Mislio. sam.... to znaci da ti svaki put kada skidas i stavljas nazad plocu, pomeras svoj bed iz ravni jer je na oprugama/silikonu.Nešto od ovoga, šta najmanje smeta.
U februaru se ocekuje neki novitet od njih, mozda tada...Zna li neko, ili da li moze da pretpostavi, kada bi moglo da se ocekuje da na sajtu BambuLab-a bude opet popust za P1S (ili P1P) model, kao sto je bio za Black Friday?
Ima li neki link za tu informaciju? Hvala.U februaru se ocekuje neki novitet od njih, mozda tada...
Yamaha AX-570 Amplifier Bass/Treble Knob by Dani_93
This is a replacement Knob for Bass/Balance/Treble on older Yamaha amplifiers. Mine was the AX-570. I designed it but in the end i don´t need to print it cause i found some original Knobs. That means I don´t tested if the print would fit but i measured the original one for this construction. So...www.thingiverse.comNisam našao onaj drugiYamaha (KX 670) tape deck balance/rec-level knob by DrMaRV
As I bought a used tape deck, it has a missing balance knob and so I decided to print my own for repairing the deck. Here is the result.www.thingiverse.com
