Mozilla Firefox [FAQ u II postu]
Meni ništa ne radi kako treba. Brisao i instalirao sve ponovo i isto,kao da ne radi flash player i java jer mi ne izbacije sve a i u dodacima nema pola ekstenzija,hbogo mi traži javascript???
Ja kako pročitah ni java,silverlight nisu više podržani a samo delimično jeste AFP...Meni je obrisao one koje ne podržava a imao sam problema i sa javascript i jedva sam to uspeo da rešim...
Neke novosti koga interesuje:
Mozilla Had A Crazy Week Landing Servo, WebRender & More Into Firefox Repo
Written by Michael Larabel in Mozilla on 12 February 2017
This was one of the busiest weeks in Firefox's history with having more than ~10,000 change-sets affecting ~97,000 file changes.
Landing into the mainline codebase of Firefox Nightly's mozilla-central repository was vendoring the Servo project, WebRender, the ECMAScript ECMA-262 conformance test suite, and various Rust dependencies.
Servo and WebRender are now landing in the firefox-central code-base, albeit this isn't a magical switchover to using it by default or anything along those lines. Mozilla developers still hope to begin using some Servo components within mainline Firefox by the end of 2017. So a big milestone is crossed but this isn't yet anything that is directly affecting end-users.
The code is now in the Firefox repository and commits to the Servo Git repository now auto-land in the Firefox Mercurial repository automatically. Thus it's becoming easier for Firefox developers to begin making use of Servo, WebRender, and other components in the future as they continue work on Quantum.
Pocelo mi da sajt http://forum.benchmark.rs/ otvara kao https://forum.benchmark.rs/profile.php?do=dst i da tu zaglavi.
Ja pocnem pisati "fo" u ff mi se pojavi http://forum.benchmark.rs/ ja kliknem "ENTER" ff pocne otvarati i izbaci https://forum.benchmark.rs/profile.php?do=dst koji ostane "zaglavljen" ne otvori stranicu vec samo da belu stranu i kad ponovim ukucavanje "fo" i izbaci https://forum.benchmark.rs/ onda mi otvori stranicu foruma sve sa mojim ulogovanim nalogom...
Sta je problem?
Sta se desava?
Zasto se to desava?
Najvaznije, kako to srediti i otkloniti?
Prestalo je da me zeza, mozda je bilo do sajta, mozda je update od ff resio problem ...
Žalosna vremena
FU Mozilla za sva sr*nja koja rade!
Cyberfox koji koristim već dugo, za godina prelazi u EOL fazu. Još samo sigurnosne rupe od Firefox ESR-a :(.
Valjda će se naći neki da preuzmu projekat...
Ostaje još Waterfox kojeg sam pre koristio i Pale Moon koji je odavno raskrstio sa Firefoxom i kojeg koristim za striming
i ako se ništa ne dogodi, to će mi biti naslednik.
MIsliš na ukidanje podrške za XBL/XUL/XPCOM ekstenzije?
java ne radi odavno, bar u verziji na 64 bita firefox, mislim od verzije firefox 50 pa sam javu obrisao sa kompa, rekli su da je izbacuju zbog toga sto nije sigurna
U ff, kad skidam neki video sa yt recimo, koristim Video DownloadHelper adons u ff.
Skida on sve mp4 odlicno ali neki video sadrzaji se mogu naci samo kao neki ADP.
E te "ADP" ja ne umem skinuti na komp i kasnije gledati.
Kako video sadrzaje oznacene kao ADP skinuti i snimiti?
To pitam jer nekada samo ima u ADP da se nadje snimak, npr neke emisije na RTS, na Heppyy tv, nailazio sam na takve snimke vise puta i bio prinudjen dzedziti uz komp umesto da skinem i lepo sa fleske na tv gledam ono sto me zanima...
Ako neko zna sta i kako raditi sa ovim "ADP snimcima" molio bi da nam objasni i uputi kako da ih skinemo i po mogucnosti kako da ih prebacimo odma u mp4, dobro bi bilo tokom procesa skidanja video sadrzaja, ako je ikako moguce sa ovim Video DownloadHelper ili eventualno nekim drugim adons-om ili programom koji radi pod ff...
Da li je još neko primetio probleme sa UnMHT ekstenzijom za snimanje cele strane u .mht fie ?
Pre Firefox 52 je sve radilo kako treba. Od tada neke strane snima pogrešno. Naprimer, stranu sa ovog linka snimi pogrešno:
http://www.hifido.co.jp/KW/G/P0/A10/E/10-10/S0/C16-07779-15814-00/
Kada sam to primetio, prijavio sam na UnMHT forumu i video da je još jedan korisnik isto uočio. Od tada više ne mogu da otvorim UnMHT site, kao da je autor ugasio site ?
https://addons.mozilla.org/en-US/firefox/addon/unmht/
UnMHT is not compatible with e10s.
Stalno se pojavljuje ovaj kvadratic malo smara skenirao system Malwarebytes Anti-Malware-om I Adwcleaner-om, reinstalirao I opet.
Ako vam se nakon apdejta na v53.0 isključi multiprocess mogući krivac je ekstenzija MEGA.
Izvinjavam se ako je ponovljeno pitanje, proičitao sam poslednjih nekoliko strana ali nisam našao.
Naime, FF odnedavno neće da mi otvori postove ovde na benchu, hoće do spiska tema i sve teme prikaže ali kad treba neku temu da otvorim dobijam samo naslov,
a ostalo se učitava bukvalno 10-tak minuta, i prikazuje mi dole levo da učitava (vrti Waiting for googleads.g.doubleclick.net i gomilu linkova, valjda su to neke skripte).
Možda je i nešto vezano za security pošto mi gore levo govori connection is not secure - ali nemam dalje nikakve opcije da instaliram neki sertifikat ili nešto,
samo mi daje more information.
da li je imao neko sličan problem i kako da ga rešim?
Jel otvaras preko http ili https?
Preko https
Sad sam malo obratio paznju na to, prilikom logovanja na forum kaze connection is not secure,
a onda kad se ulogujem ispise mi invalid redirect to http ....
znaci moze da udje samo preko https izgleda
Kako da sklonim ovo upozorenje sa slike "This connection is not secure..."?
Hoću da mi stoji samo username i password, da kad otvorim stranu samo stisnem Enter i da se ulogujem. Baš je iritantno, iskače svaki put...
Hvala ljudi, to je rešilo problem :)
Ipak iskače padajući meni sa username-om na koji mora da se klikne, ali makar nema onog upozorenja. Mislim da ovo i ne može da se isključi. U svakom slučaju mnogo je bolje nego pre.
Konačno su promene ispod haube počele da se osećaju. Firefox više nije onaj tromi pregledač kao pre koju godinu koji su ljudi napuštali zbog Chrome. Još uvek se ne pokreće momentalno ali je mnogo bolje nego ranije, video sajtovi rade bolje, kao i uvek troši manje memorije nego Chrome. Što se izgleda tiče nove compact teme su vrh a nadolazeći revamp interfejsa će biti još bolji jer će konačno vratiti RELOAD tamo gde mu je mesto i uvećati BACK FORWARD i RELOAD, što je jako bitno.
Kada Servo bude potpuno integrisan i projekat Quantum završen biće ovo najbolji browser na tržištu kao nekad. Sigurna Rust baza će eliminisati ogroman broj bagova. Nadam se da Google neće igrati prljavo u nameri da sabotira konkurenciju, koristeći monopol nad internetom da zadrži svoje proizvode u vrhu. Pošto Google Chrome osim što se širi van web browser upotrebe i evoluira u neku super bloated nakazu, na polju pregledanja interneta tapka u mestu već godinama.
Ako ti nije problem razjasni sta si mislio pod ovom recenicom.
Google veoma dobro ako ne i odlicno razvija svoj motor.Bloated?Sta konkretno?Ne vidim nista beskorisno da isporucuje u svom brauzeru.Sve je lepo upakovano i korisno,a i odlicno radi.Ne vidim da on uzima nesto vise resursa od Edge-a i Firefox-a,a duplo bolje radi od njih.
Da nastavimo red. Sad ti objasni ovo. :p
Nema ništa beskorisno, ali ni ništa korisno. Užasan bookmark management (nema drag and drop, nema click to add u folderima u bookmarks baru), nemogućnost zadržavanja browsera nakon zatvorenog poslednjeg taba, nema "recently closed tabs" listu (osim kroz history), right-clik meni je užasan (ne nudi search drugim pretraživačima)... To su sve osnovne stvari i ako mi je potrebna ekstenzija da bih ih imao, onda je takav browser po mom mišljenju đubre.
Najbolje poređenje browsera bi bilo:
- Opera je Mercedes S klase (najbolji bookmark management, ugrađen ad-blocker, ugrađen VPN, "currency|search|copy" za selektovan tekst, podrazumevana "recently closed tab" lista, ugrađeni chat klijenti, dobar side panel, odvajanje i pinovanje video klipa, odličan speed dial panel, najbolji download manager...)
- Vivladi je E klasa (odličan bookamrk management, najbolje podešavanje search opcija, najbolja "recently closed tab" opcija, dobar side panel, podešavanje keyboard prečica, odličan donwlaod manager, odličan speed dial panel)
- Firefox je C klasa (u svemu dobar ni u čemu najbolji, mada ima ugrađen "pocket")
- Chrome je Dacia (jedino u čemu je bolji od ostalih je multi-user korišćenje. I dalje ne shvatam kako imaju 60% korisika, i zar je moguće da u jednoj kući može biti dvoje ljudi kojima je chrome prvi izbor)
- Edge je Jugo (kao Chrome, samo malo gori bookmark management i righ-click meni)
Chrome jede memoriju, strašno šta radi. Brzo se podiže jer je prvi uveo da čuči u pozadini dok su ostali imali cold start. Šta mi ne treba, prvo i osnovno ne treba mi Chrome Store i Chrome Apps i sve vezano za Chrome OS. Znači sve što nema veze sa pregledom interneta. Dev Tools su dobri ali bi voleo da se bira u instaleru da li će se instalirati ili ne i da stižu kao zasebna aplikacija u paketu koja se razume sa Chrome. To važi za sve browsere koji bundle-uju dev tools. Kao što nema svaki PC alate za programiranje u C i C++, tako ne treba ni svaki browser da ima opcije za izmene sajtova po defaultu.
Nisam od onih što misle da je Opera 12 vrhunac browsera niti mi treba da mi browser kuva ručak, proponent sam dobro uvezanih ali zasebnih aplikacija. Tako da mi u Firefoxu ovaj Pocket baš bode oči, ne znam koji će mi. Opera ima RSS reader koji mi isto nema mesta u browseru na način na koji je ugrađen. Da browser otvara feedove i prikazuje lepo u zasebnom tabu to je ok, ali ovi agregatori što pakuju CNN, Verge i BBC po defaultu su ništa drugo nego bloat. Sad ubacuju Facebook, Instagram i Telegram. Jes da koristim Telegram ali cenim zaseban app koji dobro komunicira sa browserom a ne in-browser addon Facebook i Instagram mi trebaju ko sneg u sred meseca jula.
Google sve što unapređuje tiče se njihovih proizvoda, po tom pitanju nisu ništa bolji od Microsofta. Ubili su konkurenciju gde su stigli. Internet pati da Vimeo ili neki sličan servis preuzme share od youtube reklamne mašinerije. Kao i za zdravom alternativom mejlu. Možda onaj duckduckgo nekad bude mogao na crtu Google ali to nije realno očekivati.
