Da li ovo ista vise pokazuje? Odnosno da li je normalno da to sto mi pokazuje da ce baterija da drzi narednih 9h? Iskreno, nemam iskustva i meni to deluje da je malo
Pogledajte prilog 194829
Stavi network mode na WCDMA/GSM jer ti je loš signal ...
Osvetljenje ekrana AUTO (5)...
Sve zavisi šta sve imaš instalirano na telefonu i kako ga koristiš![]()
Network tako i stoji, osvetljenje ekrana isto
Od apikacija imam sledece:
Facebook i messenger
Viber, skype, whatsapp, linkedin
tapatalk
Monster, Job Search, Adverts, donedeal, daft.ie ( ovo su Irske aplikacije za pretragu poslova i iznajmljivanje stanova i oglasi kao nas kupujem prodajem)
I to je to, i fingerprint koristim
Najvise u toku dana koristim viber
Signal je inace slab u ovom stanu gde sam trenutno, cim izadjem napolje bude pun signal. Ne, necu da budem ceo dan napolju ako je to razlog da baterija duze traje![]()
Factory reset the Galaxy Note 4: method 2 (hardware buttons)
1. Turn off your Galaxy Note 4.
2. Press and hold Power, Volume Up and the Home button until you see Recovery booting in blue at the top of your screen. Release the buttons.
3. You'll now be in Recovery Mode. Use the volume buttons to scroll up and down and the Power button to confirm. It's not a bad idea to wipe the cache partition while you're here, but it is not essential.
4. Scroll down to Wipe data/Factory reset and press Power to confirm.
5. Scroll down to Yes and press Power to confirm.
6. You'll see a notification in yellow at the bottom of the screen to confirm the reset has been completed. Scroll to Reboot system now and hit Power to confirm.
7. Your Galaxy Note 4 will now reboot. Once it has rebooted, you can restore your apps and data.
