| Size | 3.38” x 3.38” x 2.99” (86 mm x 86 mm x 77 mm) |
| Weight | 513 g |
| Processor | Octa-core 4x 2.2GHz 4x 2.0GHz |
| GPU | 800MHz |
| Storage | 16 GB internal |
| Memory | 2 GB internal |
| Wi-Fi | Wi-Fi 6E Tri-band. Also supports 802.11a/b/g/n/ac/ax wifi networks. For Wi-Fi 6E support, Fire TV Cube must be connected to the 6GHz band of a Wi-Fi 6E network using WPA3 encryption. |
| Bluetooth | Bluetooth 5.2 + LE. Pair with compatible Bluetooth speakers, headphones, and more. |
| Voice support | Far-field and near-field voice support |
| Voice control compatibility | Controls a wide range of IR-enabled devices, including TVs, soundbars, and A/V receivers. Learn more about IR-enabled supported devices. |
| Cloud storage | Free cloud storage for digital content purchased from Amazon |
| Ports | HDMI Input, HDMI Output, IR Extender, Power, USB-A, Ethernet port |
| Audio support | Dolby Atmos, 7.1 surround sound, 2-channel stereo, and HDMI audio pass through up to 5.1. |
| 4K support | To watch movies and TV shows in 4K Ultra HD, you need a compatible 4K Ultra HD TV. All services may not be available in 4K/HDR. Certain services are subject to change at any time, may not be available in all areas, or in 4K/HDR, and may require separate subscriptions. Learn more about services. |
| Content formats supported | Video: Dolby Vision, HDR 10, HDR10+, HLG, H.265, H.264, VP9, AV1, Audio: AAC-LC, AC3, eAC3 (Dolby Digital Plus), FLAC, MP3, PCM/Wave, Vorbis, Dolby Atmos (EC3_JOC), Dolby MAT, Photo: JPEG, PNG, GIF, BMP |
| Output resolution supported | 2160p, 1080p and 720p up to 60 fps |
Ко ти је рекао да нема AV1 подршку?
Size 3.38” x 3.38” x 2.99” (86 mm x 86 mm x 77 mm) Weight 513 g Processor Octa-core 4x 2.2GHz 4x 2.0GHz GPU 800MHz Storage 16 GB internal Memory 2 GB internal Wi-Fi Wi-Fi 6E Tri-band. Also supports 802.11a/b/g/n/ac/ax wifi networks. For Wi-Fi 6E support, Fire TV Cube must be connected to the 6GHz band of a Wi-Fi 6E network using WPA3 encryption. Bluetooth Bluetooth 5.2 + LE. Pair with compatible Bluetooth speakers, headphones, and more. Voice support Far-field and near-field voice support Voice control compatibility Controls a wide range of IR-enabled devices, including TVs, soundbars, and A/V receivers. Learn more about IR-enabled supported devices. Cloud storage Free cloud storage for digital content purchased from Amazon Ports HDMI Input, HDMI Output, IR Extender, Power, USB-A, Ethernet port Audio support Dolby Atmos, 7.1 surround sound, 2-channel stereo, and HDMI audio pass through up to 5.1. 4K support To watch movies and TV shows in 4K Ultra HD, you need a compatible 4K Ultra HD TV. All services may not be available in 4K/HDR. Certain services are subject to change at any time, may not be available in all areas, or in 4K/HDR, and may require separate subscriptions. Learn more about services. Content formats supported Video: Dolby Vision, HDR 10, HDR10+, HLG, H.265, H.264, VP9, AV1, Audio: AAC-LC, AC3, eAC3 (Dolby Digital Plus), FLAC, MP3, PCM/Wave, Vorbis, Dolby Atmos (EC3_JOC), Dolby MAT, Photo: JPEG, PNG, GIF, BMP Output resolution supported 2160p, 1080p and 720p up to 60 fps
Ima na Amazonu ali su skupi, probaj na Aliju tamo su oko 10$Ima li da se kupi negde remote za 4k max? Mlađi sin ga je toliko puta bacio da je jednostavno prestao da radi. 😭
Ne znam što ti transkoduje dd+ kada shield podržava dotični?!Nisam upratio sta ti nije radilo na Nvidia shieldu pa si presao na kocku?
Ja imam na Nvidia shieldu problem preko pleksa radi mi transcode eac3 audio.
Ostalo sve dobro radi.
Претреси тему - качио је неко кодове за ЕОН и Ирис.Jel može pomoć kako da instaliram eon smart tv app na 4K max? Nešto lutam, nema ga u njegovom store-u... Isto važi i za Iris ap
preko cega pustis sve arene odjednom? 😀
Nasao sam kodove, mada nisu bas azurirani za poslednje verzije aplikacija. Najlakse sam prebacio apkove sa kompa preko anydesk-a koji svakodnevno koristim. Njega sam nasao na storu i posle toga ide lagano prebacivanje fajlova i instalacija sa samog sticka preko X-explorera.Претреси тему - качио је неко кодове за ЕОН и Ирис.
Није битно који су канали. А у питању је Тивимејт апликација (TiVimate).preko cega pustis sve arene odjednom? 😀
