djalf
DJ u penziji
Nadjoh ovo za RTX 30XX seriju i 16GB RAM pa probajte:
Kod:
1. Install Nvidia latest driver hotfix if you have a RTX 30 series gpu's
531.58 [https://nvidia.custhelp.com/app/answers/detail/a_id/5455].
2. uncheck "read-only" from last of us game folder (includes all sub-folders and files).
3. go to properties of both "tlou-i-l.exe & tlou-i" in game dir. and check run this game as administrator.
4. go to nvidia control panel, then manage 3d settings, then program settings, then find "the last of us" game and Turn ON low latency mode (Helps little with stuttering issues).
5. Create a paging file if you have 16gb ram (Initial size: 24576 MB; Maximum Size: 49152 MB) [Fix most of the crashes].
6. Go to graphic settings of the game and set these optimized settings explained in this video (https://youtu.be/eqqgW_7hosY?t=865).
7. Wait for the shaders to built (Approx 45-60 Minutes)
