LeEco Le Max 2
Ne znam, istražujem. Od 25.11 ne ažuriraju change log za MM, samo za Nougat. Znam da je sređen problem sa mikrofonom, da se tiho čulo pri snimanju i pri voip-u. Sada je sve ok.
Sent from my Le X820 using Tapatalk
Izašao 019s indijski oficijalni
eUI 5.8.019SNew!
Change Log
For any issues please log in to http://bug.letv.com/in
[Network]
Fixed an issue in which 4G Data is not working in Reliance JIO. (Le Max2)
Fixed an issue in which call drop happens when making VoLTE calls using Reliance JIO 4G network. (Le Max2)/(Le 2)
Fixed an issue in which Reliance JIO Sim can not register IMS. (Le Max2)/(Le 2)
Enabled VoLTE feature. (Le 2)
[Dialer]
Added back call recording function. (Le Max2)
Fixed an issue in which VoLTE HD call unstable and HD Signal disappeared once call started. (Le Max2)
[Video Player]
Fixed an issue in which the Next button is not working in default video player. (Le Max2)
[Music]
Added new music service provided by Hungama. (Le Max2)/(Le 2)
Fixed an issued in which Music stops when unlock music application by fingerprint or by pattern. (Le Max2)
Added service to control center to support third-party music app. (Le Max2)/(Le 2)
Fixed an issue in which no dynamic permission pop-up at first launch. (Le 2)
Added ‘Create Playlist’ option in Playlist. (Le 2)
[Camera]
Optimised focus performance in dark environment. (Le Max2)
Optimised focus performance in macro. (Le Max2)
Fixed an issue in which the focus keep moving in and out when taking photo of text in macro mode. (Le Max2)
Optimized flash brightness. (Le Max2)
Optimized color spot under HRD mode. (Le Max2)
Optimized QR Scanner focus speed. (Le Max2)
Enhanced the auto night mode (Le 2)
Optimized color display in low light conditions. (Le 2)
Fixed an issue in which ghosting may occur when taking photo of moving objects in HDR mode. (Le 2)
Optimized White balance performance. (Le 2)
Fixed an issue in which fingerprint unlock fails after few captures with camera from locker screen. (Le 2)
Optimized SLO-MO recording noise. (Le 2)
Optimized Green color performance under night mode. (Le 2)
Adjusted flash color cast. (Le 2)
Optimized color spot under HRD mode. (Le 2)
Optimized QR Scanner focus speed. (Le 2)
[Phone Manager]
Added auto alert switch in App Battery Usage Alert.(Le Max2)
Optimized network access control logic. (Le 2)
Optimized battery usage alert function. (Le 2)
Added an access to app lock and privacy lock. (Le 2)
Added Virus Scan. (Le 2)
Added Harassment Filter Function. (Le 2)
Added access to manage Trash Message. (Le 2)
[Fingerprint]
Version upgraded, Optimized using experience.(Le Max2)
[Setting]
Added Dual App feature. (Le Max2)
Added Small font option. (Le Max2)
Optimized font display. (Le Max2)
Optimized setup procedure of App lock. (Le Max2)
Added Do not Disturb. (Le Max2)
Optimized setup procedure of privacy lock. (Le Max2)
Added Small font option. (Le 2)
Added Three-finger screenshot function. (Le 2)
Fixed an issue in which font increased after OTA. (Le 2)
Optimised the App lock’s processing logic. (Le 2)
[My LeEco]
Added LeEco Membership (Le Max2)
[Message]
Added default SIM card option for messaging. (Le Max2)/(Le2)
Fixed an issue in which received new message while all messages selected, message stopped.(Le Max2)
Added an access to settings page. (Le 2)
Added SIM info and longer preview in Notification Centre. (Le 2)
Fixed an issue in which received new message while all messages selected, message stopped. (Le 2)
[Screeshot]
Added Three-finger gesture for screenshot function.(Le Max2)
[Ringtone]
Added more ringtones (Le Max2)
[Battery]
Added quick charge switch (Le Max2)
Add Battery Temperature (Le Max2)
[Sound & Vibration]
Added Vibration switch.(Le Max2)
Added Dolby Atmos (Le Max2)
Added separate ringtone setting for dual sim card.(Le Max2)/(Le2)
[Third-party App]
Fixed an issue in which WhatsApp can only send 1 local music file at once.(Le Max2)/ (Le 2)
Fixed an issue in which sound cannot switch from earphone to speaker after unplugged earphone when listening to Whatsapp voice message. (Le 2)
Optimised WhatsApp Notification tone volume. (Le 2)
[System]
Changed minimum battery requirement for upgrade to 30%.(Le Max2)
Fixed an issue in which APN setting is unable to edit.(Le Max2)/(Le2)
Fixed an issue in which JIO network does not work properly.(Le Max2)/(Le 2)
Adjusted ZRAM strategy now default set as off. (Le 2)
Updated Google security patch. (Le 2)
Changed minimum battery requirement for upgrade to 30%. (Le 2)
[Feedback]
Fixed an issue in which the ‘feedback’ app crashes after submitted online feedback. (Le 2)
[Recovery Mode]
Fixed an issue in which ‘no .apk file found’error message pop up when update system in recovery mode. (Le 2)
[Type-C]
Optimised Type-C earphone energy consumption when using GPS. (Le 2)
Fix the issue where there is a pop sound in type-C earphones at dialling. (Le 2)
[Dolby Atmos]
Optimised Dolby Atmos. (Le 2)
Modified Dolby parameter. (Le 2)
[Phone/Contact]
Added back call recording function. (Le 2)
Optimized new contact creating procedure. (Le 2)
Added SIM name on dial button when using Dual Sim. (Le 2)
Added blacklist in Contact setting. (Le 2)
Fixed an issue in which VoLTE HD call was unstable and HD Signal disappeared once call started. (Le 2)
[Recovery Mode]
[Wallpaper]
Fixed an issue in which wallpaper change back to default occasionally. (Le 2)
[Hall Sensor]
Optimised Hall Sensor Int value which fixed auto lock screen issue. (Le 2)
[Wi-Fi]
Fixed an issue in which occasional Wi-Fi signal loss when connecting to open Wi-Fi network. (Le 2)
Fixed an issue in which WLAN displayed instead of Wi-Fi when system language is English. (Le 2)
[Bluetooth]
Fixed an issue in which search function stop working after unpaired. (Le 2)
Fixed an issue in which WeChat cannot play a complete voice message in Bluetooth mode. (Le 2)
Fixed an issue in which Bluetooth function fail to open. (Le 2)
Fixed an issue in which fail to share files. (Le 2)
[Browser]
Fixed an issue in which navigation website changes with phone language setting. (Le 2)
[Note]
Added Privacy lock. (Le 2)
[Clock]
Fixed an issue in which date format incorrect in Dual Clock widget. (Le 2)
Fixed an issue in which dual clock widget cannot be opened when switch from standard view to zoomed view. (Le 2)
Fixed an issue in which some city take longer time to load in dual clock widget. (Le 2)
Fixed an issue in which alarm only have sound but no visual when goes off in multi-task interface. (Le 2)
Adjusted Date format for different regions. (Le 2)
[Gallery]
Fixed an issue in which video cannot be played in hidden album. (Le 2)
[Mail]
Added ‘Long press’ to select all action in Contact detail page. (Le 2)
[Calendar]
Added attachments count in Meeting Event. (Le 2)
Znaci trebao bi cuoco92 isto da izbaci update uskoro
Cuoco radi na bazi kineskog roma, a mislim da ce i to skoro..
Promjene sam vidio na dev verziji. Drugaciji je dialer, malo su usminkali. i onaj recent apps sa togglom wifi, data itd. je skroz redizajniran..
Poslano sa mog Le X820 koristeći Tapatalk
Pratim vec neko vreme temu o ovom telefonu i posle mnogo odgledanih review-ova po netu, a i sudeci po komentarima korisnika koji poseduju isti, pokazao se kao jak allround igrac bez nekih izrazenih mana, te odlucih da pazarim sebi jedan.
Odakle je trenutno najpovoljnije naruciti na EU, sa sto manje marzi ? Boja nije presudna, ali je pozeljna gold ili siva. Ne znam kako uzivo izgleda ova rose gold ali kapiram da nije toliko tragicna :D
P.S. u krajnjem slucaju, ako je neko voljan da proda moze svoj tel neka pise na pm
Imam tu rose i unutra izgleda kao zlatno-cigla boja a gde je jača svetlost presijava i ta rose boja mada uvek se stavi neki case i to je to.V idi na e-foxy bilo 205e + poštarinu bez davanja ali lepo pročitaj sve tamo.
Lukam,vidim stavio si 018s i koje razlike primećuješ u odnosu na 021s tj da li se isplati prelaz.
Mokee sajt ne radi ????
Imaju radove, biće online kasnije...
Cekam pa da probam i taj mokeee,Darko da li mozes da napomenes sta je bitno kod njega npr da se stavi dosteluje itd.
@rista1 na e-fox ima rose gold iz evropskog skladista za 240eur sa postarinom i dazbinama ili iz Kine za 200eur bez uracunatih troskova...nije bas sjajna ponuda
ovde nadjoh za 215 eur + 5-6 eur za EU Customs Insurance https://flosmall.com/products/leeco-le-max-2?variant=19159212486
Da li doplata za to EU Customs Insurance stvarno ima smisla u praksi, jel neko imao iskustva sa time ?
Pise im na sajtu da im po isporuci treba ima poslati racune carinjenja i oni potom refundiraju te troskove
Koliko je pouzdan ovaj flosmall i da li je neko imao iskustva sa tim refundiranjem troskova carinjenja ?
Ja sam kupio iz Evrope na e-foxu i kada prebaciš u dolare i plus kod ispada 230e i stiže ti na adresu u EU npr meni u Beč za tri dana.
nebitno dali idu iz Europe ili ne, ne placas carinu/pdv na adrese u EU.. popust ima trenutno od 6€ samo.. upisi DS-TLKZ..
from my I9505X Demo on TT
Onda ti ispada 269e i to je extra cena ako ti treba dosta slobodnog prostora jer na 32 gb ostaje ti u startu 24gb
@sasha2511 hvala za hint ;)
@rista1 naravo da znaci, prostora nikad dosta :D ovako sam miran...jer ovom ver 6/64 donekle resavam ujedno po meni najveci nedostatak ovog tel, prosirivanje skladisnog prostora micro SD karticama :D
Rodjak iz Svabije krece 20.12. Nadam se samo da ce telefon stici do njega pre nego sto on krene za Srbiju :S:
Ako planira da ti stigne naruči odmah u ponedeljak jer oni kažu 8-10 radnih dana .
http://www.grossoshop.net/letv-leeco-le-max-2-6-64gb-force-gold.html?search=le max 2
NA ovom linku koji je postavljen na prethodnoj strani cena je 260e (-6e kupon), ali nigde nisam mogao da pronađem uslove za prevoz i da li postoje još neki dodatni troškovi. Gde to mogu da vidim i koliki su? Dostava bi bila u Francusku.
nema dodatnih troskova osim jos 15 € shiping i to je zadnja cijena s dostavom iz Kine SF Expressom.. SF Ex nosi do EU i onda preuzima DPD..
garancija 2 godine sa servisom za manje kvarove u Italiji a za vece u Kinu + DOA (dead on arival) garancija od 7 dana..
from my Le X720 on TT
Hvala. Da li to isto važi i za verziju 4/32gb? Mislim na to da nema dodatnih troškova carine, odnosno da se plaća samo putni trošak od 15e?
za HR je 19€ shiping inace.. za FRA je 15€ posto si za tamo pitao..
18 je skoro isti kao 21, zapravo ne znam koje su razlike.. cinilo mi se da je na 21 bolja baterija ali nije ni tu losa
Da, za Francusku sam pitao, u Hrvatskoj nemam nikoga. Hvala i tebi i Risti na odgovorima.
Za moj ukus ništa, zato ga i koristim. Jedino naravno gapps moraš da instaliraš. Root se uključuje u developer settings.
E sad ne znam ako na nešto konkretno ciljaš...
Meni je bio problem preko titaniuma vratit backup aplikacija s EUI na mokee, mozda bi islo bolje da sam flesao superSu uz postojeci root. Drugo sve 5, nema neugodnih iznenađenja
Edit: proradila moki stranica
U stvari zaboravio sam. Ja dodajem jednu stvar ali ona je većini ljudi totalno nebitna. Naime, skroz mi je ok truecaller tj njegova opcija da identifikuje čiji je broj sa kojeg primaš poziv a nemaš ga u imeniku. Sad imaju već veliku bazu i naših brojeva i to sve već počinje da liči na nešto.
E sad, uvek možeš da instaliraš truedialer sa gplay i rešiš problem no meni to ne dolazi u obzir. Pošto Mokee podržava i capps, onda instaliram i truecaller addon za default dialer kao i cyanogen account jer bez toga ne radi.
Naravno rade sve capps, tako da kome šta od istih treba, može da instalira...
