Eh, baš bih probao sad ali sam već vratio telefon vlasnici 🙁Pa zar mislis da bih ja koristio nesto, a da ne valja??? 🙂
Na RR radi sve, FP 99 od 100 😉
Radi cak i vise, uz odogarajuci kernel imas i dt2w, uz moj mod za sim imas 3g na oba sim-a...
Sent from my RN3 Pro
Hvala puno.Xiaomi.eu ostavlja twrp.To je custom rom.
Samo flesujes za Kate Xiaomi.eu, ne za Kenzo 😉
Od juce ne radi refresh weather..
Zadnja beta..
A je li? Ispod pise Sent from my Redmi Note 3.. 🙂
Jel ima neko resenje za aplikaciju za vremensku prognozu? Nece da mi se azurira stanje vec nekoliko dana, dobijam poruku "Couldnt connect to network"
@mgx
Go to /sytem/etc and editmixer_paths_wcd9326.xml, change "CLS_H_LP" to "CLS_H_HIFI"this should improve sound for you, I kept LP as default because HIFI produces noise for many users but you can try it, just edit the line, save file and reboot your phone. You can try both LP and HIFI modes and see what is best for you, screenshots attatched for reference, hope this helps.
