@Saj a da im kazemo da povremeno istusiraju karte da se rashlade🙂 , niovajlije, samo sa kartama pod vodom mozete da se ponasate tako, kupite vodena hladjenja pam ih ganjajte do mile volje, al za to morate da se isprsite jos koliko za karte
Rade li ovi drajveri 15.12 koje clay preporucije na rx serijama? I ima li razlike, vredi li ih ubacivati?
Kako da namestim na nano poolu da mi isplacuje na 1eth a ne na 0.2
predjite na miningpoolhub ili suprnovu
Because of the recent developments concerning the soft/hard fork discussion because of the DAO Hack and the decisions by the Dev's, I've decided to close the Ethereum Pool as I think ETH does not comply with the idea of irreversible, uncensored blockchain technology.
ETH is still a brilliant coin (or rather a technology) with most likely a bright future because of all the funding invested the clever dev's attached and all the possibilites with Smart Contracts etc. Of course mine it if its profitable for you, or not if you don't like the whole (changed) idea behind it.
The Pool will remain running until the fork occurs, as there are plenty of pools already it should be pretty easy to move over. It was a pleasure being one of the first pools available for ETH and I enjoyed working with the technology.
Please move your miners to the other pools, it was great to have you on suprnova, check the main page, lots of other coins are listed there too or just PM me if you find a coin that is not listed.
Ne na suprnovu !!!
