Ma to mačku o rep da znaš. To su ko zna koji sajtovi na jedan piše won't come na drugi piše confrimed.Pa zvanicno potvrdjeno. Negde smo kacili ovde vesti.
Ma mislim da ce biti u najmanju ruku za kinesko trziste pa cemo ga preraditi.Ma to mačku o rep da znaš. To su ko zna koji sajtovi na jedan piše won't come na drugi piše confrimed.
EMUI 9 je *mjau**mjau**mjau**mjau**mjau**mjau* jedno veliko samo da znaš, razmisliću 5-6 puta dal da se bakćem uopšte sa tim. Recent apps mu je brutalno retardiran.Ma mislim da ce biti u najmanju ruku za kinesko trziste pa cemo ga preraditi.
Kod mene je Meni na srpskom jeziku "Id fingerprint" se nalazi u opcijama Bezbednost i privatnost 5 grupa podešavanja od dole u meniju.
Use the fingerprint sensor to unlock the screen, access the Safe and App Lock, and authorize payments in third-party applications.
For added security and to ensure that you can still access your data if your phone fails to recognize your fingerprint, you will need to set a backup password when configuring fingerprint unlock.
Step 1 OpenSettings and touch Fingerprint ID > Fingerprint management.
Step 2 Select PIN or Password, and then follow the onscreen instructions to set a screen lock password.
Step 3 Once you have configured the password, touch New fingerprint to add your fingerprint.
Step 4 Place your fingertip on the fingerprint sensor. Press down lightly on the sensor until your phone vibrates. Repeat this step using different parts of your fingertip until your phone has successfully added your fingerprint.
Step 5 Once you have added your fingerprint, touch OK.
On the Fingerprint management screen, turn off the Unlock screen switch to disable fingerprint unlock.
Hvala obojici. Nisam našao iz prve, morao sam prvo da restartujem telefon, posle toga sam uspeo sve da odradim.![]()
Sent from my 3310
Auuu kao kod mene na ove najnovije buildove. Strašno. Ovaj telefon varira od modela do modela. Šta da ti kažem, jedino da se vratiš servisnim.B321 i morfuz 2.1
Katastrofa
Pogledajte prilog 258570Pogledajte prilog 258571
Poslato sa WAS-LX1 uz pomoć Tapatoka
Nesto ti nije tu dobro. Kad fleshujes b321 onda mora factory reset pa tek onda dalje sta nameravas. A i nesto ti je signal katastrofa.... Evo kod mene trenutno kako je na b321, morfuz 2.1 governors darkness-blu active.B321 i morfuz 2.1
Katastrofa
Ja opet sa druge strane sam prezadovoljan Huawei telefonom i verovatno će sledeći moj telefon biti opet Huawei. Ja lično nemam taj dojam da se radi o jeftinom telefonu, što se tiče tih abdejta ne očekujem ništa spektakularno obzirom da sam zadovoljan radom telefona, naravno uz svo uvažavanje vaše patnje bez namere da provociram. Takođe sam siguran da se ne bih zadržavao na nekom telefonu ukoliko mi on ne odgovara nego bih ga prodao i uzeo neki drugi model.
Obavezno uradim factory reset uvek isto su darknes i blue governori. Stavio sam sad b367 direktno iz hwota i naravno stock kernel deluje mi bolje, juče skinem ga sa punjača bilo je b321 i morfuz 2.1 i odmah sa 100% na 97 čim sam skinuo... Moguće da je nešto do punjača izgubio sam originalni pa punim nekim kineskim... [emoji23]Nesto ti nije tu dobro. Kad fleshujes b321 onda mora factory reset pa tek onda dalje sta nameravas. A i nesto ti je signal katastrofa.... Evo kod mene trenutno kako je na b321, morfuz 2.1 governors darkness-blu active.
Znaci ovo je perfektno, a i plus sam ga drndo sa onim kernelom v5 ranije sto je bio sve zeznuo.
Pogledajte prilog 258590Pogledajte prilog 258591
Nešto tu ne štima... Kolki ti je SOT na b367? I jesi radio kalibraciju baterije posle flasha?Obavezno uradim factory reset uvek isto su darknes i blue governori. Stavio sam sad b367 direktno iz hwota i naravno stock kernel deluje mi bolje, juče skinem ga sa punjača bilo je b321 i morfuz 2.1 i odmah sa 100% na 97 čim sam skinuo... Moguće da je nešto do punjača izgubio sam originalni pa punim nekim kineskim... [emoji23]
Nisam ni jednom do sad radio kalibraciju sot je negde oko 4h max...Nešto tu ne štima... Kolki ti je SOT na b367? I jesi radio kalibraciju baterije posle flasha?
Meni je na b321 sa Morfuzom i puno aplikacija, lepo namešten Doze i Launch, baterija kalibrisana, punjač njegov ili powerbank 4h 56min max za dva dana. Za jedan dan mislim oko 6h. A na one nove buildove maksimum 2h 50min SOT.Nisam ni jednom do sad radio kalibraciju sot je negde oko 4h max...
Pise za Morfuz kernel da treba pustiti jedan full charging discharging da iskalibrise. Ali ti sa tim punjacem si ga nesto uxjbo i zato ti se tako ponasao, abnormalno.Obavezno uradim factory reset uvek isto su darknes i blue governori. Stavio sam sad b367 direktno iz hwota i naravno stock kernel deluje mi bolje, juče skinem ga sa punjača bilo je b321 i morfuz 2.1 i odmah sa 100% na 97 čim sam skinuo... Moguće da je nešto do punjača izgubio sam originalni pa punim nekim kineskim... [emoji23]
Nikad na nijednom telefonu nisam radio kalibraciju a prošle godine sam imao alcatel 5025D nema kakav rom nije prošo kroz njega i evo i dan danas radi normalno i batetija i sve...Meni je na b321 sa Morfuzom i puno aplikacija, lepo namešten Doze i Launch, baterija kalibrisana, punjač njegov ili powerbank 4h 56min max za dva dana. Za jedan dan mislim oko 6h. A na one nove buildove maksimum 2h 50min SOT.
Tako ja na moj stari LG. Na ovaj sve mora školski [emoji849][emoji52].Nikad na nijednom telefonu nisam radio kalibraciju a prošle godine sam imao alcatel 5025D nema kakav rom nije prošo kroz njega i evo i dan danas radi normalno i batetija i sve...
Baš to. Ja sam se sva sreća uspeo primirim na b321 sa solidnim rezultatima. Ja mislim nikad više Huawei.Na ovom sve skolski,sve zivo iskombinujes i na kraju ispadne dodje mu sve na isto.
Pa nemamo mnogo izbora.Baš to. Ja sam se sva sreća uspeo primirim na b321 sa solidnim rezultatima. Ja mislim nikad više Huawei.
Pa mislim da nisam uspeo da se primirim skrcao bi ga hahahahhaahhaPa nemamo mnogo izbora.
Ne znam telefon je hardverski stvarno dobar uživam u 4GB RAMa i komforu koji pruža, a i baterija od 3000mah bi trebala da kida bre. Samo što je softverski jedno veliko *mjau**mjau**mjau**mjau**mjau**mjau*.Ja ovaj moj,vec drmnuo dva puta o patos 😀 Sreca njegova,sto je dobra zastitna maska 😀
Ti to iz iskustva [emoji1787][emoji1787][emoji1787][emoji1787][emoji1787]Huawei is the best of the best! [emoji1][emoji1][emoji1]
Huawei do pobede [emoji1][emoji1][emoji1][emoji1][emoji1][emoji1]Ti to iz iskustva [emoji1787][emoji1787][emoji1787][emoji1787][emoji1787]
Stvarno treba promeniti ime teme u Huawei hate section hahahahahah.Huawei do pobede [emoji1][emoji1][emoji1][emoji1][emoji1][emoji1]
