Da li vi zaustavljate rudarenje pri promeni svakog daga, da bi se napravili novi, ili masine to rade same i nastave? Ima li to neke veze sa negativnim sherovima?
meni poslednjih par sati na coinotronu drzi tacno na 40mhs, umesto 60...
nadam se da nije do mene, jer je u mineru sve ok...
Pump! Ima ovo da ode i do 0,023...![]()
SAMPLE USAGE
Dual mining Ethereum & Decred:
ethpool, ethermine (and Stratum for Decred):
EthDcrMiner64.exe -epool us1.ethpool.org:3333 -ewal 0xD69af2A796A737A103F12d2f0BCC563a13900E6F -epsw x -dpool stratum+tcp://yiimp.ccminer.org:4252 -dwal DsabMdMku2tjrDcPtkwd7tvGfyskgHMG8ex -dpsw x
you can also specify "-esm 1" option to enable "qtminer" mode, in this mode pool will display additional information about shares (accepted/rejected), for example:
EthDcrMiner64.exe -epool us1.ethermine.org:4444 -esm 1 -ewal 0xD69af2A796A737A103F12d2f0BCC563a13900E6F -epsw x -dpool stratum+tcp://yiimp.ccminer.org:4252 -dwal DsabMdMku2tjrDcPtkwd7tvGfyskgHMG8ex -dpsw x
dwarfpool (and Stratum for Decred):
EthDcrMiner64.exe -epool eth-eu.dwarfpool.com:8008 -ewal 0xD69af2A796A737A103F12d2f0BCC563a13900E6F -epsw x -dpool stratum+tcp://dcr.suprnova.cc:2252 -dwal Redhex.my -dpsw x
you can also specify "-eworker YourWorkerName" option.
miningpoolhub:
EthDcrMiner64.exe -epool us-east1.ethereum.miningpoolhub.com:20536 -ewal 0xD69af2A796A737A103F12d2f0BCC563a13900E6F -eworker YourLogin.YourWorkerName -epsw x -dpool http://dcr.suprnova.cc:9111 -dwal Redhex.test -dpsw x
you must also create worker "YourWorkerName" on pool and specify your wallet address there.
coinotron, coinmine:
EthDcrMiner64.exe -epool coinotron.com:3344 -ewal Redhex.rig1 -esm 2 -epsw x -dpool http://dcr.suprnova.cc:9111 -dwal Redhex.my -dpsw x -allpools 1
Loš mu je miner, tj šarena laža. I ETH only i multi. qtminer keva
ispisuje rec po rec 10 minuta dok krene...
280x koja je uvek bila iskoriscena 99 posto,sada pala na 90.
evo vratih 280x na default bios... opet sve isto, oko 90 posto bleji, varijacije ogromne 30-60mhs....
jedna 380 kao luda sa zauzecem...
Pogledajte prilog 198340
taj miner je instaliran pre sat vremena, ethminer i proxy.
inace koristim genoil koji ne instaliram, portable je.
dagovi menjani XX puta
