Radi svuda uz pomoć https://play.google.com/store/apps/details?id=xyz.paphonb.systemuituner aplikacije.
Android Oreo Saves Devices in Bootloops with new Rescue Party Feature
https://www.xda-developers.com/android-oreo-rescue-party-bootloop/
Što bre, slobodno otključaj, ako rikne lako ćeš ga zaključati ako uđeš u bootloader
Ja baš iz bezbednosti na 6P uvek držim otključan, a i rut + pixel mod + adaway mnogo znače...
ROOT
SuperSU zip - https://s3-us-west-2.amazonaws.com/supersu/download/zip/SuperSU-v2.82-201705271822.zip
Adaway - https://f-droid.org/repo/org.adaway_60.apk
Jel nakon root-a na stock romu moze da se zakljuca bootloader? Plasim se zbog garancije da drzim otkljucan bootloader...
Bootloader
Kod:fastboot flashing lock
Kod:fastboot flashing unlock
(This command will wipe all user data from the device)
Important: do not lock the bootloader unless you have first flashed the stock images. Locking the bootloader while you have a custom recovery installed can result in a brick.
Please also note that the locking procedure will wipe all user data from the device.
TWRP - https://eu.dl.twrp.me/bullhead/twrp-3.1.1-0-bullhead.img
Kod:fastboot flash recovery twrp-3.1.1-0-bullhead.img
On 7.1.2 and above you'll also need to boot into TWRP recovery and wipe cache and dalvik cache.
ROOT
