NVIDIA Shield (svi modeli)
Emulira li neko retro igre preko Shielda? I ako da, koje gamepadove koristite? A da nije original, teško se nalazi :)
Xbox 360 ili One? Wireless ili wired?
Meni nesto kao da je imalo lag. Možda nisam samo prebacio na game mode TV.
Meni je shield 2015. i dalje na androidu 9.1.1 isplati li se upgrade?
Zbog čega bi radio upgrade?
Ne znam, samo pitam, ima li realno potrebe kupiti noviji shield, ili sem onog AI upscale to je sve isto?
Koliko znam 9.1.1 je poslednja verzija za shield 2015. Što se tiče vredi li prelaz na shield 2019 pro pa i ne baš osim cpu osveženja, Dolby vision, AI upscaling, manjeg skladištenog prostora, BT 5.0
SHIELD Experience Upgrade 9.2​
Op op za nas malobrojne :)
Meni malopre stiglo
New or Upgraded Apps
AURO-3D
This update unlocks full support for playback of high-resolution immersive sound in AURO-3D over HDMI. Connect your NVIDIA SHIELD TV Pro to an AURO-3D compatible decoder and enjoy the most natural 3D sound experience from streaming apps such as Artist Connection.
Enhancements
  • Added support for Match audio content resolution feature when using a USB DAC
  • Added ability to clear HDMI 1.4 flag via factory reset
  • Added match Frame Rate (beta) enhancement
  • Added French parental control
  • Added security enhancement for 4K DRM playback
Known Issues
Resolved Bugs
  • Fixed choppy video playback after FFWD/RWD operations
  • Fixed remote stops responding for 60 seconds after wake from sleep
  • Fixed SHIELD waking from lock screen without a button press
  • Fixed issue with large file transfer to NAS (operation not permitted error)
  • Fixed Google signing flow stuck in a loop
  • Fixed stutters in Bose and Sony headsets while connected to 2.4Ghz Wi-Fi
  • Fixed audio stutter in aptx supported headsets
  • Fixed AV sync issues when Dolby Processing is enabled
  • Fixed crash on volume change
  • Fixed Apple Music corruption during casting
  • Fixed Spotify empty playback when Match Audio Content resolution is enabled with Stereo Upmix
  • Fixed Google Assistant not starting after Google GMS update
  • Fixed full screen SHIELD Rewards notification issue
  • Fixed Wi-Fi log filling up storage
  • Fixed SHIELD drive filling up
  • Fixed no audio heard when headset is connected to controller and DAP is on
  • Fixed Geforce NOW crash after launch
  • Fixed video distortion on "RGB 8-bit Rec.709" display mode
  • Fixed USB HDD/Flash drive showing corrupted after hotplug
  • Fixed NAS folder info shows 0 B and not the actual capacity
  • Fixed mounted storages not listed after upgrade
  • Fixed occasional crashes in DRM apps
  • Fixed when Alexa SHIELD Skill cannot locate SHIELD TV device
Lost ability to control SHIELD with Google Home after taking upgrade
Vidim temu na Redditu od pre godinu dana (ili više?) u kojoj neki kažu da su tek danas dobili taj update.
Полако... Стићи ће и HLG на ред. Битно је да су сва 4 корисника AURO-3D задовољна. 😁
Da li neko ima instaliran apple music na shield-u...hocu da vidim da li sada moze da poera hi-res fajlove
AURO-3D
Enhancements
Known Issues
Resolved Bugs
Da li se sva ova unapređenja odnose i na model iz 2015-te?
Da li je neko instalirao ovaj apdejt i osetio neke blagodeti?
Ja nisam primetio nikakvu razliku na 2019 pro.
Šta treba da se desi da izbace novi model? 😅 Nekako imam osećaj da čim uzmem '19 pro ima da objave novi model.
Vidiš da ih i gaming grafičke sve manje interesuju. Mislim da im je novi Shield poslednja rupa na svirali.
Možda dogodine nakon što se rasproda kontigent Switcheva. A možda i ne :D
Dobar je ali nije Shield nivo dobar. Moraš da praviš kompromise. Npr. da koristiš Kodi umesto Plexa ili Plex u okviru Kodi-ja.
The Plex client can passthrough TrueHD and DTS-HD MA just fine. DTS:X and Dolby Vision profile 7, it cannot
