Samsung televizori
MarcusS
CPU & Cooler
Ryzen 5700X3D & ID-COOLING XTS 224
Matična ploča
AsRock B550m STEEL LEGEND
RAM
2x16 GB Corsair Vengeance RGB PRO sl 3600mhz
GPU
Sapphire PURE 7700XT 12GB WHITE
Storage
M.2 Kingston KC3000 512GB + 2TB Toshiba + 4TB Seagate
PSU
Cooler Master Bronze 750w
Kućište
Zalman S5 White
Monitor
Benq Zowie XL2540K
Miš & tastatura
Logitech G910 spectrum & Logitech Superlight l mouse
Ostale periferije
Logitech G PRO X
Mobilni telefon
Honor Magic 7 Pro
Pametni uređaji
Garmin Venu 3
Pristup internetu
  1. Kablovski internet
Ako ima tema ispravite me, pretražio sam sve dva puta 🙂
Ima li neko info o ovom modelu, pošto vidim da ima svega 7, 8 strana na google-u o njemu: Samsung QE65Q82RATXXH
We are now streaming HDR10+ content on our service for AV1-enabled devices, enhancing the viewing experience for certified HDR10+ devices, which previously only received HDR10 content.
Unlike HDR10+ and Dolby Vision, HDR10 uses static metadata for an entire film or TV show, a “one-size-fits-all” approach to tone-mapping that could produce less accurate lighting, especially in very bright or very dark scenes.š
To enhance our offering, we have been adding HDR10+ streams to both new releases and existing popular HDR titles.
Konačno alternativa u rangu Dolby Vision na Samsung televizorima 🙂
Pitanje u vezi samsung tva. Ima mu vec 4-5 godina, radio je odlicno sve do pre neki dan. Pocela je da "igra" slika sa desne strane tva, kao da blinka, posle nekog vremena se smiri, ali nastavi. Zna li neko sta moze da bude?
Vidim da uz ove nove modele iz 2025 ima promocija 5 god.garancije plus poklon soundbar.E sad kako naručiti i videti koje su cene kad nema ni kod jednih u ponudi a promocija traje do 25.5.?
a baš kad sam hteo da kupim
Od 2. juna do 13. jula 2025. godine, kupovinom QLED, OLED, Neo QLED i The Frame modela televizora iz 2025. i 2024. godine dimenzija 55’’ i većih ostvaruješ 3 godine dodatne zaštite. Dok kupovinom QLED, OLED, Neo QLED i The Frame modele televizora iz 2025. i 2024. godine dimenzija 65’’ i većih kao i Crystal UHD modela dimenzije 98”, na poklon dodatno poklanjamo i Galaxy Watch7 u vrednosti od 44.999 RSD*
  • Matte panel gives blacks a greyish look in brighter environments
  • QD-OLED color fringing
  • Micro-stutter, poor motion smoothing
  • Raised blacks/flicker in VRR
  • Ads in Tizen
U minusu treba dodati i nedostatak Dolby Vision podrške jer Samsung forsira HDR10+
Poručio sam S90D 65" OLED posle dugog razmatranja šta uzeti.
Proučio sam i video da S90D dolazi i sa WOLED i sa QD OLED panelima i uspeo da pronađem da ovaj 65 ima QD OLED. Da li ima potrebe obratiti pažnju na još nešto sem toga?
Čestitke na kupovini, isto sam njega gledao ali nam nije bilo sudjeno.. Jesi siguran za panel da je QD?
Pre nekih mesec-dva kada sam kontaktirao samsung korisnički servis mi je rečeno da je u Evropi sav S90D sa woled panelima nezavisno od veličine ekrana.. Mada, kakvi su pajseri ispali posle kod mog poručivanja, ništa me više ne bi iznenadilo 😄
Hvala! Za koji si se ti na kraju odlučio?
Sudeći po onome što ljudi pišu na netu, može se po oznaci TV-a odgonetnuti koji je panel. Na primer ovaj je QE65S90DATXXU dok sve ostale veličine (48, 55, 77 i 83") nose oznaku QE48S90DAEXXU. Poslednja 4 slova navodno označavaju panel. Kod S95D u svim veličinama ide QD-OLED i svaki nosi oznaku QE65S95DATXXU.
Po tome se može zaključiti koji su panel ubacili. Ali potvrdiću kad TV stigne do mene. Nadam se da je internet u pravu 😀
Ne označavaju nužno panel, ali iz gorenjeg teksta se može zaključiti da svi sa T oznakom u imenu proizvoda će biti sa QD OLED panelom. Potvrdiću čim stigne TV do mene 🙂
Evropa je navodno u S90D dobila QD OLED samo u 65" veličini, ja sam poručio 65-icu samo iz tog razloga.
Ja sam uzeo s90d 65", isto sam gledao te oznake i po tome sam mislio da je qd oled. Kako da potvrdim da je qd oled?
Raspored pixela na samom panelu, možeš fotkati izbliza pa ćeš odmah videti.
Evo primera (levo je WOLED, desno QD OLED):
    17.8 KB · Pregleda: 62
Do daljnjeg sam odlučio da čekam, iako često pomislim da možda nisam trebao da otkažem porudžbinu.
Za sada nam super i dalje radi 75NU8005, koji već evo osam godina bez ikakve veće zamerke šljaka. Ostaje mana refleksija (popodne nam je sunce sa te strane dnevne sobe), i jelte crna boja. Toga nekako nismo ni bili svesni u nekoj svakodnevici, al kad se prebacim neki put sa gledanja filma na tabletu na sadasnji tv, bas se iznenadim kolika je razlika u mračnim scenama 🫣😂 ovo ipak iz ugla mene kao prosečnog korisnika, verujem da bi neko drugi našao hiljadu mana..
Da je taj nesudjeni S90D 77 bio sa QD panelom, onda mislim da ne bih ni otkazivao.. ovako je ostalo da čekam neku drugu priliku.. drugar je bas pre par nedelja kupio S95D i jedva čekam da bacim pogled na njega, nešto me vuče da se isprsim možda za njega neki sledeći put na akciji..
Preuzeo sam televizor (S90D 65") i potvrdjujem da je QD-OLED panel u pitanju. 😎
    364.8 KB · Pregleda: 41
Da nije slučajno neko imao prilike da uživo iz prve ruke uporedi woled i qd oled od samsunga? Opet mi je iskočio s90d woled na akciji, i baš me muči čekanje na s95d koji nikako da se nadje na nekom iole značajnijem popustu. A terenutno je razlika tolika da mogu da kupim 2 woled s90d za cenu jednog s95d u istoj dijagonali.. i jos da mi ostane nesto para pride, ne verujem 😳
