Messaging i VoIP aplikacije(WhatsApp, Viber, Telegram, Signal, Skype..)
Skriveni cet izlazi kao prazna notifikacija.
Šta mu fali [emoji23]
Meni baguje, prikazuje mi last seen tad i tad a ljudi su online...
Sent from my E5823 using Tapatalk
Ne znam sta je..uradio sam reinstalaciju i opet isto
Na tabletu radi normalno a na telefonu ne
Beyond Genius Lies Insanity
razlog vise da mislim da je sve do tebe, tj do telefona :)
btw, ja jedino imam malo problema sa android wear (moto 360) - poruke se ne prikazu na ekranu ako su secret chat (sto je malo i logicno), i imao sam jedno pucanje vajber app na satu. Takodje, secret chats se uopste ne pojavljuju na PC-u, ali generalno, meni je vajber sve bolji i bolji, u svakoj verziji korisni noviteti, za razliku od npr FM i Messenger app, kod kojih skoro sve vazda isto...
Meni isto brljavi viber i pokazuje neka bezvezna vremena za online status, mada mi to nije ni problem, retko kada obraćam pažnju na to.
Sent from my KIW-L21 using Tapatalk
Signal update, what's new:
Changes in 3.31.4:
★ Video calling and improved audio calls are now enabled by default.
★ Bug fixes and performance improvements
eto izašla zakrpa za Vajber, kažu ljudi sredila im bagove. Ja i nisam imao problema :)
edit: ne radi mi sticker market, ni sa prošlom verzijom :smash:
Ne radi ni meni, izbacuje no connection
Sent from my Nexus+6P using Tapatalk
WhatsApp is bringing back statuses after replacing them with a Snapchat Story clone
A few weeks ago, WhatsApp replaced the ability for users to set a text-based in-app status with a Snapchat Stories clone. Now, after user backlash, the company is re-adding the ability for users to set an availability status through the About section of the messaging app, according to a report from TechCrunch.
Like Instagram, Facebook Messenger, and Facebook’s regular app, the WhatsApp version of Snapchat stories allows users to post pictures and videos that disappear after 24 hours. WhatsApp hoped that the picture and video stories would serve a similar function as the text-based statuses, but apparently users felt differently. Per WhatsApp, new About Status “will appear next to profile names anytime you view contacts, such as when creating a new chat or looking at Group info.”
There’s probably a lesson here somewhere about sticking to the things that users like about your app and not just running after the current popular thing that you’re competitors are doing, but given the industry’s pace of copying features from each other, it’s doubtful that anyone is actually going to learn anything from this.
In a statement to TechCrunch, WhatsApp noted that the new About Status feature should be rolling out to Android users in the next week, and to iOS users “soon.”
http://www.theverge.com/2017/3/15/14938800/whatsapp-about-statuses-snapchat-story-clone
Pomagajte, do skoro mi je sve regularno radilo.. i pre par dana me zvao cale na skype i ja sam njega cuo, al on mene nije..mislio sam ubagovalo, do neta itd..pa nisam proveravao, medjutim posle provalim da ne radi video poziv ni na wapp ni messengeru ni viberu...mikrofon radi, jer obican poziv radi..voice message takodje mogu da snimim, i mogu poziv preko tih app al ako nije ukljucena kamera.
Reinstalirao sam ceo soft..mrzelo me da radim jedno po jedno, da brisem pa instal app pa hard reset..nego sam odmah reinstal :D
I nije bilo uspesno...ako nije to resilo u cemu je problem?
Nasao sam nesto za "ok google" kao google voice search il sta vec..i kao probao da iskljucim - neuspesno..
takodje sam proverio dozvole..sve app su ok.
Telefon sony m4 aqua..android 23.3.A.0.131
Pomagajte :)
Pa izgleda da se kamera pokvarila, posto flesovanje softvera nije pomoglo. Voice search nema veze sa tim problemom, niti bi dozvole mogle biti sporne na tek instaliranom ROM-u.
A u tom slucaju kamera ne bi radila ni van tih app? Tacnije ne bi snimala zvuk. Upravo sam i to proverio - snima i radi normalno i prednja i zadnja :/ neke druge ideje? :D
I da..kad stavim slušalice,čuju me. Znaci samo mic ne radi kad je video poziv bez slušalica.
ja probao danas viber secret chat, ali neke poruke ipak nije obrisao automatski nakon što je iscurilo vreme na tajmeru?
Sigurniji je hidden chat, pazi sto cu da rizikujem da li je poruka istekla ili nije...
Da li znate koliko bateriju troše Viber, WA itd. za glasovne pozive, tipa recimo za 10min toliko procenata baterije te i te velicine?
iOS Viber kada se koristi wifi konekcija, moze duze da se prica u odnosu na gsm poziv.
Evo konkretno:
Signal voice poziv od oko 1h trosi oko 16% baterije od 2800mAh preko 3G.
Ja sam mislio viber nešto zeza, izgleda su ubacili kada si zadnji put ulazio u aplikaciju kao zadnji status?
Danas me podsetilo na privatnost - juce dobijem preko Vibera sliku nekakvih slusalica od kolege, a danas na FB iskacu reklame sa slicnim slusalicama.
Viber to Facebook. Seems usefull ;)
Sad malo razgledah opcije, ipak ima Facebook connect u aplikaciji. Jesi li povezao Viber sa FB?
Pa i meni nešto čudno u zadnje vreme, može biti da jesu ubacili to, mada nisu napomenuli u changelog-u.
Mnogo glupo ako jesu, onako kako je bilo je mnogo bolje.
Evo proverio sam na drugom telefonu i piše pre 10 minuta,bas tada sam ulazio. To je opasna glupost, nervira me to kod wa. Sad i ovi ubacili.
