LBRY Credits [LBC]
Već sam napisao da je autor post. Nepotrebno cijena je poznat mene. :)
Utisak na dva GPU. Nisam znao gdje da udari softvera mod.
Covece, koristi engleski jezik :) Ovo je da te bog sacuva!
I think so. I already too tired to write in another language. :)
ma nikakav problem, samo me zanimalo odakle si, ja miner nemam, a ko ima neka se javi, mozes da pises na engleskom valjda nece admini da prave problem
Kako je krenulo... dno je do same zemlje, pa kada iskopas rupu i probijes na drugi kraj zemlje, negde, tamo... u Kini, ko ce ti ga znati :p :smash:
Through the core of the earth i will not beat it to China. But never say never. :):):)
Nesic1: You wrote me something. If I wanted the sgminer software modded, so who should I contact. When you write that you do not have him.
I don't have the miner, if someone have it, He will write here and contact you, I suppose
We already have modded sgminer, you wrote you have 145 MH with two 7970, with modded miner you will get around 180 MH, but, if you have only two 7970, you won't notice improvement, because LBC is worth at the moment 0.001 BTC, you will mine only 6-7 LBC per day, and diff is so high now...
This is also true. I guess it does not make sense for the two GPUs. I try to look for other coins or buy any other gpu´s.
Only you can do with two 7970 is to wait for a new coin announcement - be the first to mine it while diff is so low, then wait for exchange, and then try to instant sell for high price.
posalji mail u pm da bi te pozvali...ne moze ovako da se udje
Sent from my MX5 using Tapatalk
ma samo lazna nada ja vidim da ce na 50k ovo sto kao malo dadne neki znak samo je varka bilo je ovako i na 100k...mozda ne budem u pravu :d
Neka padne koliko hoce, nije njemu problem da skoci... Pre nedelju dana je isto bio beda, pa za kratko skocio 10x...
Sto se mene tice,neka skoci jos jednom,nebitno kad.... Ja ga cekam
