Endurance measured
For the battery life, we adjusted the settings of the two versions of S21 Ultra to be the same (fixed screen brightness at 50%, volume at 50%, and turned on airplane mode), and used PCMark’s battery life test to test the phone’s power from 100% to 20 % time. First, with the screen update rate maintained at the default "optimized" setting (up to 120Hz), the Qualcomm S21 Ultra ran out of 11 hours and 14 minutes of battery life, while the S21 Ultra Orion version had a battery life of 6 hours and 46 minutes. , S21 Ultra, which represents the S888 version, has a much higher endurance performance than the Orion version. For comparison, last year's Samsung Qualcomm S865 version S20 Ultra also equipped with 5000 mAh battery, ran out of 9 hours and 47 minutes of battery life in 120Hz mode, and 15 hours and 1 minute in 60Hz mode. ▲ The Qualcomm version of S21 Ultra has an endurance score of 11 hours and 14 minutes at 120Hz. ▲ Orion version of S21 Ultra, running 6 hours and 46 minutes under 120Hz endurance score. In addition, we also used the Qualcomm version of S21 Ultra, adjusted the screen update rate to 60Hz and ran the PCMark battery life again. The results have not been released before the deadline, and we will add them when there are results; but because the Orion version can be tested for a short time, Therefore, there is no endurance test for the 60Hz part.
