Xiaomi Redmi Note 4
  • Začetnik teme Začetnik teme ZAP
Samo još da nije tako ružan 😀 Subtratum beše, i čime da promenim status bar ikonice? (signal, wifi etc...)
Evo sa ovim - xposed modul je u pitanju...
Sent from my Redmi Note 4x
Zile to ovaj 15/03? Kako sada radi, jel uporedivo sa 14.1?
@kamango604 Nije ovo LOS, već Generic System Image za sve Android uređaje koji imaju omogućen Treble. https://forum.xda-developers.com/showthread.php?p=74622427
Nije uporedivo, još malo im fali da dostignu taj nivo, ispeglaće abhishek A1 i RN4 sigurno 🙂
15/03 LOS15.1 je bolji od onog 18/02 LOS 15.1, vidi se napredak.
Zile, super ovo izgleda, malo cu da se poigram kad budem imao vremena.
Ima li nesto za izgled notifikacija i shortcut iconica? Moze li da se doda ime ikone?
Sent from my Redmi Note 4X using Tapatalk
Jel neko istestirao poslednji MUI HMNote4XGlobal_V9.5.4.0.NCFMIFA?
Baterija i tako to...😀
Wayang[emoji769]v1.4 Kernel (Miui, Nougat, Oreo)
Specifican je zbog "Schedutil" cpu governor-a - Energy Aware Scheduling (EAS)
https://forum.xda-developers.com/showthread.php?t=3766901
EAS:
Energy Aware Scheduling (EAS) is an enhancement to Linux power management, unifying CPU power control under the Linux kernel. EAS extends the Linux kernel scheduler to make it fully aware of the power/performance capabilities of the CPUs in the system, to optimize energy consumption for advanced multi-core SoCs including big.LITTLE. With EAS, the Linux kernel will use the task load and a CPU ‘Energy Model’ to control task placement to select the optimal CPU to run on.
EAS is a completely different breed compared to the conventional HMP system, where it serves an entirely different purpose of achieving the optimal balance between performance and efficiency, with the latter taking the top spot. EAS achieves that via cleverer tasks placement, by which the system determines which is the more efficient cluster for the task to be processed by, as well as categorising the different tasks into cgroups (top-app, foreground and background, in order from highest priority to lowest priority respectively) by which each cgroup receives its sliver of the available firepower (cpuset). EAS also offers the capability of inflating the perceived load, that's determined by the load trackers, of the task in any of the cgroups via its schedtune.boost setting, and whether the task should be processed by all the cpu cores available or only by the cluster the task has been placed on via its schedtune.prefer_idle setting. One of the key features of EAS is lifting almost all the processing from the governor to the CPU scheduler (no it is not the I/O scheduler, something different) and letting it take much much more control, leaving the CPU governor to only do the frequency determination part, which unsurprisingly relies heavily on data supplied by the scheduler. With all that said, it is easily deduced that EAS is not all about governors and governor settings and the like, rather a much cleverer solution that serves the purpose of seeking the best balance between performance and efficiency, and to ensure the CPU is not overdoing a task or the CPU governor is overshooting a simple task, which would attribute to needlessly draining a lot of power as a natural consequence. EAS is about ensuring you get the smoothest UI possible while retaining as much power as possible. However, that does not mean that EAS is lame poor when it comes to performance. Sometimes, if not in most cases, this cleverer tasks placement makes tasks get processed faster, a point that is already proved quite well by the EAS-supporting non-OOS based custom ROMs like VertexOS, ZeNiTy-RR and PAEX. Conserving battery does not necessarily mean crushing performance. This explains that app launches are on-par with HMP if not ahead of it sometimes.
https://forum.xda-developers.com/general/general/ref-to-date-guide-cpu-governors-o-t3048957
Energy-aware scheduling (EAS) Governors
1. schedutil
Description:
schedutil is a new EAS governor found in recent versions of the Linux Kernel (4.7+) that aims to integrate better with the Linux Kernel scheduler. It uses the kernel's scheduler to receive CPU utilisation information and make decisions from this input. As a direct result, schedutil can respond to CPU load faster and more accurate than normal governors such as Interactive that rely on timers.
Oni svi poludeli sa tim romovima i kernelima... Nema čovek vremena ni da telefonira [emoji16]
Baš me zanima na koju foru je sredio "bug" sa flashlight.
I svaka mu čast ako je uspešno portovao EAS na msm8953.
Na zeninom Note 4x je stigao uodate 9.5.x.x. Imam root i stock recovery, uradio je download(OTA) ali ne moze da instalira update. Izbacuje failed. Koja je procedura?
Sent from my MI MAX using Tapatalk
Edit:
Isao sam u Magidisk, isao unroot, nije mogao da se bootuje jer verovatno više nije imao boot. Img. Skinuo Miflash, poslednju verziju u fastboot formatu. Malo se zezao, i upisao poslednju verziju i sacuvao podatke.
Slična problematika, ako može mala pomoć... Telefon mi jutros javlja da je update spreman za instalaciju (nisam išao u Check for updates, izgleda da je telefon sam svukao sve što treba). Telefon mi je otključan, instaliran je TWRP (standardna verzija) i SuperSU. Šta treba da uradim da mi se telefon ne bi zakucao u bootloop? Ideja mi je bila da skinem novi ROM, napravim backup, pa iz TWRP flešujem taj novi ZIP, LazyFlasher i SuperSU opet, pa restore aplikacija. Međutim, novonastala situacija traži drugačiji pristup, pa molim pomoć od prekaljenih članova.
Stavi redwolf recovery umesto twrp.
Trazi samo redwolf recovery mido i naci ces sva uputstva.
Mozes fleshovati novi rom rucno, kroz twrp, pa lazyflasher. Kod mene je bio stock recovery i izbrisan boot.img.
Stvarno na ovom kernelu bijeli fles,ali u kernel version pise unavailable na los14.1
Pozdrav, evo i da se ja pohvalim da posle 3g korišćenja g2 sam prešao na rn4 🙂 odličan telefon a posebno za pohvalu je fenomenalna baterija.
Šta ze dešava sa rn4, koja kombinacija je najbolja? Ostati na stock miui ili neki custom rom? Da li ima Google kapela za njega?
EAS:
1. schedutil
Description:
Ne znam, nisam nesto odusevljen autonomijom baterije na ovom kernelu, na romu Android Open Source illusion Project (AOSIP), ocekivao sam bolje rezultate. Probao sam juce i danas i mnogo bolji sot je na stock kernelu... Inace AOSIP je odlican rom, svidja mi se...
Evo i ja sam ga malo isprobao ali cini mi se da ima laga u nekim aplikacijama dok sa frankom ne.
Cek da probam i ja ovo mjaukanje (ispravka na forumu za psovke kao npr. j # b # g i slicno)... *mjau**mjau**mjau*, *mjau**mjau**mjau**mjau* ga, *mjau**mjau**mjau**mjau**mjau**mjau*, u picku materinu....
Edit: ahahhahahaha prosla ova zadnja, dal' je moguce da nju nisu stavili u ispravke? 🙂 [emoji23]
Znam za Red Wolf, ali kako da ga flešnem? Da li preko kompjutera (Minimal ADB and Fastboot)? Jer čim restartujem telefon prvi put, on će krenuti da povlači ovaj update i mogu upasti u bootloop.
Da li može ovako kako sam naveo: backup, reboot in recovery, flash 9.5.4.0 ROM, flash LazyFlasher, flash SuperSU, boot, restore backup?
Za white flash treba dodati u init.rc fajl kernela ovu liniju:
write /sys/devices/soc/qpnp-flash-led-25/leds/led:torch_1/max_brightness 0
Treba editovati boot.img
Zadnji xiaomi.eu. Definitivno nesto nije u redu...
9.5.1.0 je stable? Fali li mu kakvih opcija u odnosu na ovaj China developer na kom su bazirani xiaomi eu?
Ne koliko ja znam, ima sve sto ima xiaomi.eu pogledaj na sajtu, mozes sam "kreirati" rom. Izaberes verziju, i sta zelis da ima.
Slažem se. Probajte KudKernel, bolji je. 1.6GHz je default CPU freq, povećajte za bolje performanse.
Zna li neko koji gcam tj koja verzija i podesavanja idu za Lineage OS 14.1 official i Omnivision senzor? Ubih se naci neku a da ne crashuje posle 2min... Ne znam ni podsavanja koja idu
Svaka cast na otkricu Zile. Cudo jedno, pre su svi kukali za belim flesom, a sad je svima izgleda svejedno 🙂 navika je cudo
Moras probavati, mislim da prolazi Nexus 6p,i high hdr settings. Quality 97%
Moze li se staviti ovaj novi global notification shade na ovaj poslednji china stable ikako?
