Uglavnom, imam jedan paket koji je zaglavio negde "Your package has been marked "Delivery failed". You can check the ECSC website..." bla bla, jedan takav stigao posle 70 dana i dok sam tako čačkao po tim stranicama za praćenje dobijem ovo:
Donji link iz poruke -----> https://www.euronews.rs/srbija/drustvo/211677/posta-srbije-skracuje-carinsku-proceduru/vest
Sve u svemu, ako i ne bude načina da se poveže pošiljka sa porudžbinom, ići će isporuka u pošti pa ću po veličini i obliku paketa da prepozna šta je i odlučim da li ide nazad ili ne.
Nazalost nema nacina da se povezu posiljke po PJxxxRS brojevima - veliki problem
Drugi veliki problem je što se te pošiljke čuvaju samo 5 radnih dana i ako se ne preuzmu vrećaju se
Ali je online platforma i ogromna logistika koja direktno zavisi od saradnje sa postama (to su im najvazniji partneri) koje su uclanjene u medjunarodnu ogranizaciju koja funkcionise po odredjenim pravilima. Po tim pravilima nije dozvoljeno naplacivati neke dodatne izmisljene troskove ili menjati nacine i troskove vec ugovorene dostave.
To nije dozvoljeno, mogu da naplacuju carinu, pdv, pregled (ako zaista pregledaju) ali ne i neke proizvoljne fiksne iznose, doplate, pregled a pregleda nema vec samo skeniraju bar kod, dostavu po cenovniku kurirskih sluzbi, itd.
A i to je resenje bas, moze samo da se desi da ukinu totalno slanje za Srbiju.
Mi moramo da pisemo komentare jer je Ali apsolutno odgovoran sto im u opisu ne stoje dodatni postanski troskovi (a koji nisu carinski), da se zalimo medjunarodnim organizacijama, da podnosimo prijave protiv Poste Srbija pa ce se nesto desiti, ili ce ovde raditi po zakonu ili ce Ali uvesti obavestenja ili prekinuti saradnju sa Srbijom. Sve je bolje od cutanja i prihvatanja novog stanja.
Izgleda da kad je vrednost ispod 1$ ne naplacuju nista, stigla su mi tri paketa vrednosti od po 0,4$ i nije nista dodatno naplaceno. Paketi su poruceni 30. januara i 03. februara, stigli danas, 09. marta.
Auuuu kako sporo dostavljaju,nista popravili nisu,Temu ih u tome debelo šije oduvek
To ti je prošlo pre implementacije harača od 260 dindži još verovatno u prvoj polovini februara.
To što si ga dobio tek sad je zato što ti je mesec i kusur stajalo u tvojoj lokalnoj pošti dok se tvoj poštar nije smislio da ti donese.
Već smo bili pre par godina zbog velikog broja "izgubljenih" pošiljki preko Pošte... Ukinuli su bili AE Strandard i za SRB je bio samo DHL i sl.
Nemoj pričati gluposti, ima ovde ljudi koji se sećaju i >5 godina unazad šta je i kako je bilo? Nikada AliExpress nije bio ograničen na "DHL i slične". Uvek je bilo opcija za jeftinije slanje sa ili bez dodatne (obično simolične) naplate.
Pošiljke su se gubile i u Mađarskoj.
Srbija je trebala da bude ta u kojoj će biti centar koji je sada tamo odnosno Srbiji je to bilo ponuđeno.
Kako da ukinu? Zar nismo bratja, i crnu zemlju delimo bratski.
Zavisi gde se "informišeš".
Kina trenutno širi "maligni uticaj" i svako ko ima neki ugovor sa njom je u problemu.
Slikaj taj papir na kome piše da je "dostava"?
Netačno.
Mi moramo da pisemo komentare jer je Ali apsolutno odgovoran sto im u opisu ne stoje dodatni postanski troskovi ...
Ne znam kako je npr. regulisano u zemljama EU ali tamo nema dodatnih troškova. Navodno je sve uračunato u cenu koju plaća kupac. Primer - Španija.
Ako to može tako kod njih - onda sigurno može i ovde kod nas.
Ovako je kupac prevaren (obmana) a u sve je po svemu sudeći upletena privatna firma iz Šimanovaca (DOO, proveri se lako na Company Wall).
Sad sam uzeo pošiljku vrednosti 5,72 $, naplaćeno 377 dinara. Nije otvarana, tako da nisu ti troškovi, ne podleže carini. Nisam dobio nikakav dokument na osnovu koja je to naplaćeno. Zaključak - setili su se odličnog načina za pljačku.
Videcu, verovatno cu jos koji poruciti u narednim mesecima, jer su mi neki iz decembra stigli tek prosle nedelje i naplaceni su, ali veca vrednost. Bice da si u pravu ali isprobacu.
Dear ************!
Best Regards
jutro mi poslali mail iste sadrzine, sada proveravam, sasvim slucajno se pojavio novi status na pracenju 😀
Isto se i meni pojavilo za famoznu LA HU od 16.02. Izgleda da su ih izvukli iz nekog budžaka.
@SuperStarr Nije navodno uracunato vec je uracunatom provereno 100%, mrzime da proveravam kako tacno pise, ali pise u fazonu porez ukljucen u cenu, jeste da pise pri samom placanju da moze da nastanu dodatni troskovi nesto u tom fazonu ali se to nikad nije desilo bezobzira na vrednost paketa.
Jedina mana koja postoji (koja i nije neka mana) za eu je cena dostave za pakete manje vrednosti od 10e ali i tu pa ima opet benefit da se svaki paketic prati...
Meni su u posti rekli da sad imaju pracenje za sve pakete, cak i za one gde nema pracenja (ne znam kako i ja da ih pratim).
