Diskusija o cenama
Salje mi Poloniex poruku, delistuju usdt, a ja kao imam nesto. Udjem posle 3 godine, nema nista, lazovi, samo da navuku stare korisnike. Nego aj reko kad sam vec iskopao kljuceve za 2FA da udjem i na Binance. Ostalo mi 50$ kada sam vracao pare nazad na druge menjacnice onomad kada su nas stavili na crnu listu. Kad tamo ostalo mi oko 130 icon-a, reko prebacicu kad me ne bude mrzelo i tako i ostalo. Evo skocio na 2.7 i ja ga sibno, 360$. Kupio sam Ltc za sve pare. Ajmo, ajmo Ltc 😄
Mnogo je gresaka u tvom postu😀. Jesi siguran da delistuju USDT? Delistuju USDT na OMNI mrezi ukratko. Ako neko i ima USDT na OMNI mrezi ne mora nista da radi Poloniex ce sve automatski da odradi i da prebaci vas USDT na ETH ili TRON mrezu.
"If you're receiving this message it is because you currently hold a balance in USDT, or have generated a USDT on OMNI address.
We want to clarify some confusion that has arisen from our last communication: We are not delisting USDT, we are removing the ability to interact with USDT on the OMNI protocol. USDT transactions will now be available via the ETH network and TRON network. All of your funds are safe.
USDT on OMNI is currently enabled. On April 30, 2021, we will migrate your USDT to a new chain. There is no action required on your part."
HOT otisao na 0.017, nazalost ja sam ranije prodao vecu kolicinu, ko je uzeo pre par dana na 0.007 ovo je odlicna zarada.
Sto volim ovo kad refresujem portfolio na binance, a ono svaki put skace po 10-20$ :)
Jel mislite da se polako altovi vracaju u usdt, ne verujem da ce rast jos dugo?
Bolje u btc nego usdt ;)
omi, reef, cro, srk, bepro
Imho sve to ima potencijala da još vozi ako situacija dozvoli.
Zakazan novi launchpad na Binance:
Binance will record user BNB balances for 7 days from 2021-03-31 0:00 AM (UTC) to 2021-04-07 0:00 AM (UTC). The final BNB holding amount for each user will be determined as the average of the 7 days, using the Daily Average BNB Balance calculation previously announced here.
TKO Token Sale Details:
  • Token Name: Tokocrypto (TKO)
  • Launchpad Hard Cap: 7,500,000 USD
  • Hard Cap Per User: 20,000 USD (200,000 TKO)
  • Total Token Supply: 500,000,000 TKO
  • Total Tokens Allocated to Binance Launchpad: 75,000,000 TKO (15% of Total Token Supply)
  • Public Sale Token Price: 1 TKO = 0.10 USD (price in BNB will be determined prior to subscription)
  • Token Sale Format: Subscription
  • Supported Sessions: BNB only
E do mojega, prebacio sam neke altove, pre 2 dana sa kojima sam bio u plusu, u Bnb na 260 i prodao na 290 malopre...
pratice stanje bnb novcica u periodu 2021-03-31 0:00 AM (UTC) - 2021-04-07 0:00 AM. Posle racunaju prosek za taj period i tu prosecnu vrednost bnb-a mozes zameniti za nov novcic.
Znam, ali razmisljam dal da kupujem sad, vidis da irece pumpanje, verovatno zbog toga. Sad ce da ode na 300+, prekosutra vec moze da padne opet na 260...
krece onoliko koliko i btc/$ , sto u principu za promenu nije lose ,mada uvek moze opet da se podvuce :)
--4%-LTC-target-progress---------------------------------->>
Pa ako si prodao za 290, što bi kupovao sad na 295-300 :)
Sačekaš da padne ako će padati, a ako produži gore, *** - proš'o voz, tražiš drugi novčić i ćao...
Ako je ovakav sistem,onda se isplati whaleovima :D
nema veze da li si whale ili ne, kad je max po user-u 20000$...
Hard Cap Per User - 20,000 USD (price in BNB will be determined prior to the start of subscription)
a ako si whale sa 20000$, onda stvarno :)
edit:
Ja ću se svakako poigrati i ovaj put za deo bnb-a, a za deo sam postavio sell order-e sve do 350$ ( to mi više odgovara ako prođu :) ) u slučaju da bnb izdivlja u ovih par dana.
edit:
Definitivno je bolje da ti prodje order, jedan od tih coina ima da pukne samo tako, pitanje je koji. A nekoliko prethodnih su bili isplativi samo neposredno nakon izlaska...
mislim da brkaš pojmove Launchpad i Launchpool 😀
Ne mozes biti nikako u minusu jer tokene dobijes free.
U principu ne mozes otici u minus ni sa launchpool-om, pod uslovom da ne glumis trejdera i “nadas se” da će skočiti.
Tu isto dobijas free novcice ali stejkovanjem, pa koliko god dobijes free - mislim da je odlicno. 😀
Trebalo bi prvo da dobro pročitas uslove za učestvovanje, pa će ti onda biti sve jasnije.
Sada ako ne krene litecoin ne znam kada ce ?!
Kad te nada napusti i dignes ruke. Prvo mora da ti pokida sve, do poslednje zivca, pa ce tek onda da krene. 🤬
Sad vec pocinje i mene da nervira pomalo. Nijednog trenutka ne sumnjam da li ce krenuti ili ne da smara nego ubija. LTC holderi ce slaviti kad konacno bude krenuo, gorece net.
Ako sutra nesto ne uradi i ja dizem ruke...
Ja sam počeo da polako gradim long poziciju.
Iskreno, ne mislim da će ispod 50k, mada ću i ja postaviti 2-3 ordera ispod 50k, čisto da smanjim ulaz ako ode.
Imam još tri ordera postavljena na svakih -1000, pa lagano...
Dosta će longova biti likvidirano ovih dana ( već je krenulo polako ), pa se može držati opušteno otvoren long, a i funding se lepo resetovao.
Target i dalje ostaje 72-75k, very soon.
edit:
Od altova sam polako krenuo da dokupljujem ADU, i videću još neke dobre da nađem koji budu najviše iskrvarili ovih dana.
Pogledajte prilog 301551
Buy the dip!
Ja sam zadovoljan sa mojom Adom. Meni je sad oko +10% na ovom trejdu, ali je ne diram do daljnjeg
Ovde sve manje i manje pametnih stvari da se pročita. Pratim ovaj forum od 2016te i iskusniji ljudi uporno ponavljaju da day-trading nije za neiskusne. Ta mrtva ada je napravila skok od 600% u poslednja 3 meseca, a marcet cap je trenutno 33 milijarde evra. Znam da svi očekuju neverovatne zarade, ali gledajte ljudi u šta ulazite i u kom momentu. Samo izračunajte šta znači još jedan skok od 600% za Adu u market kapu? Pa čak i taj od 10%.
Od mene, podrška starijim članovima na temi koji gledaju i dalje na bar 3+ meseca. Zog vas po mom mišljenju ova tema i dalje ima neku vrednost.
Izgleda da smo je prozvali, ko da bi krenula al nesto sramezljivo :) bnb skoro do 310... Ko ga ne proda na ovu cenu taj je lud, garant ce da se sroza posle ovog pumpanja zbog ovih coina...
Zavisi od strategije onog koji trejduje, niko ne prica ovde nista nerealno, ja konkretno idem 80% short i zadovoljavam se 10-20%. Ako je do sada vec 5 puta isla od 1 do 1.30 sta tu tebi nije pametno u ovom ciklusu gde ima stalne oscilacije? Ja sam na par coina poslednjih mesec dana po 3 i vise puta uzimao 15-30%, konkretno na hot,dent,rose i vise... I po tvojoj logici sad kad bude pad, je treba vise da kupujem nista jer to nije pametno?
Pa uključi se i ti u diskusiju, da i mi naučimo od tebe nešto ako je moguće...
Kao nemi posmatrač i čitač, ovakvim komentarima ne doprinosiš apsolutno ni malo :)
