Kako izgleda Vas LINUX Desktop?
Povratak Mintu
Moj frankenstein Artix Dinit sa CachyOS kernelom.
Definitivno neću prelaziti na Windows 11 na mojoj matoroj desktop kanti. Inicijalni testovi su bili BunsenLabs vs OpenSUSE Leap. Prvi krug gde sam najviše gledao bazičnu funkcionalnost je bio izjednačen, ali drugi gde više obraćam pažnju na look and feel vodi OpenSUSE sa KDE.
A sad nesto drugacije :)
@dobrivoj kako si zadovoljan Steam OS? Ja sam ga davno probao kada je krenuo ali tada je bio u početku i nije bio ispeglan kao danas predpostavljam.
Ovo je na samom SteamDecku za koji je i pravljen.Tako da sve radi posle 3 godine peglanja.
Uz Gigabyte G27F-EK Gaming Monitor 27″ FHD 144Hz IPS FreeSync Premium je extra samo jedan usbC kabel i imam i punjenje i spoljni ekran i tastaturu i misa kao
redovan PC izvucem taj kabel i imam rucnu konzolu. Sta ces bolje, nije bas jak ali sve moje igre rade u ovoj rezoluciji.
Jedino mi fali conky. To jos istrazujem kako staviti najsigurnije. do sada se nisam time zanimao
Ako ti bas fali conky probaj ovaj nacin ali obavezno beckapuj sistem prvo
This is how to install the conky manager and conky themes from MX Linux on Linux Mint Debian Edition.
Tested on LMDE 6 (Cinnamon) running on a 64 bit CPU PC.
Steps:
  1. Use Timeshift to back up your system in case you want to undo the install. Start Menu > Administration > Timeshift
  2. Double click the description field of Timeshift beside the restore point and label it “B4 conky installation” or something similar so you know which image to restore if necessary. This is in case something goes wrong with the installation and you want to restore your system to the state it was in before the installation.
  3. Go to Index of /mx/repo/pool/main/m/mx-conky-data and donwload mx-conky-data_20211226_all.deb and double click the deb file to install it. This installs the conky themes in /usr/share/mx-conky-data
  4. Go to Index of /mx/repo/pool/main/c/conky-manager and download conky-manager_2.7+dfsg1-6mx19+4_amd64.deb . I am using a 64 bit PC hence I downloaded the amd64.deb version. If you are running different hardware then download the version for your system. Double click the deb file to install it. This is the conky manager.
  5. Optionally, navigate to …/m/mx-conky/ directory in the above link and download mx-conky_24.3_amd64.deb and double click the deb file to install it. This installs an app to customise a conky. I am using a 64 bit PC hence I downloaded the amd64.deb version. If you are running different hardware then download the version for your system. Double click the deb file to install it.
  6. Go to Start Menu > Accessories > Conky Manager and run that.
  7. In the Conky Manager window, click on the Application Settings icon (third from the right, looks like a box with 2 switches)
  8. In the Application Settings pop-up, click the Locations tab, then the Add button, add /usr/share/mx-conky-data and it should appear in the “Additional Locations to search for Conky themes” box. Note that the path text should not contain the “themes” directory at the end. It should end with “mx-conky-data”.
  9. Close Conky Manager and open it again. The themes should then be listed and you can tick the check box of the theme to run.
  10. Not all conky themes work in LMDE but most do. The MX-CoreBlue/conky2core is the one I wanted to run but it does not work in LMDE. If anyone knows how to make it work do reply and tell me how.
Conky je nepotreban resource waste koji može da napravi problem sa full screen aplikacijama. Ukoliko i dalje želiš da ideš tom rutom, instaliraj conky-manager koji će ti olakšati taj process.
Konačno instalirao Tumbleweed sa KDE. Nikada ranije nisam birao KDE okruženje, ali pomislio sam da je v6 dobra početna tačka. Zanimljivo mi je što se teme pišu low level cpp i kompajliraju, i neke koje su baš odlične fale za v6. Trenutno nemam vremena da se bavim izgledom ozbiljnije, ali sporadično ću nastaviti da tražim neki zaobljeni izgled sa pastelnim bojama. Ako neko ima predlog slobodno neka napiše, radi ću da isprobam.
Neočekivano sam imao problem da namestim video reprodukciju sa nVidia drajverima u Firefoxu. Morao sam da dokumentujem u dotfiles, jer ne želim da prolazim ponovo kroz istraživanje šta i gde fali od kodeka. Komedija je što sve funkcioniše kako treba od starta u Edge (flatpak grdosija).
    2.9 MB · Pregleda: 146
Tema je "kako izgleda vaš linux desktop" a ne terminal i pozadina. 😄
Prešao na Wayland sesiju na silu, pa sam rešio to što se miš ne crta u virtualnim mašinama u Virtualboxu tako što sam prešao na virt-amanger. :D
Pogledajte prilog 498477
Da li si osetio poprilično bolji odzviv na Wayland-u u odnosu na X ? Zadnji put kad sam probao Plazmu na Arch-u, razlika je bila neverovatna. X sesija je toliko bila spora, da je skoro pa neupotrebljiva. Wayland bukvalno leti.
Jedina razlika koju sam primetio (ili umislio) je da se KRunner pokreće dosta brže na Waylandu u odnosu na X11. To je dosta bitna stavka jer aplikacije uglavnom porekećem tako što pokrenem KRunner korišćenjem prečice na tastaturi i onda krenem pretragu imena aplikacije i enter. Onaj standarni KDE meni koristim samo kada menjam ikonicu aplikacijama.
Nisam ulazio u analizu ove razlike, niti planiram. Sve ostalo je brzo kao na X11, ili mi se bar tako čini.
