danilo989
- AMD Ryzen 7 5800X3D, Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
- MSI MPG B550I Gaming Edge Wi-Fi ITX
- 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
- PowerColor Radeon RX 7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
- Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
- Zvuk
- Altec Lansing 220, HyperX Cloud II
- Corsair SF750 Platinum 750W SFX
- Cooler Master NR200P ITX
- Monitor
- Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
- Miš & tastatura
- Endgame Gear OP1 8K, HyperX Alloy Origins Aqua
- Ostale periferije
- APC BX1400U-GR
- Kablovski internet
Izgleda da sam izvukao deblji kraj sa mojim ADATA Gammix, SM2262G i Samsung 64L NAND
Kod:
Drive : 2(NVME)
Scsi : 1
IOCtl: NVME_OF failed 0x45d!
Driver : W10
Model : XPG GAMMIX S11 Pro
Fw : 32B3T8EA
LBA Size : 512
Controller : SM2262 [SM2262AB]
FW revision: 32B3T8EA
ROM version: 2262ROM:SVN00235
Bank00: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank01: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank02: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank03: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank04: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank05: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank06: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank07: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank08: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank09: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank10: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank11: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank12: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank13: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank14: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank15: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank16: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank17: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank18: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank19: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank20: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank21: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank22: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank23: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank24: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank25: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank26: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank27: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank28: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank29: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank30: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Bank31: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
--- Experimental ---
FlashID : 0xec,0x1c,0x98,0x3f,0x84,0xcb,0x0,0x0 - Samsung 3dv4-64L TLC 16k 256Gb/CE 256Gb/die
Channel : 8
Ch map : 0xFF
CE map : 0x0F
First Fblock : 1
Total Fblock : 1426
Bad Block From Pretest: 4
Start TLC/MLC Fblock : 68
DRAM Info : [0x4F 0x52]
DRAM Size,MB (*) : 1024
DRAM Bus,bit : 32
DRAM Type : DDR3
DRAM Vendor : Samsung
(*) - Possible incorrect
Telemetry v8
